I'm try to use MibSPI with DMA,it didn't work.
here is my code and project.
/** @file sys_main.c * @brief Application main file * @date 07-July-2017 * @version 04.07.00 * * This file contains an empty main function, * which can be used for the application. */ /* * Copyright (C) 2009-2016 Texas Instruments Incorporated - www.ti.com * * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /* USER CODE BEGIN (0) */ /* USER CODE END */ /* Include Files */ #include "sys_common.h" /* USER CODE BEGIN (1) */ #include <mibspi.h> #include <sys_dma.h> /* USER CODE END */ /** @fn void main(void) * @brief Application main function * @note This function is empty by default. * * This function is called after startup. * The user can use this function to implement the application. */ /* USER CODE BEGIN (2) */ #define D_SIZE 64 uint16 tx_data[D_SIZE] = {0}; uint16 rx_data[D_SIZE] = {0}; g_dmaCTRL g_dmaCTRL_tx; g_dmaCTRL g_dmaCTRL_rx; /* USER CODE END */ int main(void) { /* USER CODE BEGIN (3) */ sint32 i; for (i = 0; i < D_SIZE; i++) { tx_data[i] = i; } mibspiInit(); mibspiEnableLoopback(mibspiREG1, Analog_Lbk); dmaEnable(); //mibspiSetData(mibspiREG1, 0, tx_data); dmaReqAssign(DMA_CH0, 1u); g_dmaCTRL_tx.SADD = (uint32)(&tx_data); g_dmaCTRL_tx.DADD = (uint32)(&(mibspiRAM1->tx[0])); g_dmaCTRL_tx.CHCTRL = DMA_CH0; g_dmaCTRL_tx.FRCNT = 1u; g_dmaCTRL_tx.ELCNT = D_SIZE; g_dmaCTRL_tx.ELDOFFSET = 4u; g_dmaCTRL_tx.ELSOFFSET = 0u; g_dmaCTRL_tx.FRDOFFSET = 0u; g_dmaCTRL_tx.FRSOFFSET = 0u; g_dmaCTRL_tx.PORTASGN = 4u; g_dmaCTRL_tx.RDSIZE = ACCESS_16_BIT; g_dmaCTRL_tx.WRSIZE = ACCESS_16_BIT; g_dmaCTRL_tx.TTYPE = FRAME_TRANSFER; g_dmaCTRL_tx.ADDMODERD = ADDR_INC1; g_dmaCTRL_tx.ADDMODEWR = ADDR_OFFSET; g_dmaCTRL_tx.AUTOINIT = AUTOINIT_ON; dmaSetCtrlPacket(DMA_CH0, g_dmaCTRL_tx); dmaSetChEnable(DMA_CH0, DMA_HW); mibspiREG1->DMACTRL[0] |= (((1 << 4) | 0) << 16); mibspiREG1->DMACTRL[0] |= 0x8000C000u; mibspiREG1->DMACTRL[0] |= (0 << 8) |(0 << 24); mibspiTransfer(mibspiREG1,0 ); while (!(mibspiIsTransferComplete(mibspiREG1,0))) {} mibspiGetData(mibspiREG1, 0, rx_data); while (true) {} /* USER CODE END */ //return 0; } /* USER CODE BEGIN (4) */ /* USER CODE END */
