Part Number: TM4C1290NCPDT
Other Parts Discussed in Thread: TM4C129XNCZAD,
I have few queries related to lcd interface ..
Can I interface below attached datasheet LCD ?LXD-M7637A-spec.pdf
I respect the protecting IP, but screen manufactures have an odd way of using the word "confidential".
Edit: after posting I realized I too may be breaking the rules. I had linked to newhaven and displaytech-us as examples of offending the use of the word "confidential". More examples of screen manufacturers hosting "confidential" data sheets on their websites are not hard to find.
This appears to be a different screen from a different manufacturer. Perhaps you've taken cb1's advice?
My initial post is incorrect due to confusion from the title. The TM4C1290NCPDT does NOT have the LCD peripherals you need to drive this screen. The TM4C129XNCZAD does. Read section 26 of the TM4C129XNCZAD's datasheet and it should be clear. Table 31-3 in the TM4C129XNCZAD's will show the signals for the screen's interface. For example, pin N4 is VSYNC.
The part number mix up is caused by 'x' sometimes being a placeholder for various values, but the TM4C129X chips use the 'x' in the part number. What was your intention when creating the title? Why have you cited TM4C1290NCPDT?
