Other Parts Discussed in Thread: TPS92515, TPS92692, TPS92691
We want a LED driver IC to replace PT4119 that made in China.
1. The output must be a constant current source;
2. Switching circuit, not linear, low efficiency, and very hot;
3. Input power supply voltage: 12V or 24V;
4. The power should be almost 24W, specifically tested, first select 24W.
5. The efficiency is over 90%.
Thank you!
Elsa Duan
