Part Number: TMS570LS3137
Other Parts Discussed in Thread: HALCOGEN
Hi Team,
We are using CCS8.0 and trying to load the image using Flash (F021) API calls instead of CCS8.0.
With this, image is loaded successfully and after loading, we try to reset the CPU (using CCS8.0 by loading symbols only) and could see that double bit exception handler is getting called during checkFlashECC.
This is not happening when we try to flash image using CCS8.0. Do we need to do execute any Flash API calls after loading the image into flash, prior to CPU reset?
Can you please explain the reason for this behavior.
M.Sreenviasan.
