RTOS/EK-TM4C129EXL: 20 ADC Channels in combination with uDMA and TI-RTOS; Problem with the Transfersize
Part Number: EK-TM4C129EXL
Tool/software: TI-RTOS
guys I am using Code Composer Studio 8.0 on a Windows 7 machine and was already able to write simple application with the EK-TM4C129EXL in combination with and without TI-RTOS Tivac 2_16_00_08.
I am working on an application where the 2 ADC's should sample the 20 available analog inputs with a sampling rate of 50 kHz for a single analog input. The ADC modules run with 1MHz sampling rate. Each ADC module samples 10 channels with the help of 2 sequencers. The mapping from analog input to sequencer position is as following:
ADC0                                         | ADC1
Sequencer0: AIN0                   |Sequencer0: AIN10
                        AIN1                   |                         AIN11
                        AIN2                   |                         AIN12
                        AIN3                   |                         AIN13
                        AIN4                   |                         AIN14
                        AIN5                   |                         AIN15
                        AIN6                   |                         AIN16
                        AIN7                   |                         AIN17
Sequencer1: AIN8                   |Sequencer1: AIN18
                        AIN9                   |                         AIN19
The data from the sequencer FIFOs to the SRAM should be done by the uDMA with Ping-Pong transfers. Later the application should be able to sent the data in the Ping buffer via TCP/IP to a PC, while the uDMA is filling the Pong buffer and vice versa. This feature is not yet implemented, but is my motivation to use TI-RTOS. Without TI-RTOS the above described behavior of the ADC and uDMA is perfectly fine for every transfersize I'm choosing. The following code implements the above described behavior without TI-RTOS and is fine:
#include <stdint.h>                     //Variable definitions for C99 standard
#include <stdbool.h>                    //Boolean definitions for the C99 standard
#include "inc/tm4c129encpdt.h"
#include "inc/hw_memmap.h"              //Macros defining the memory map of Tiva C.
#include "inc/hw_types.h"               //Defines common types and macros
#include "driverlib/sysctl.h"           //Includes API functions such as SysCtlClockSet and SysCtlClockGet
#include "driverlib/interrupt.h"
#include "driverlib/gpio.h"             //Includes API functions such as GPIOPinTypeGPIOOutput and GPIOPinWrite
#include "driverlib/timer.h"
#include "driverlib/adc.h"
#include "driverlib/fpu.h"
#include "driverlib/udma.h"
//constants //TODO: All constant defines written in CAPSLOCK
#define ADCFrq                                  50000
#define FIFO0                                   8
#define FIFO1                                   4
#define ResultLength                            2048
#define NumberOfSequsForTimingError             1024
#define SamplePosiForTimingTest                 200
#define NumberOfAinChannels                     20
#define UDMATRANSFERSIZEFIFO0                   8
#define UDMATRANSFERSIZEFIFO1                   4
//ADCClockingDefinesVJ
#define PIOSC16MHZ                              0x00000000
#define PLL480MHZTO32MHZ                        0x00000001
//DMATransferDefinesVJ
#define ADC0SS0VJ                               0x00000000
#define ADC0SS1VJ                               0x00000001
#define ADC1SS0VJ                               0x00000002
#define ADC1SS1VJ                               0x00000003
#define DMATRANSFERSIZE_SS0                     1024
#define DMATRANSFERSIZE_SS1                     (DMATRANSFERSIZE_SS0/8)*2
//Since the DMA control table needs to be aligned to a 1024 address
#pragma DATA_ALIGN(pui8ControlTable, 1024)
//control structure itself
uint8_t pui8ControlTable[1024];
//prototyping
void ErrorFunction(void);
void TimingErrorEval(void);
void VJADCClockingSetting(uint32_t ui32Setting);
void DMATransferReEnable(uint32_t NumOfTransfer);
void DMASetup(void);
uint16_t Adc0_FIFO0_UDMA_A[DMATRANSFERSIZE_SS0];
uint16_t Adc0_FIFO1_UDMA_A[DMATRANSFERSIZE_SS1];
uint16_t Adc1_FIFO0_UDMA_A[DMATRANSFERSIZE_SS0];
uint16_t Adc1_FIFO1_UDMA_A[DMATRANSFERSIZE_SS1];
uint16_t Adc0_FIFO0_UDMA_B[DMATRANSFERSIZE_SS0];
uint16_t Adc0_FIFO1_UDMA_B[DMATRANSFERSIZE_SS1];
uint16_t Adc1_FIFO0_UDMA_B[DMATRANSFERSIZE_SS0];
uint16_t Adc1_FIFO1_UDMA_B[DMATRANSFERSIZE_SS1];
uint16_t ADCTest[DMATRANSFERSIZE_SS0];
uint32_t ADCTestIndex=0;
uint32_t i=0;
uint32_t TIMER2=0, ADC0SEQUENCER0=0, ADC0SEQUENCER1=0, ADC1SEQUENCER0=0, ADC1SEQUENCER1=0, ui32Mode=0,
         ADC0Sequencer0SWI=0, ADC0Sequencer1SWI=0, ADC0Sequencer0SWI_A=0, ADC0Sequencer0SWI_B=0,ADC0Sequencer1SWI_A=0,ADC0Sequencer1SWI_B=0,
         ADC1Sequencer0SWI=0, ADC1Sequencer1SWI=0, ADC1Sequencer0SWI_A=0, ADC1Sequencer0SWI_B=0,ADC1Sequencer1SWI_A=0,ADC1Sequencer1SWI_B=0,
         DebugPrint=0         ,DmaErrors=0;
    uint32_t ui32Mode;
    switch (NumOfTransfer)
        case ADC0SS0VJ:
            ui32Mode=uDMAChannelModeGet(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT);
            if(ui32Mode==UDMA_MODE_STOP)
               uDMAChannelTransferSet(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40038048, Adc0_FIFO0_UDMA_A, DMATRANSFERSIZE_SS0);
               for(i=0;i<128;i++)
                   ADCTest[ADCTestIndex+i]= Adc0_FIFO0_UDMA_A[8*i];
               ADCTestIndex=ADCTestIndex+128;
               ADC0Sequencer0SWI_A++;
            ui32Mode=uDMAChannelModeGet(UDMA_CHANNEL_ADC0|UDMA_ALT_SELECT);
               uDMAChannelTransferSet(UDMA_CHANNEL_ADC0|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40038048, Adc0_FIFO0_UDMA_B, DMATRANSFERSIZE_SS0);
               for(i=0;i<128;i++)
                   ADCTest[ADCTestIndex+i]= Adc0_FIFO0_UDMA_B[8*i];
               ADC0Sequencer0SWI_B++;
            if(ADCTestIndex>=DMATRANSFERSIZE_SS0)
                ADCTestIndex=0;
            if(uDMAChannelIsEnabled(UDMA_CHANNEL_ADC0)==0)
                uDMAChannelEnable(UDMA_CHANNEL_ADC0);
                ADC0Sequencer0SWI++;
        break;
        case ADC0SS1VJ:
            ui32Mode=uDMAChannelModeGet(UDMA_CHANNEL_ADC1|UDMA_PRI_SELECT);
               uDMAChannelTransferSet(UDMA_CHANNEL_ADC1|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40038068, Adc0_FIFO1_UDMA_A, DMATRANSFERSIZE_SS1);
               ADC0Sequencer1SWI_A++;
            ui32Mode=uDMAChannelModeGet(UDMA_CHANNEL_ADC1|UDMA_ALT_SELECT);
               uDMAChannelTransferSet(UDMA_CHANNEL_ADC1|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40038068, Adc0_FIFO1_UDMA_B, DMATRANSFERSIZE_SS1);
               ADC0Sequencer1SWI_B++;
            if(uDMAChannelIsEnabled(UDMA_CHANNEL_ADC1)==0)
                uDMAChannelEnable(UDMA_CHANNEL_ADC1);
                ADC0Sequencer1SWI++;
        break;
        case ADC1SS0VJ:
            ui32Mode=uDMAChannelModeGet(UDMA_SEC_CHANNEL_ADC10|UDMA_PRI_SELECT);
                uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC10|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40039048, Adc1_FIFO0_UDMA_A, DMATRANSFERSIZE_SS0);
                ADC1Sequencer0SWI_A++;
            ui32Mode=uDMAChannelModeGet(UDMA_SEC_CHANNEL_ADC10|UDMA_ALT_SELECT);
                uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC10|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40039048, Adc1_FIFO0_UDMA_B, DMATRANSFERSIZE_SS0);
                ADC1Sequencer0SWI_B++;
            if(uDMAChannelIsEnabled(UDMA_SEC_CHANNEL_ADC10)==0)
                uDMAChannelEnable(UDMA_SEC_CHANNEL_ADC10);
                ADC1Sequencer0SWI++;
        break;
        case ADC1SS1VJ:
            ui32Mode=uDMAChannelModeGet(UDMA_SEC_CHANNEL_ADC11|UDMA_PRI_SELECT);
                uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC11|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40039068, Adc1_FIFO1_UDMA_A, DMATRANSFERSIZE_SS1);
                ADC1Sequencer1SWI_A++;
            ui32Mode=uDMAChannelModeGet(UDMA_SEC_CHANNEL_ADC11|UDMA_ALT_SELECT);
                uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC11|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40039068, Adc1_FIFO1_UDMA_B, DMATRANSFERSIZE_SS1);
                ADC1Sequencer1SWI_B++;
            if(uDMAChannelIsEnabled(UDMA_SEC_CHANNEL_ADC11)==0)
                uDMAChannelEnable(UDMA_SEC_CHANNEL_ADC11);
                ADC1Sequencer1SWI++;
        break;
void DMASetup(void)
     uint8_t *CheckTable=0xFFFFFFFF;
     uint8_t *CheckTable1=0xFFFFFFFF;
     uint8_t *CheckTable2=0xFFFFFFFF;
     CheckTable = uDMAControlBaseGet();
     uDMAEnable();
     CheckTable1 = uDMAControlBaseGet();
     uDMAControlBaseSet(pui8ControlTable);//set the pointer to the control table array
     CheckTable2 = uDMAControlBaseGet();
     uDMAChannelAssign(UDMA_CH14_ADC0_0);//DMAChannel 14 is used by ADC0 Sequencer0
     uDMAChannelAssign(UDMA_CH15_ADC0_1);//DMAChannel 15 is used by ADC0 Sequencer1
     uDMAChannelAssign(UDMA_CH24_ADC1_0);//DMAChannel 24 is used by ADC1 Sequencer0
     uDMAChannelAssign(UDMA_CH25_ADC1_1);//DMAChannel 25 is used by ADC1 Sequencer1
     // disable all channel attributes for channel 14,15,24,25
     uDMAChannelAttributeDisable(UDMA_CHANNEL_ADC0, UDMA_ATTR_ALL);
     uDMAChannelAttributeDisable(UDMA_CHANNEL_ADC1, UDMA_ATTR_ALL);
     uDMAChannelAttributeDisable(UDMA_SEC_CHANNEL_ADC10, UDMA_ATTR_ALL);
     uDMAChannelAttributeDisable(UDMA_SEC_CHANNEL_ADC11, UDMA_ATTR_ALL);
     /* enable for channel 14,15,24,25 burst mode->only burst modes will be processed by DMA
      *set the priority to high for channel 14 and 24, channel 15 and 25 will remain as default priority
      *the order of execution if multiple channels request a DMA are dependent on the channel number AND the priority setting, the lower the channel number the more important
      *Priority-List:0=most important,3=least important
      *-0. Channel 14
      *-1. Channel 15
      *-2. Channel 24
      *-3. Channel 25
     uDMAChannelAttributeEnable(UDMA_CHANNEL_ADC0, UDMA_ATTR_USEBURST|UDMA_ATTR_HIGH_PRIORITY);
     uDMAChannelAttributeEnable(UDMA_CHANNEL_ADC1, UDMA_ATTR_USEBURST);
     uDMAChannelAttributeEnable(UDMA_SEC_CHANNEL_ADC10, UDMA_ATTR_USEBURST|UDMA_ATTR_HIGH_PRIORITY);
     uDMAChannelAttributeEnable(UDMA_SEC_CHANNEL_ADC11, UDMA_ATTR_USEBURST);
     /* setup the primary control structure for channel 14,15,24,25
      * a transfer item is 16 bit->UDMA_SIZE_16
      * the sources are the FIFOs of the ADC sequencers, after a value is read from the FIFO this value is poped->UDMA_SRC_INC_NONE
      * the destination array is a uint16 array. each cell is 16 bit->UDMA_DST_INC_16
      * the FIFOs request a DMA transfer if they are half full, for sequencer0 this is after 4 samples and for sequencer1 this is after 2 samples
      * the DMA should therefore always rearbitary after one burst if a higher priority channel requests a transfer-> UDMA_ARB_4 for sequencer 0, UDMA_ARB_2 for sequencer 1
     uDMAChannelControlSet(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT, UDMA_SIZE_16|UDMA_SRC_INC_NONE|UDMA_DST_INC_16|UDMA_ARB_4);
     uDMAChannelControlSet(UDMA_CHANNEL_ADC1|UDMA_PRI_SELECT, UDMA_SIZE_16|UDMA_SRC_INC_NONE|UDMA_DST_INC_16|UDMA_ARB_2);
     uDMAChannelControlSet(UDMA_SEC_CHANNEL_ADC10|UDMA_PRI_SELECT, UDMA_SIZE_16|UDMA_SRC_INC_NONE|UDMA_DST_INC_16|UDMA_ARB_4);
     uDMAChannelControlSet(UDMA_SEC_CHANNEL_ADC11|UDMA_PRI_SELECT, UDMA_SIZE_16|UDMA_SRC_INC_NONE|UDMA_DST_INC_16|UDMA_ARB_2);
     /* setup the alternative control structure for channel 14,15,24,25
      * the same settings as for the primary
     uDMAChannelControlSet(UDMA_CHANNEL_ADC0|UDMA_ALT_SELECT, UDMA_SIZE_16|UDMA_SRC_INC_NONE|UDMA_DST_INC_16|UDMA_ARB_4);
     uDMAChannelControlSet(UDMA_CHANNEL_ADC1|UDMA_ALT_SELECT, UDMA_SIZE_16|UDMA_SRC_INC_NONE|UDMA_DST_INC_16|UDMA_ARB_2);
     uDMAChannelControlSet(UDMA_SEC_CHANNEL_ADC10|UDMA_ALT_SELECT, UDMA_SIZE_16|UDMA_SRC_INC_NONE|UDMA_DST_INC_16|UDMA_ARB_4);
     uDMAChannelControlSet(UDMA_SEC_CHANNEL_ADC11|UDMA_ALT_SELECT, UDMA_SIZE_16|UDMA_SRC_INC_NONE|UDMA_DST_INC_16|UDMA_ARB_2);
     /* set second the primary transfer function active     -> | UDMA_PRI_SELECT
      * Ping-Pong transfer                                  -> UDMA_MODE_PINGPONG
      * source adresses                                     -> FIFO adresse TODO:remove hard coded adresses
      * destination adresses                                -> adress of the first element of the ping buffers
      * number of items (16 bit)                            -> 1024 (WHICH IS THE MAXIMUM VALUE!)
     /* set first the alternative transfer function active  -> | UDMA_ALT_SELECT
      * destination adresses                                -> adress of the first element of the pong buffers
     /*     activate the channels
      *     first transfer is with the primary control structure
int main(void)
    uint32_t ui32Period;
    uint32_t ui32SysClkFreq;
    ui32SysClkFreq = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480), 120000000);
    //enable floating point unite for statistic calculations, only for timing error debugg version required
    FPUEnable();
    //configure the fpu to perform lazy stacking of the fp state
    FPULazyStackingEnable();
    // enable Port N for Led0, Led1
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPION);
    // enable Port E for AIN0,1,2,3,8,9
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
    // enable Port D for AIN4,5,6,7,12,13
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
    // enable Port K for AIN16,17,18,19
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOK);
    // enable Port B for AIN10,11
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
    // enable Timer0 which will trigger ADC0 and ADC1 in synchronized fashion
    SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
    // enable ADC0
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
    // enable ADC1
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC1);
    // enable the DMA, this must be done before the setup routine is called!!!!
    SysCtlPeripheralEnable(SYSCTL_PERIPH_UDMA);
    // set Port E Pin 0 to 5 as analog input for AIN0 to AIN3 and AIN8 and AIN9
    GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_4|GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_5);
    // set Port D Pin 7,6,5,4,3,2,1,0 as analog input for AIN4, AIN5 ,AIN6 ,AIN7 ,AIN12 ,AIN13 ,AIN14 , AIN15
    GPIOPinTypeADC(GPIO_PORTD_BASE, GPIO_PIN_7|GPIO_PIN_6|GPIO_PIN_5|GPIO_PIN_4|GPIO_PIN_3|GPIO_PIN_2|GPIO_PIN_1|GPIO_PIN_0);
    // set Port K Pin 0,1,2,3 as analog input for AIN16, AIN17, AIN18, AIN19
    GPIOPinTypeADC(GPIO_PORTK_BASE, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3);
    // set Port B Pin Pin 4,5 as analog input for AIN12 , AIN13
    GPIOPinTypeADC(GPIO_PORTB_BASE, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3);
    // set Port N Pin 0,1 as output to enable LEDs
    GPIOPinTypeGPIOOutput(GPIO_PORTN_BASE, GPIO_PIN_0|GPIO_PIN_1);
    //set the ADC module frq either to 16MHz(1Megasamples/s) by using the PIOSC
    //or to 32MHz(2Megasamples/s) by using the VCO(@480MHz) and a 15 divider
    //TODO: DOES NOT WORK WITH 32 MHz!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    VJADCClockingSetting(PIOSC16MHZ);
    //uDMAChannelTransferSet(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT, UDMA_MODE_BASIC, 0x40038048, Adc0_FIFO0_UDMA, ResultLength);
    //uDMAChannelTransferSet(UDMA_CHANNEL_ADC1|UDMA_PRI_SELECT, UDMA_MODE_BASIC, 0x40038068, Adc0_FIFO1_UDMA, ResultLength);
    //uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC10|UDMA_PRI_SELECT, UDMA_MODE_BASIC, 0x40039048, Adc1_FIFO0_UDMA, ResultLength);
    //uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC11|UDMA_PRI_SELECT, UDMA_MODE_BASIC, 0x40039068, Adc1_FIFO1_UDMA, ResultLength);
    DMASetup();
    //Configures the 0ths sequencer of ADC0 as triggered by a Timer with highest priority
    //ADC_adress|Sequencer_number|Trigger_source|Priority needs to be between 0 to 3, 0 highest prio; 3 lowest prio
    ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_TIMER, 0);
    ADCSequenceConfigure(ADC0_BASE, 1, ADC_TRIGGER_TIMER, 1);
    ADCSequenceConfigure(ADC1_BASE, 0, ADC_TRIGGER_TIMER, 0);
    ADCSequenceConfigure(ADC1_BASE, 1, ADC_TRIGGER_TIMER, 1);
    //program sequencer 0 of ADC0 to sample AIN0 to AIN7
    ADCSequenceStepConfigure(ADC0_BASE, 0, 0, ADC_CTL_CH0);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 1, ADC_CTL_CH1);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 2, ADC_CTL_CH2);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 3, ADC_CTL_CH3);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 4, ADC_CTL_CH4);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 5, ADC_CTL_CH5);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 6, ADC_CTL_CH6);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 7, ADC_CTL_CH7|ADC_CTL_IE|ADC_CTL_END);
    //program sequencer 1 of ADC0 to sample AIN8 to AIN9
    ADCSequenceStepConfigure(ADC0_BASE, 1, 0, ADC_CTL_CH8);
    ADCSequenceStepConfigure(ADC0_BASE, 1, 1, ADC_CTL_CH9|ADC_CTL_IE|ADC_CTL_END);
    //program sequencer 0 of ADC1 to sample AIN10 to AIN17
    ADCSequenceStepConfigure(ADC1_BASE, 0, 0, ADC_CTL_CH10);
    ADCSequenceStepConfigure(ADC1_BASE, 0, 1, ADC_CTL_CH11);
    ADCSequenceStepConfigure(ADC1_BASE, 0, 2, ADC_CTL_CH12);
    ADCSequenceStepConfigure(ADC1_BASE, 0, 3, ADC_CTL_CH13);
    ADCSequenceStepConfigure(ADC1_BASE, 0, 4, ADC_CTL_CH14);
    ADCSequenceStepConfigure(ADC1_BASE, 0, 5, ADC_CTL_CH15);
    ADCSequenceStepConfigure(ADC1_BASE, 0, 6, ADC_CTL_CH16);
    ADCSequenceStepConfigure(ADC1_BASE, 0, 7, ADC_CTL_CH17|ADC_CTL_IE|ADC_CTL_END);
    //program sequencer 1 of ADC1 to sample AIN0 to AIN7
    ADCSequenceStepConfigure(ADC1_BASE, 1, 0, ADC_CTL_CH18);
    ADCSequenceStepConfigure(ADC1_BASE, 1, 1, ADC_CTL_CH19|ADC_CTL_IE|ADC_CTL_END);
    //enable the adc to generate dma transfer requests
    //enable ADC0sequencer0 to request a dma transfer
    ADCSequenceDMAEnable(ADC0_BASE, 0);
    //enable ADC0sequencer1 to request a dma transfer
    ADCSequenceDMAEnable(ADC0_BASE, 1);
    //enable ADC1sequencer0 to request a dma transfer
    ADCSequenceDMAEnable(ADC1_BASE, 0);
    //enable ADC1sequencer1 to request a dma transfer
    ADCSequenceDMAEnable(ADC1_BASE, 1);
    ADCSequenceEnable(ADC0_BASE, 0);//enable sequencer 0 of ADC0
    ADCSequenceEnable(ADC0_BASE, 1);//enable sequencer 1 of ADC0
    ADCSequenceEnable(ADC1_BASE, 0);//enable sequencer 0 of ADC1
    ADCSequenceEnable(ADC1_BASE, 1);//enable sequencer 0 of ADC1
    TimerConfigure(TIMER0_BASE, TIMER_CFG_PERIODIC);//configure timer0 as a periodic timer
    ui32Period = ui32SysClkFreq/ADCFrq;//calculate number of ticks in order that the timer will trigger the adc in the desired frequency
    TimerLoadSet(TIMER0_BASE, TIMER_A, ui32Period-1);//load the calculated number of ticks into timer0
    TimerControlTrigger(TIMER0_BASE, TIMER_A, true);//enables timer0 to trigger the ADCs
    TimerIntEnable(TIMER0_BASE, TIMER_TIMA_TIMEOUT);//enable the specific interrupt in timer0
    ADCIntEnableEx(ADC0_BASE, ADC_INT_DMA_SS0);//enable the specific sequencer0 interrupt in ADC0
    ADCIntEnableEx(ADC0_BASE, ADC_INT_DMA_SS1);//enable the specific sequencer1 interrupt in ADC0
    ADCIntEnableEx(ADC1_BASE, ADC_INT_DMA_SS0);//enable the specific sequencer0 interrupt in ADC1
    ADCIntEnableEx(ADC1_BASE, ADC_INT_DMA_SS1);//enable the specific sequencer1 interrupt in ADC1
    IntEnable(INT_UDMA);
    IntEnable(INT_UDMAERR);
    IntEnable(INT_TIMER0A);//enable the interrupt for timer0
    IntEnable(INT_ADC0SS0);//enable the interrupt for sequencer0 of ADC0
    IntEnable(INT_ADC0SS1);//enable the interrupt for sequencer1 of ADC0
    IntEnable(INT_ADC1SS0);//enable the interrupt for sequencer0 of ADC1
    IntEnable(INT_ADC1SS1);//enable the interrupt for sequencer0 of ADC0
    IntMasterEnable();//enable global interrupt
    TimerEnable(TIMER0_BASE, TIMER_A);//start timer0
    GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_1, 0);
    while(1)
void uDMAIntHandler(void)
    int vj=0;
    vj++;
void uDMAErrorHandler(void)
    uint32_t ui32Status;
    ui32Status = uDMAErrorStatusGet();
    if(ui32Status)
        uDMAErrorStatusClear();
    switch (ui32Setting)
        case PIOSC16MHZ: //The standard settings, nothing at all needs to be done. The ADC modules will run with 1 Megasample/s
                //Nothing to do here
        break;
        case PLL480MHZTO32MHZ: //The 480 MHZ VCO clock is divided by 15 to provide the ADC with 32MHZ which will result in 2 Megasample/s
            ADCClockConfigSet(ADC0_BASE, ADC_CLOCK_SRC_PLL|ADC_CLOCK_RATE_FULL, 8);
        break;
void Adc0Sequencer0IntHandle(void)
    ADCIntClear(ADC0_BASE,0);
    ADCIntClearEx(ADC0_BASE, ADC_INT_DMA_SS0);
    ADC0SEQUENCER0++;
    DMATransferReEnable(ADC0SS0VJ);
void Adc0Sequencer1IntHandle(void)
    ADCIntClear(ADC0_BASE,1);
    ADCIntClearEx(ADC0_BASE, ADC_INT_DMA_SS1);
    ADC0SEQUENCER1++;
    DMATransferReEnable(ADC0SS1VJ);
void Adc1Sequencer0IntHandle(void)
    ADCIntClear(ADC1_BASE,0);
    ADCIntClearEx(ADC1_BASE, ADC_INT_DMA_SS0);
    ADC1SEQUENCER0++;
    DMATransferReEnable(ADC1SS0VJ);
void Adc1Sequencer1IntHandle(void)
    ADCIntClear(ADC1_BASE,1);
    ADCIntClearEx(ADC1_BASE, ADC_INT_DMA_SS1);
    ADC1SEQUENCER1++;
    DMATransferReEnable(ADC1SS1VJ);
void Timer0IntHandler(void)
    // Clear the timer interrupt
    TimerIntClear(TIMER0_BASE, TIMER_TIMA_TIMEOUT);
    TIMER2++;
    /*float TimingErrorMean[NumberOfAinChannels];
    uint_fast32_t ui32SumOfErrors=0;
    uint_fast32_t i,ii;
    float fSumOfErrors=0;
    for (i=0;i<NumberOfAinChannels;i++)
        ui32SumOfErrors =0;
        fSumOfErrors    =0;
        for (ii=0;ii<ResultLength;ii++)
            ui32SumOfErrors=ui32SumOfErrors+*(AdcResultHandler[i]+ii);
        fSumOfErrors=(float)ui32SumOfErrors;
        TimingErrorMean[i]=fSumOfErrors/ResultLength;
    fSumOfErrors=0;*/
//if an error occurred enable the leds and stay in this function
    GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_1|GPIO_PIN_0, 3);
    IntMasterDisable();
    while(1)
The tranfersize for this code is set to 1024 (the maximum number of items for a uDMA transfer).
Now I wanted to to implement this exact application with the help of TI-RTOS. The ISR's should post a SWI where the DMA channels are checked and the required transfer, either Ping or Pong, are set again if they are finished. The HWIs are working as expected and the SWIs as well. Everything works fine till I set the transfersize for the uDMA transfers to 1024, which is no problem without the TI-RTOS. In order for you guys to comprehend the bug/error here is the same application as above but with TI-RTOS support:
 * Copyright (c) 2015, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== empty_min.c ========
/* XDCtools Header files */
#include <xdc/std.h>
#include <xdc/runtime/System.h>
#include <xdc/cfg/global.h>
#include <xdc/runtime/Log.h>
/* BIOS Header files */
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Swi.h>
/* TI-RTOS Header files */
// #include <ti/drivers/EMAC.h>
#include <ti/drivers/GPIO.h>
// #include <ti/drivers/I2C.h>
// #include <ti/drivers/SDSPI.h>
// #include <ti/drivers/SPI.h>
// #include <ti/drivers/UART.h>
// #include <ti/drivers/USBMSCHFatFs.h>
// #include <ti/drivers/Watchdog.h>
// #include <ti/drivers/WiFi.h>
/* Board Header file */
#include "Board.h"
#include "driverlib/interrupt.h"        //Defines for interrupt and register assignments
/*  Timer Header File */
/*  ADC Header File   */
/* Defines  */
#define VJSYSFRQ                        120000000                                                       //CPU Frequency
#define VJADCSINGLECHANNELRATE          50000                                                           //Sample Rate of a single microphone channel
#define VJNUMOFCHANNELS_SS0             8                                                               //Number of Microphone channels served by AdcXSequencer0
#define VJNUMOFCHANNELS_SS1             2                                                               //Number of Microphone channels served by AdcXSequencer1
#define VJDMATRANSFERSIZE_SS0           1016                                                            //Number of items till a dma channel related to Sequencer 0 will cause an interrupt (AdcXSequencer0 interrupt)
//In order that the samples of the 2 channels sampled by Sequencer1 are sent at the same time as the 8 sampled by Sequencer 1 the corresponding dma channel needs only to transfer 1/4th of the items of Sequencer0
#define VJDMATRANSFERSIZE_SS1           (VJDMATRANSFERSIZE_SS0/VJNUMOFCHANNELS_SS0)*VJNUMOFCHANNELS_SS1 //Number of items till a dma channel related to Sequencer 0 will cause an interrupt (AdcXSequencer1 interrupt)
#define VJNUMOFSAMPLEPERTRANSFER        VJDMATRANSFERSIZE_SS0/VJNUMOFCHANNELS_SS0                       //Number of samples of one microphone channel in a single dma transfer
 * Prototypes
void VJ_initAnalogInputs(void);
void VJ_initADC0WithOutDMA(void);
void VJ_initADC1WithOutDMA(void);
void VJ_initADC0WithDMA(void);
void VJ_initADC1WithDMA(void);
void VJ_initTimer2ForADC(uint32_t ui32SysClkFreq);
void ISR_Timer2(void);
void ISR_Adc1Sequencer1(void);
void ISR_Adc1Sequencer0(void);
void ISR_Adc0Sequencer1(void);
void ISR_Adc0Sequencer0(void);
void VJ_initDMATransForADC1SS1(void);
void VJ_initDMATransForADC1SS0(void);
void VJ_initDMATransForADC0SS1(void);
void VJ_initDMATransForADC0SS0(void);
void SWI_Adc0Sequencer0(void);
void SWI_Adc0Sequencer1(void);
void SWI_Adc1Sequencer0(void);
void SWI_Adc1Sequencer1(void);
/* Debug Variable */
/* DMA Memory */
uint16_t Adc0_FIFO0_UDMA_A[VJDMATRANSFERSIZE_SS0];
uint16_t Adc0_FIFO1_UDMA_A[VJDMATRANSFERSIZE_SS1];
uint16_t Adc1_FIFO0_UDMA_A[VJDMATRANSFERSIZE_SS0];
uint16_t Adc1_FIFO1_UDMA_A[VJDMATRANSFERSIZE_SS1];
uint16_t Adc0_FIFO0_UDMA_B[VJDMATRANSFERSIZE_SS0];
uint16_t Adc0_FIFO1_UDMA_B[VJDMATRANSFERSIZE_SS1];
uint16_t Adc1_FIFO0_UDMA_B[VJDMATRANSFERSIZE_SS0];
uint16_t Adc1_FIFO1_UDMA_B[VJDMATRANSFERSIZE_SS1];
/*  VJ_initAnalogInputs: put all 20 required pins to analog pins
 *        |     0      |     1       |     2       |     3       |     4      |     5      |     6      |     7
 *  Port E: Pin0->AIN0 , Pin1->AIN1  , Pin2->AIN2  , Pin3->AIN3  , Pin4->AIN8 , Pin5->AIN9
 *  Port D: Pin0->AIN15, Pin1->AIN14 , Pin2->AIN13 , Pin3->AIN12 , Pin4->AIN7 , Pin5->AIN6 , Pin6->AIN5 , Pin7->AIN4
 *  Port K: Pin0->AIN16, Pin1->AIN17 , Pin2->AIN18 , Pin3->AIN19
 *  Port B:                                                        Pin4->AIN12, Pin5->AIN13
    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOE))
    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOD))
    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOK))
    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOB))
    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_ADC0))
    ADCIntEnable(ADC0_BASE, 0);
    ADCIntEnable(ADC0_BASE, 1);
    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_ADC1))
    ADCIntEnable(ADC1_BASE, 0);
    ADCIntEnable(ADC1_BASE, 1);
    IntEnable(INT_ADC1SS1);//enable the interrupt for sequencer1 of ADC0
    //Configures the 0ths sequencer of ADC1 as triggered by a Timer with highest priority
    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_UDMA))
    CheckTable=uDMAControlBaseGet();
    if(CheckTable==0|CheckTable==0xFFFFFFFF)
        while(1)
     *-0. Channel 14
     *-1. Channel 15
     *-2. Channel 24
     *-3. Channel 25
    /* set second the primary transfer function active     -> | UDMA_ALT_SELECT
    uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC11|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40039068, Adc1_FIFO1_UDMA_B, VJDMATRANSFERSIZE_SS1);
    uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC11|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40039068, Adc1_FIFO1_UDMA_A, VJDMATRANSFERSIZE_SS1);
        while(1)
     *-0. Channel 14
     *-1. Channel 15
     *-2. Channel 24
     *-3. Channel 25
    uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC10|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40039048, Adc1_FIFO0_UDMA_A, VJDMATRANSFERSIZE_SS0);
    uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC10|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40039048, Adc1_FIFO0_UDMA_B, VJDMATRANSFERSIZE_SS0);
        while(1)
     *-0. Channel 14
     *-1. Channel 15
     *-2. Channel 24
     *-3. Channel 25
    uDMAChannelTransferSet(UDMA_CHANNEL_ADC1|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40038068, Adc0_FIFO1_UDMA_A, VJDMATRANSFERSIZE_SS1);
    uDMAChannelTransferSet(UDMA_CHANNEL_ADC1|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40038068, Adc0_FIFO1_UDMA_B, VJDMATRANSFERSIZE_SS1);
       while(1)
     uDMAChannelAttributeDisable(UDMA_CHANNEL_ADC0, UDMA_ATTR_ALL);//TODO:DEBUG burst channel disabled
      *-0. Channel 14
      *-1. Channel 15
      *-2. Channel 24
      *-3. Channel 25
     uDMAChannelTransferSet(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40038048, Adc0_FIFO0_UDMA_A, VJDMATRANSFERSIZE_SS0);
     uDMAChannelTransferSet(UDMA_CHANNEL_ADC0|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40038048, Adc0_FIFO0_UDMA_B, VJDMATRANSFERSIZE_SS0);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER2);
    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_TIMER2))
    uint32_t ui32Period = ui32SysClkFreq/VJADCSINGLECHANNELRATE;
    TimerConfigure(TIMER2_BASE, TIMER_CFG_PERIODIC);//configure timer2 as a periodic timer
    TimerLoadSet(TIMER2_BASE, TIMER_A, ui32Period-1);//load the calculated number of ticks into timer0
    TimerControlTrigger(TIMER2_BASE, TIMER_A, true);//enables timer2 to trigger the ADCs
    TimerIntEnable(TIMER2_BASE, TIMER_TIMA_TIMEOUT);//enable the specific interrupt in timer0
    TimerEnable(TIMER2_BASE, TIMER_A);
    ADCIntClear(ADC0_BASE,0);//TODO:Under- and Overflowcheck
    Swi_post(Adc0Sequencer0);
    ADC0SEQUENCER0++;
    ADCIntClear(ADC0_BASE,1);//TODO:Under- and Overflowcheck
    Swi_post(Adc0Sequencer1);
    ADC0SEQUENCER1++;
    ADCIntClear(ADC1_BASE,0);//TODO:Under- and Overflowcheck
    Swi_post(Adc1Sequencer0);
    ADC1SEQUENCER0++;
    ADCIntClear(ADC1_BASE,1);//TODO:Under- and Overflowcheck
    Swi_post(Adc1Sequencer1);
    ADC1SEQUENCER1++;
    TimerIntClear(TIMER2_BASE, TIMER_TIMA_TIMEOUT);
    TIMER2++;
    DebugPrint=(TIMER2%(VJNUMOFSAMPLEPERTRANSFER));
    switch (DebugPrint)
        case 0:
            Log_info5("HWI        !!! Timer2: [%u]| Adc0Sequencer0  : [%u] | Adc0Sequencer1  : [%u] | Adc1Sequencer0  : [%u] | Adc1Sequencer1  : [%u] ",TIMER2,ADC0SEQUENCER0,ADC0SEQUENCER1,ADC1SEQUENCER0,ADC1SEQUENCER1);
            break;
        case 1:
            Log_info5("SWI        !!! Timer2: [%u]| Adc0Sequencer0_A: [%u] | Adc0Sequencer1_A: [%u] | Adc1Sequencer0_A: [%u] | Adc1Sequencer1_A: [%u] ",TIMER2,ADC0Sequencer0SWI_A,ADC0Sequencer1SWI_A,ADC1Sequencer0SWI_A,ADC1Sequencer1SWI_A);
            break;
        case 2:
            Log_info5("SWI        !!! Timer2: [%u]| Adc0Sequencer0_B: [%u] | Adc0Sequencer1_B: [%u] | Adc1Sequencer0_B: [%u] | Adc1Sequencer1_B: [%u] ",TIMER2,ADC0Sequencer0SWI_B,ADC0Sequencer1SWI_B,ADC1Sequencer0SWI_B,ADC1Sequencer1SWI_B);
            break;
        case 3:
            Log_info5("DMA Enables!!! Timer2: [%u]| Adc0Sequencer0: [%u]   | Adc0Sequencer1:   [%u] | Adc1Sequencer0  : [%u] | Adc1Sequencer1  : [%u] ",TIMER2,ADC0Sequencer0SWI  ,ADC0Sequencer1SWI  ,ADC1Sequencer0SWI  ,ADC1Sequencer1SWI  );
            break;
    if(!uDMAChannelIsEnabled(UDMA_CHANNEL_ADC0))
   if(!uDMAChannelIsEnabled(UDMA_CHANNEL_ADC1))
    if(!uDMAChannelIsEnabled(UDMA_SEC_CHANNEL_ADC10))
    if(!uDMAChannelIsEnabled(UDMA_SEC_CHANNEL_ADC11))
 *  ======== main ========
int main(void)
    uint32_t ui32SysClkFreq = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480), VJSYSFRQ);
    /* Call board init functions */
    Board_initGeneral();
    EK_TM4C129EXL_initDMA();
    // Board_initEMAC();
    Board_initGPIO();
    // Board_initI2C();
    // Board_initSDSPI();
    // Board_initSPI();
    // Board_initUART();
    // Board_initUSB(Board_USBDEVICE);
    // Board_initUSBMSCHFatFs();
    // Board_initWatchdog();
    // Board_initWiFi();
    VJ_initAnalogInputs();
    VJ_initADC0WithDMA();
    //VJ_initADC0WithOutDMA();
    VJ_initDMATransForADC0SS0();
    VJ_initDMATransForADC0SS1();
    //VJ_initADC1WithOutDMA();
    VJ_initADC1WithDMA();
    VJ_initDMATransForADC1SS0();
    VJ_initDMATransForADC1SS1();
    VJ_initTimer2ForADC(ui32SysClkFreq);
    /* Start BIOS */
    BIOS_start();
    return (0);
  At the moment the transfersize is set to 1016 which works perfectly fine (I also tried 1023 which works as well). With the define
the transfersize can be changed. In order to debug the application the application increments debug variables and print them to a log every 1016 timer2 interrupts.
My TI-RTOS settings (.cfg) are the following:
 * Copyright (c) 2015-2016, Texas Instruments Incorporated
 * are met:
/* ================ Clock configuration ================ */
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
 * Default value is family dependent. For example, Linux systems often only
 * support a minimum period of 10000 us and multiples of 10000 us.
 * TI platforms have a default of 1000 us.
Clock.tickPeriod = 1000;
/* ================ Defaults (module) configuration ================ */
var Defaults = xdc.useModule('xdc.runtime.Defaults');
 * A flag to allow module names to be loaded on the target. Module name
 * strings are placed in the .const section for debugging purposes.
 * Pick one:
 *  - true (default)
 *      Setting this parameter to true will include name strings in the .const
 *      section so that Errors and Asserts are easier to debug.
 *  - false
 *      Setting this parameter to false will reduce footprint in the .const
 *      section. As a result, Error and Assert messages will contain an
 *      "unknown module" prefix instead of the actual module name.
Defaults.common$.namedModule = true;
//Defaults.common$.namedModule = false;
/* ================ Error configuration ================ */
var Error = xdc.useModule('xdc.runtime.Error');
 * This function is called to handle all raised errors, but unlike
 * Error.raiseHook, this function is responsible for completely handling the
 * error with an appropriately initialized Error_Block.
 * Pick one:
 *  - Error.policyDefault (default)
 *      Calls Error.raiseHook with an initialized Error_Block structure and logs
 *      the error using the module's logger.
 *  - Error.policySpin
 *      Simple alternative that traps on a while(1) loop for minimized target
 *      footprint.
 *      Using Error.policySpin, the Error.raiseHook will NOT called.
Error.policyFxn = Error.policyDefault;
//Error.policyFxn = Error.policySpin;
 * If Error.policyFxn is set to Error.policyDefault, this function is called
 * whenever an error is raised by the Error module.
 * Pick one:
 *  - Error.print (default)
 *      Errors are formatted and output via System_printf() for easier
 *      debugging.
 *  - null
 *      Errors are not formatted or logged. This option reduces code footprint.
 *  - non-null function
 *      Errors invoke custom user function. See the Error module documentation
 *      for more details.
Error.raiseHook = Error.print;
//Error.raiseHook = null;
//Error.raiseHook = "&myErrorFxn";
 * If Error.policyFxn is set to Error.policyDefault, this option applies to the
 * maximum number of times the Error.raiseHook function can be recursively
 * invoked. This option limits the possibility of an infinite recursion that
 * could lead to a stack overflow.
 * The default value is 16.
Error.maxDepth = 2;
/* ================ Hwi configuration ================ */
var halHwi = xdc.useModule('ti.sysbios.hal.Hwi');
var m3Hwi = xdc.useModule('ti.sysbios.family.arm.m3.Hwi');
 * Checks for Hwi (system) stack overruns while in the Idle loop.
 * Pick one:
 *  - true (default)
 *      Checks the top word for system stack overflows during the idle loop and
 *      raises an Error if one is detected.
 *  - false
 *      Disabling the runtime check improves runtime performance and yields a
 *      reduced flash footprint.
//halHwi.checkStackFlag = true;
halHwi.checkStackFlag = false;
 * The following options alter the system's behavior when a hardware exception
 * is detected.
 * Pick one:
 *  - Hwi.enableException = true
 *      This option causes the default m3Hwi.excHandlerFunc function to fully
 *      decode an exception and dump the registers to the system console.
 *      This option raises errors in the Error module and displays the
 *      exception in ROV.
 *  - Hwi.enableException = false
 *      This option reduces code footprint by not decoding or printing the
 *      exception to the system console.
 *      It however still raises errors in the Error module and displays the
 *      exception in ROV.
 *  - Hwi.excHandlerFunc = null
 *      This is the most aggressive option for code footprint savings; but it
 *      can difficult to debug exceptions. It reduces flash footprint by
 *      plugging in a default while(1) trap when exception occur. This option
 *      does not raise an error with the Error module.
m3Hwi.enableException = true;
//m3Hwi.enableException = false;
//m3Hwi.excHandlerFunc = null;
 * Enable hardware exception generation when dividing by zero.
 * Pick one:
 *  - 0 (default)
 *      Disables hardware exceptions when dividing by zero
 *  - 1
 *      Enables hardware exceptions when dividing by zero
m3Hwi.nvicCCR.DIV_0_TRP = 0;
//m3Hwi.nvicCCR.DIV_0_TRP = 1;
 * Enable hardware exception generation for invalid data alignment.
 * Pick one:
 *  - 0 (default)
 *      Disables hardware exceptions for data alignment
 *  - 1
 *      Enables hardware exceptions for data alignment
m3Hwi.nvicCCR.UNALIGN_TRP = 0;
//m3Hwi.nvicCCR.UNALIGN_TRP = 1;
/* ================ Idle configuration ================ */
var Idle = xdc.useModule('ti.sysbios.knl.Idle');
 * The Idle module is used to specify a list of functions to be called when no
 * other tasks are running in the system.
 * Functions added here will be run continuously within the idle task.
 * Function signature:
 *     Void func(Void);
//Idle.addFunc("&myIdleFunc");
/* ================ Kernel (SYS/BIOS) configuration ================ */
var BIOS = xdc.useModule('ti.sysbios.BIOS');
 * Enable asserts in the BIOS library.
 * Pick one:
 *  - true (default)
 *      Enables asserts for debugging purposes.
 *  - false
 *      Disables asserts for a reduced code footprint and better performance.
//BIOS.assertsEnabled = true;
 * Specify default heap size for BIOS.
BIOS.heapSize = 512;
 * A flag to determine if xdc.runtime sources are to be included in a custom
 * built BIOS library.
 * Pick one:
 *  - false (default)
 *      The pre-built xdc.runtime library is provided by the respective target
 *      used to build the application.
 *  - true
 *      xdc.runtime library sources are to be included in the custom BIOS
 *      library. This option yields the most efficient library in both code
 *      footprint and runtime performance.
BIOS.includeXdcRuntime = false;
//BIOS.includeXdcRuntime = true;
 * The SYS/BIOS runtime is provided in the form of a library that is linked
 * with the application. Several forms of this library are provided with the
 * SYS/BIOS product.
 * Pick one:
 *   - BIOS.LibType_Custom
 *      Custom built library that is highly optimized for code footprint and
 *      runtime performance.
 *   - BIOS.LibType_Debug
 *      Custom built library that is non-optimized that can be used to
 *      single-step through APIs with a debugger.
BIOS.libType = BIOS.LibType_Custom;
//BIOS.libType = BIOS.LibType_Debug;
 * Runtime instance creation enable flag.
 * Pick one:
 *   - true (default)
 *      Allows Mod_create() and Mod_delete() to be called at runtime which
 *      requires a default heap for dynamic memory allocation.
 *   - false
 *      Reduces code footprint by disallowing Mod_create() and Mod_delete() to
 *      be called at runtime. Object instances are constructed via
 *      Mod_construct() and destructed via Mod_destruct().
BIOS.runtimeCreatesEnabled = true;
//BIOS.runtimeCreatesEnabled = false;
 * Enable logs in the BIOS library.
 * Pick one:
 *  - true (default)
 *      Enables logs for debugging purposes.
 *  - false
 *      Disables logging for reduced code footprint and improved runtime
 *      performance.
//BIOS.logsEnabled = true;
/* ================ Memory configuration ================ */
var Memory = xdc.useModule('xdc.runtime.Memory');
 * The Memory module itself simply provides a common interface for any
 * variety of system and application specific memory management policies
 * implemented by the IHeap modules(Ex. HeapMem, HeapBuf).
/* ================ Program configuration ================ */
 *  Program.stack is ignored with IAR. Use the project options in
 *  IAR Embedded Workbench to alter the system stack size.
if (!Program.build.target.$name.match(/iar/)) {
     *  Reducing the system stack size (used by ISRs and Swis) to reduce
     *  RAM usage.
Program.stack = 1024;
 * Enable Semihosting for GNU targets to print to CCS console
if (Program.build.target.$name.match(/gnu/)) {
    var SemiHost = xdc.useModule('ti.sysbios.rts.gnu.SemiHostSupport');
/* ================ Semaphore configuration ================ */
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
 * Enables global support for Task priority pend queuing.
 * Pick one:
 *  - true (default)
 *      This allows pending tasks to be serviced based on their task priority.
 *  - false
 *      Pending tasks are services based on first in, first out basis.
 *  When using BIOS in ROM:
 *      This option must be set to false.
//Semaphore.supportsPriority = true;
Semaphore.supportsPriority = false;
 * Allows for the implicit posting of events through the semaphore,
 * disable for additional code saving.
 * Pick one:
 *  - true
 *      This allows the Semaphore module to post semaphores and events
 *      simultaneously.
 *  - false (default)
 *      Events must be explicitly posted to unblock tasks.
//Semaphore.supportsEvents = true;
Semaphore.supportsEvents = false;
/* ================ Swi configuration ================ */
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
 * A software interrupt is an object that encapsulates a function to be
 * executed and a priority. Software interrupts are prioritized, preempt tasks
 * and are preempted by hardware interrupt service routines.
 * This module is included to allow Swi's in a users' application.
/* ================ System configuration ================ */
var System = xdc.useModule('xdc.runtime.System');
 * The Abort handler is called when the system exits abnormally.
 * Pick one:
 *  - System.abortStd (default)
 *      Call the ANSI C Standard 'abort()' to terminate the application.
 *  - System.abortSpin
 *      A lightweight abort function that loops indefinitely in a while(1) trap
 *      function.
 *  - A custom abort handler
 *      A user-defined function. See the System module documentation for
 *      details.
System.abortFxn = System.abortStd;
//System.abortFxn = System.abortSpin;
//System.abortFxn = "&myAbortSystem";
 * The Exit handler is called when the system exits normally.
 * Pick one:
 *  - System.exitStd (default)
 *      Call the ANSI C Standard 'exit()' to terminate the application.
 *  - System.exitSpin
 *      A lightweight exit function that loops indefinitely in a while(1) trap
 *      function.
 *  - A custom exit function
 *      details.
System.exitFxn = System.exitStd;
//System.exitFxn = System.exitSpin;
//System.exitFxn = "&myExitSystem";
 * Minimize exit handler array in the System module. The System module includes
 * an array of functions that are registered with System_atexit() which is
 * called by System_exit(). The default value is 8.
System.maxAtexitHandlers = 2;
 * The System.SupportProxy defines a low-level implementation of System
 * functions such as System_printf(), System_flush(), etc.
 * Pick one pair:
 *  - SysMin
 *      This module maintains an internal configurable circular buffer that
 *      stores the output until System_flush() is called.
 *      The size of the circular buffer is set via SysMin.bufSize.
 *  - SysCallback
 *      SysCallback allows for user-defined implementations for System APIs.
 *      The SysCallback support proxy has a smaller code footprint and can be
 *      used to supply custom System_printf services.
 *      The default SysCallback functions point to stub functions. See the
 *      SysCallback module's documentation.
var SysMin = xdc.useModule('xdc.runtime.SysMin');
SysMin.bufSize = 128;
System.SupportProxy = SysMin;
//var SysCallback = xdc.useModule('xdc.runtime.SysCallback');
//System.SupportProxy = SysCallback;
//SysCallback.abortFxn = "&myUserAbort";
//SysCallback.exitFxn  = "&myUserExit";
//SysCallback.flushFxn = "&myUserFlush";
//SysCallback.putchFxn = "&myUserPutch";
//SysCallback.readyFxn = "&myUserReady";
/* ================ Task configuration ================ */
var Task = xdc.useModule('ti.sysbios.knl.Task');
 * Check task stacks for overflow conditions.
 * Pick one:
 *  - true (default)
 *      Enables runtime checks for task stack overflow conditions during
 *      context switching ("from" and "to")
 *  - false
 *      Disables runtime checks for task stack overflow conditions.
//Task.checkStackFlag = true;
Task.checkStackFlag = false;
 * Set the default task stack size when creating tasks.
 * The default is dependent on the device being used. Reducing the default stack
 * size yields greater memory savings.
Task.defaultStackSize = 512;
 * Enables the idle task.
 * Pick one:
 *  - true (default)
 *      Creates a task with priority of 0 which calls idle hook functions. This
 *      option must be set to true to gain power savings provided by the Power
 *      module.
 *  - false
 *      No idle task is created. This option consumes less memory as no
 *      additional default task stack is needed.
 *      To gain power savings by the Power module without having the idle task,
 *      add Idle.run as the Task.allBlockedFunc.
//Task.enableIdleTask = true;
Task.enableIdleTask = false;
//Task.allBlockedFunc = Idle.run;
 * If Task.enableIdleTask is set to true, this option sets the idle task's
 * stack size.
 * Reducing the idle stack size yields greater memory savings.
Task.idleTaskStackSize = 512;
 * Reduce the number of task priorities.
 * The default is 16.
 * Decreasing the number of task priorities yield memory savings.
Task.numPriorities = 16;
 * Idle Function list.
 * Functions added here will be run continously within the idle task.
 *     Void func(Void);
/* ================ Text configuration ================ */
var Text = xdc.useModule('xdc.runtime.Text');
 * These strings are placed in the .const section. Setting this parameter to
 * false will save space in the .const section. Error, Assert and Log messages
 * will print raw ids and args instead of a formatted message.
 * Pick one:
 *  - true (default)
 *      This option loads test string into the .const for easier debugging.
 *  - false
 *      This option reduces the .const footprint.
Text.isLoaded = true;
//Text.isLoaded = false;
/* ================ Types configuration ================ */
var Types = xdc.useModule('xdc.runtime.Types');
 * This module defines basic constants and types used throughout the
 * xdc.runtime package.
/* ================ TI-RTOS middleware configuration ================ */
var mwConfig = xdc.useModule('ti.mw.Config');
 * Include TI-RTOS middleware libraries
/* ================ TI-RTOS drivers' configuration ================ */
var driversConfig = xdc.useModule('ti.drivers.Config');
 * Include TI-RTOS drivers
 * Pick one:
 *  - driversConfig.LibType_NonInstrumented (default)
 *      Use TI-RTOS drivers library optimized for footprint and performance
 *      without asserts or logs.
 *  - driversConfig.LibType_Instrumented
 *      Use TI-RTOS drivers library for debugging with asserts and logs enabled.
driversConfig.libType = driversConfig.LibType_NonInstrumented;
//driversConfig.libType = driversConfig.LibType_Instrumented;
/* ================ Application Specific Instances ================ */
var m3Hwi0Params = new m3Hwi.Params();
m3Hwi0Params.instance.name = "HwiHandle_Timer2";
m3Hwi0Params.priority = 0;
Program.global.HwiHandle_Timer2 = m3Hwi.create(39, "&ISR_Timer2", m3Hwi0Params);
LoggingSetup.sysbiosSwiLogging = false;
LoggingSetup.sysbiosHwiLogging = false;
var m3Hwi1Params = new m3Hwi.Params();
m3Hwi1Params.instance.name = "HwiHandle_Adc0Sequencer0";
m3Hwi1Params.priority = 1;
Program.global.HwiHandle_Adc0Sequencer0 = m3Hwi.create(30, "&ISR_Adc0Sequencer0", m3Hwi1Params);
var m3Hwi2Params = new m3Hwi.Params();
m3Hwi2Params.instance.name = "HwiHandle_Adc0Sequencer1";
m3Hwi2Params.priority = 1;
Program.global.HwiHandle_Adc0Sequencer1 = m3Hwi.create(31, "&ISR_Adc0Sequencer1", m3Hwi2Params);
var m3Hwi3Params = new m3Hwi.Params();
m3Hwi3Params.instance.name = "HwiHandle_Adc1Sequencer0";
m3Hwi3Params.priority = 1;
Program.global.HwiHandle_Adc1Sequencer0 = m3Hwi.create(62, "&ISR_Adc1Sequencer0", m3Hwi3Params);
var m3Hwi4Params = new m3Hwi.Params();
m3Hwi4Params.instance.name = "HwiHandle_Adc1Sequencer1";
m3Hwi4Params.priority = 1;
Program.global.HwiHandle_Adc1Sequencer1 = m3Hwi.create(63, "&ISR_Adc1Sequencer1", m3Hwi4Params);
m3Hwi.dispatcherAutoNestingSupport = false;
var swi0Params = new Swi.Params();
swi0Params.instance.name = "Adc0Sequencer0";
swi0Params.priority = 0;
Program.global.Adc0Sequencer0 = Swi.create("&SWI_Adc0Sequencer0", swi0Params);
var swi1Params = new Swi.Params();
swi1Params.instance.name = "Adc0Sequencer1";
swi1Params.priority = 0;
Program.global.Adc0Sequencer1 = Swi.create("&SWI_Adc0Sequencer1", swi1Params);
LoggingSetup.loadTaskLogging = false;
LoggingSetup.loadSwiLogging = false;
LoggingSetup.loadHwiLogging = true;
LoggingSetup.enableTaskProfiler = false;
LoggingSetup.loadLoggerSize = 1024;
LoggingSetup.mainLoggerSize = 2048;
var swi2Params = new Swi.Params();
swi2Params.instance.name = "Adc1Sequencer0";
swi2Params.priority = 0;
Program.global.Adc1Sequencer0 = Swi.create("&SWI_Adc1Sequencer0", swi2Params);
var swi3Params = new Swi.Params();
swi3Params.instance.name = "Adc1Sequencer1";
swi3Params.priority = 0;
Program.global.Adc1Sequencer1 = Swi.create("&SWI_Adc1Sequencer1", swi3Params);
If you know what I did wrong please let me know, also if its a common bug, ( I allready tried to search for it). I am also gratefull on any tipps on how to debug this strange behavior.
Best greetings,
Richard
  • Hi Richard,
    When you say the TI-RTOS based one does not work when the size is set to 1024, what happens? Also, can you place the DMA buffers on a 4 byte boundary (via a #pragma or making them an int32_t). I thought they needed to be on a 32-bit boundary...I should confirm, but it's an easy test:)
    Todd
  • Hi Todd,
    thanks for the fast replie. Unfortunatly I am not at work anymore and can't try to align the buffers till tomorrow. But if that would be the problem shouldn't it be a problem without the TI-RTOS as well?
    But I can describe the error a little more. The error effect is actually really strange. Almost no other ISRs are entered by the CPU exept the ISRs for the ADC0 Sequencer0 and ADC0 Sequencer1. I derive this behavior because the program increment for every ISR and every SWI a counter. If I let the program run for a little bit the counter for all ISRs and SWIs are very low, but not all the same. I couldn't find any pattern in how often an ISR or SWI is entered besides the ADC0 Sequencer0 and ADC0 Sequencer1 ISR, so i assumed it's random.
    Richard
  • Hi Todd,
    I aligned the memory to 4 byte addresses but it still didn't work. The source code I used is the following:
    #pragma DATA_ALIGN(Adc0_FIFO0_UDMA_A, 4)
    #pragma DATA_ALIGN(Adc0_FIFO1_UDMA_A, 4)
    #pragma DATA_ALIGN(Adc1_FIFO0_UDMA_A, 4)
    #pragma DATA_ALIGN(Adc1_FIFO1_UDMA_A, 4)
    #pragma DATA_ALIGN(Adc0_FIFO0_UDMA_B, 4)
    #pragma DATA_ALIGN(Adc0_FIFO1_UDMA_B, 4)
    #pragma DATA_ALIGN(Adc1_FIFO0_UDMA_B, 4)
    #pragma DATA_ALIGN(Adc1_FIFO1_UDMA_B, 4)
    However I needed to proceed with my work and changed my memory management more to a way how I imagen the final programm should run. I allocate a whole block of memory and split this block into 8 memory blocks. In that way the arrays are in a consecutivley order. And it turned out that this is the solution to the problem. Here is the corresponding source code:
     * are met:
    #include "Board.h"
    /* Defines  */
    #define VJDMATRANSFERSIZE_SS0           1024                                                            //Number of items till a dma channel related to Sequencer 0 will cause an interrupt (AdcXSequencer0 interrupt)
    /* Addresses of the FIFOs of the AdcXSequencerY */
    #define VJADC0SS0FIFOADDRESS            0x40038048
    #define VJADC0SS1FIFOADDRESS            0x40038068
    #define VJADC1SS0FIFOADDRESS            0x40039048
    #define VJADC1SS1FIFOADDRESS            0x40039068
     * Prototypes
    void VJ_initMemoryForDma(void);
    /* DMA Memory */
     * First allocate the overall required memory, so the memory will be in a single block
     * Sequencer0 writes VJDMATRANSFERSIZE_SS0                         items to memory
     * Sequencer1 writes VJDMATRANSFERSIZE_SS0/4=VJDMATRANSFERSIZE_SS1 items to memory
     * for each adc there is 1 Sequencer0 and 1 Sequencer1, both with an A and B buffer
     * Therefore the required array length equals: ADC0Sequencer0_A_Buffer->VJDMATRANSFERSIZE_SS0
     *                                            +ADC0Sequencer0_B_Buffer->VJDMATRANSFERSIZE_SS0
     *                                            +ADC1Sequencer0_A_Buffer->VJDMATRANSFERSIZE_SS0
     *                                            +ADC1Sequencer0_B_Buffer->VJDMATRANSFERSIZE_SS0
     *                                            +ADC0Sequencer1_A_Buffer->VJDMATRANSFERSIZE_SS1
     *                                            +ADC0Sequencer1_B_Buffer->VJDMATRANSFERSIZE_SS1
     *                                            +ADC1Sequencer1_A_Buffer->VJDMATRANSFERSIZE_SS1
     *                                            +ADC1Sequencer1_B_Buffer->VJDMATRANSFERSIZE_SS1
     *                                            =4*VJDMATRANSFERSIZE_SS0+4*VJDMATRANSFERSIZE_SS1
    uint16_t *p_u16_A_Memory, *p_u16_B_Memory, *p_u16_Adc0_Ss0_Udma_A, *p_u16_Adc1_Ss0_Udma_A,
             *p_u16_Adc0_Ss1_Udma_A, *p_u16_Adc1_Ss1_Udma_A, *p_u16_Adc0_Ss0_Udma_B, *p_u16_Adc1_Ss0_Udma_B,
             *p_u16_Adc0_Ss1_Udma_B, *p_u16_Adc1_Ss1_Udma_B;
    #pragma DATA_ALIGN(p_u16_AB_Memory, 4)
    uint16_t p_u16_AB_Memory[4*VJDMATRANSFERSIZE_SS0+4*VJDMATRANSFERSIZE_SS1];
         * Split the whole memory block into 2: p_u16_A_Memory->A_Buffer of length 2*VJDMATRANSFERSIZE_SS0+2*VJDMATRANSFERSIZE_SS1
         *                                      p_u16_B_Memory->B_Buffer of length 2*VJDMATRANSFERSIZE_SS0+2*VJDMATRANSFERSIZE_SS1
        p_u16_A_Memory=&(p_u16_AB_Memory[0]);
        p_u16_B_Memory=&p_u16_AB_Memory[2*VJDMATRANSFERSIZE_SS0+2*VJDMATRANSFERSIZE_SS1];
         * Split the A_Buffer into 4 memories: p_u16_Adc0_Ss0_Udma_A->A_Buffer for Adc0Sequencer0 of length VJDMATRANSFERSIZE_SS0
         *                                     p_u16_Adc1_Ss0_Udma_A->A_Buffer for Adc1Sequencer0 of length VJDMATRANSFERSIZE_SS0
         *                                     p_u16_Adc0_Ss1_Udma_A->A_Buffer for Adc0Sequencer1 of length VJDMATRANSFERSIZE_SS1
         *                                     p_u16_Adc1_Ss1_Udma_A->A_Buffer for Adc1Sequencer1 of length VJDMATRANSFERSIZE_SS1
        p_u16_Adc0_Ss0_Udma_A=&(p_u16_A_Memory[0]);
        p_u16_Adc1_Ss0_Udma_A=&(p_u16_A_Memory[VJDMATRANSFERSIZE_SS0]);
        p_u16_Adc0_Ss1_Udma_A=&(p_u16_A_Memory[2*VJDMATRANSFERSIZE_SS0]);
        p_u16_Adc1_Ss1_Udma_A=&(p_u16_A_Memory[2*VJDMATRANSFERSIZE_SS0+VJDMATRANSFERSIZE_SS1]);
         * Split the B_Buffer into 4 memories: p_u16_Adc0_Ss0_Udma_B->B_Buffer for Adc0Sequencer0 of length VJDMATRANSFERSIZE_SS0
         *                                     p_u16_Adc1_Ss0_Udma_B->B_Buffer for Adc1Sequencer0 of length VJDMATRANSFERSIZE_SS0
         *                                     p_u16_Adc0_Ss1_Udma_B->B_Buffer for Adc0Sequencer1 of length VJDMATRANSFERSIZE_SS1
         *                                     p_u16_Adc1_Ss1_Udma_B->B_Buffer for Adc1Sequencer1 of length VJDMATRANSFERSIZE_SS1
        p_u16_Adc0_Ss0_Udma_B=&(p_u16_B_Memory[0]);
        p_u16_Adc1_Ss0_Udma_B=&(p_u16_B_Memory[VJDMATRANSFERSIZE_SS0]);
        p_u16_Adc0_Ss1_Udma_B=&(p_u16_B_Memory[2*VJDMATRANSFERSIZE_SS0]);
        p_u16_Adc1_Ss1_Udma_B=&(p_u16_B_Memory[2*VJDMATRANSFERSIZE_SS0+VJDMATRANSFERSIZE_SS1]);
            while(1)
         *-0. Channel 14
         *-1. Channel 15
         *-2. Channel 24
         *-3. Channel 25
        uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC11|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40039068, p_u16_Adc1_Ss1_Udma_B, VJDMATRANSFERSIZE_SS1);
        uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC11|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40039068, p_u16_Adc1_Ss1_Udma_A, VJDMATRANSFERSIZE_SS1);
            while(1)
         *-0. Channel 14
         *-1. Channel 15
         *-2. Channel 24
         *-3. Channel 25
        uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC10|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40039048, p_u16_Adc1_Ss0_Udma_A, VJDMATRANSFERSIZE_SS0);
        uDMAChannelTransferSet(UDMA_SEC_CHANNEL_ADC10|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40039048, p_u16_Adc1_Ss0_Udma_B, VJDMATRANSFERSIZE_SS0);
            while(1)
         *-0. Channel 14
         *-1. Channel 15
         *-2. Channel 24
         *-3. Channel 25
        uDMAChannelTransferSet(UDMA_CHANNEL_ADC1|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40038068, p_u16_Adc0_Ss1_Udma_A, VJDMATRANSFERSIZE_SS1);
        uDMAChannelTransferSet(UDMA_CHANNEL_ADC1|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40038068, p_u16_Adc0_Ss1_Udma_B, VJDMATRANSFERSIZE_SS1);
           while(1)
          *-0. Channel 14
          *-1. Channel 15
          *-2. Channel 24
          *-3. Channel 25
         uDMAChannelTransferSet(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT, UDMA_MODE_PINGPONG, 0x40038048, p_u16_Adc0_Ss0_Udma_A, VJDMATRANSFERSIZE_SS0);
         uDMAChannelTransferSet(UDMA_CHANNEL_ADC0|UDMA_ALT_SELECT, UDMA_MODE_PINGPONG, 0x40038048, p_u16_Adc0_Ss0_Udma_B, VJDMATRANSFERSIZE_SS0);
        ADC0SEQUENCER0++;
        ADC0SEQUENCER1++;
        ADC1SEQUENCER0++;
        ADC1SEQUENCER1++;
        TIMER2++;
        switch (DebugPrint)
            case 0:
                break;
            case 1:
                break;
            case 2:
                break;
            case 3:
                break;
    int main(void)
        VJ_initMemoryForDma();
        Board_initGPIO();
        // Board_initI2C();
        // Board_initSPI();
        /* Start BIOS */
        BIOS_start();
        return (0);
    So the problem itself is solved but I still don't understand why the memory needs to be structured in that way. Can you give me any insight in that, so I can avoid such problems in the future?
    Greetings
    Richard
    Hi Richard,
    We're not aware of any bugs or issues with doing size 1024 transfers with SPI DMA.  In fact, a recent enhancement allows for transfer sizes > 1024, and this is achieved by doing a series of 1024-sized (max) transfers.
    What version of TI-RTOS are you using?
    The change you made to buffer allocation/placement causes the buffers to change from being interleaved SS0 and SS1 buffers to all SS0 buffers followed by all SS1 buffers.  I'm just pointing this out since it's about the only difference between working and not working, and might have something to do with the problem.
    You mentioned that your "debug" ISR and SWI counters were not what you expected.  What do you expect, and what do you see?
    You haven't really mentioned what happens in the non-working case.  What does happen in the non-working case?
    - Rob
  • Hello Rob,
    thank you for your reply. I'm using TI-RTOS for TivaC 2.16.0.08.
    I don't think that's the problem since in my now running program they are interleaved again, but all 8 memories, which are used by the 4 DMA transfers, are in a consecutively order. I investigated the non running example and the only difference I could find was that the Linker does not place the 8 memories in a consecutively order.
    So my guess is that this has something to do with the problem.
    I expect that the TIMER2 ISR (counting variable TIMER2) is called 1024 times more often than the ADC Sequencer ISRs ( counting variable ADC1SEQUENCER1 for examples). More over I expect that the SWIs for the ADC Sequencers are called as often as the ADC Sequencer ISRs,. In the SWIs I expect, that the corresponding DMA should never be disabled (counting variable ADC1Sequencer0SWI), since the primary and the alternative structure should be toggling. Inside the SWIs I expect that the transfer for Buffer A (counting variable ADC1Sequencer0SWI_A) is reenabled half as often as the ISR for the Sequencer is called, the same applies to the transfer of Buffer B (counting variable ADC1Sequencer0SWI_B). I expect that those values are all the same for all ADC Sequencers. If I'm wrong with my expectations please let me know. Now that my program is running correctly that is exactly what I see.
    I tried to describe it in my earlier post:) I will give it another try, but it is actually quite difficult to describe the error behavior since there seems to be no deterministic behind it, from my point of view.
    In the error case almost only the ISRs for ADC0Sequencer0 and ADC0Sequencer1 are called. (Their counting variables are much higher then the other ones) Sometimes, very infrequent, the other ISRs are called, their corresponding counting variables are non zero. For me it seems that the interrupt flag is not cleared correctly. This does not make much sense to me, but is my best guess. I hope I could clear things up.
    That sounds interesting to me and my program:) I was thinking about doing it in the same fashion as the Peripheral Scatter-Gather mode. Concatenate multiple transfers. Could you post a link where I can find more information about the enhancement. A quick google search didn't showed me any useful information.
    Richard
    You probably already know, but just to make sure, multiple Swi_post()s to a given Swi before the Swi has a chance to run will cause the Swi to run just once, there is no counting of Swi_post()s.
    It could be interesting to see the placement of those discrete buffers for the non-working case.  Can you attach the .map file?
    Robert Tivy
    There's not any web page, at least externally visible outside TI, or documentation that I can find that mentions this.  It's just a feature that was added for Core SDK 3.x (Core SDK is the follow-on to TI-RTOS, which stopped at version 2.21.01.01, I believe).  Core SDK 3.x contains support for the new "Tiva" parts, named MSP432E4, which means that there's no direct support for Tiva part EK-TM4C129EXL.
    If you want to take a look at it, it's in:
    coresdk_msp432e4_3_60_01_00/source/ti/drivers/spi/SPIMSP432E4DMA.c
    Thanks for the detailed explanation of what should be happening and the explanation of what is observed when the problem happens.  I wish I could offer you some worthwhile things to try or to inspect, but I'm not an expert on SPI.  I will try to find someone within TI that could further assist you with this.
    - Rob
  • Hello Rob,
    thank you for the information about the enhanced DMA transfer size!
    Sure. The following .map files were produced with the source code which I posted in my original post. (If someone wants to try it: Just create an empty TI-RTOS Project. Replace the empty.c file with the posted c source code and the empty.cfg with the cfg source code posted.)
    Here you go:
    TIRTOS_NonWorkingExample_DMATransfersize1024.txtTIRTOS_WorkingExample_DMATransfersize1016.txt
    The only difference is the DMA Transfersize (in the posted .c source code line 81: #define VJDMATRANSFERSIZE_SS0). In the running example the define is set to 1016 and in the nonrunning example its set to 1024.
    Richard
