This is regarding the continuation of previous case. We need to detect whether the input signal frequency is present or not from N2HET module.
Also, can you tell me the min and max frequency that N2HET measures?
M.Sreenivasan.
M.Sreenivasan.
Hi Sunil,
We are trying to calculate the number of pulses measured in a given period and we are able to read the value correctly for the given input. But, after running CCS continuously for sometime, could see that number of pulses measured is zero. But, with breakpoints, if we run, we could see its value. Even we verified it in memory, but still its value is not getting changed when we run CCS in continuous mode. Can you please show some light into this behaviour?
We are using CCS8.0
M.Sreenivasan.
Hi Sunil,
Yes you are correct, but we are calculating the pulses. So, we are clearing the data field in ADD instruction.
Even we tried to clear the Data field after reading its value from software (with control is not set to ON). Still the behaviour is same.
It would be good, if we can have a short call, you can send meeting notification to my registered mail id.
M.Sreenivasan.
