Other Parts Discussed in Thread: HALCOGEN
What is the proper way to initialize MibSPI's shift registers to default states?
In our application RM48xx is used as a SPI slave and sometimes we get noise on the clock signal
which in turn gets misrecognised as a clock pulse causing issues with the communication.
As a workaround, we are trying to reset the Shift registers values,
as per the manual, it is mentioned that when the SPIEN bit of SPIGCR1 register is 0
the shift registers should be forced to default states.
We tried to force SPIEN bit to 0 but it is not working,
do we need anything other settings in order to reset the Shift registers?
Best Regards
paddu
