Part Number: TMS570LS3137
Is there a way to synchronization the PWM(N2HET) cycle to an external IO-pin? I saw the register bit in HETGCR.CMS, which sets the N2HET as a master or slave, but I don't see in the TRM or datasheet which IO pin can be used for this sync.
Also what is the specific behavior of this sync-input -- does the N2HET-cycle restart on EVERY edge (so an external glitch-edge would restart the current cycle, even if it was in the middle?
Jim
