Part Number: TM4C129ENCPDT
Hi Sir,
I need to interface 6v relay with 3.3v output signal of microcontroller (TM4C129ENCPDT)
Hi Sir,
What type of relay do you have and how are you using the relay in your application in conjunction with the MCU? Normally the MCU will drive the low voltage trigger input of the relay to energize the coil as to turn on the mechanical switch for the high voltage/current side. However, in your usage you are taking the relay output back to the MCU. I'm not clear with your application if you mind to elaborate.
