Part Number: TMS570LS3137-EP
Other Parts Discussed in Thread: HALCOGEN
I have tried to install the demo version of the CSP multiple times now and the install fails when the LDRA installation finishes because the LDRA window doesn’t close on its own. I have to close it through the task manager. I am using Windows 10.
I am also getting an error when generating the code using the TAU. I am using HALCoGen v04.07.00 and Code Composer v8.1.0. Even if I don’t try to re-generate the code I still get errors running the testsequence. I believe that I followed the user guide in setup.
Might you know what is wrong with the install or the running of the tests? Any help would be much appreciated.
