Part Number: TMS570LC4357
Other Parts Discussed in Thread: HALCOGEN
I'm using two launch pads tms570lc43x and I'm setting one up as a master and the other one as a slave. I used one of you example from the forums as guidance and I'll upload my code down here.
In halcogen for the master configuration I enable master and internal clock whereas for the slave I don't enable master and internal clock. For both configurations I enable only mibspi1 driver from "driver enable ->enable MIBSPI drivers". From PINMUX only the MIPSPI1 and I set the transfer group o for MIBSPI1 with length 16 and chip select cs_0.
Pin setup:
Master Slave
1SIMO -->1SIMO
1SOMI -->1SOMI
1CS0 -->1CS0
1CLK -->1CLK
It doesn't work.
