Part Number: EK-TM4C123GXL
I'm having an issue with the air mouse demonstration.
When I turn on the micro controller by moving the switch to the left position, the green led is on as well as a solid blue RGB. On the sensor hub, there is only a red led. It's not until I press down extremely hard on the sensor hub that the blue led on the micro controller begins to flash red and blue. The mouse buttons do work, but moving the device in any way does not elicit a response. Does anyone have any suggestions?
Thank you in advance!
