LAUNCHXL2-TMS57012: Automotive scanner / tester
Part Number: LAUNCHXL2-TMS57012
I have just come across the Hercules TMS570LS12x.
I am relative new to programming, mainly with Arduino C code.
Looking at the specs of this board, i believe it could be exactly what i am and many others are looking for.
The aim it to use it for testing and recording data, LIN, CAN-Bus, Flexray, UART, UART Duplex, PWM single wire and PWM dual wire.
Hopefully would also be able to connect RPI TFT for direct debugging and signal analysis. Main use is recording and sending recorded data.
Would this device be powerful enough for the Task?
This seems like a much cheaper option than using multiple separate shields to carry it out on a Arduino or RPI.
Any help would be great, which i will happily share further on the other forums.
