Part Number: TM4C123GH6PM
I have written a code to make a pulse of 100ms at 5s intervals,If i load value of 100ms in systic timer doesnot produce correct result but if i insert value of 50 in load register accurate pulse is made.As far as i know while working with systic at 80MHz, we can get interrupt at every 200ms(timer overflows every 200ms at max count).I cannot get correct value when 100 is put in this command (ROM_SysTickPeriodSet(SysCtlClockGet()*100/1000);) but if i put 50 i get correct result that is 50ms pulse. Following is the code.
This is Main program Application for Monitoring Pi status
Status from Pi is received by PD0 pin. On every toggle,
status is updated which is displayed by LED's. There are 4 states:
First status is for representing whether PI was restarted lately,
where as other 3 pins shows PI status. The status on which PI is currently at,
is represented by bliking of the respective LED
It utilizes WTimer0 of TM4C123G for its internal timing purposes.
If program doesn't receive any status from PI within 60 seconds,
program will re-initialize.
The system also gets the updated time every second with the help of GPS.
It is attached to UART1 and NMEA sentences are stored in ring buffer through
UART interrupt. Time information is extracted by data parsing when sentence
terminates.
It generates its own pulse to tell PI when to transmit data. It syncs itself
every 30 minutes with PPS of GPS to eliminate timer drifts. WTimer 1 is used
to monitor the resync timeout and Timer 1 is used to set the pulse to zero
Connections:
PD0 -> Pi status toggle Pin
PB1 -> LED1 (for representing whether Pi was restarted lately)
PB2 -> LED2
PB3 -> LED3
PB4 -> LED4
GND -> Pi Ground
PC4(U1RX)-> GPS TX
PC6 -> GPS PPS
PC7 -> pi GPIO pin (to tell pi to initiate transmission)
3.3V -> GPS VIN pin
GND -> GPS GND
#include <stdint.h>
#include <stdbool.h>
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/debug.h"
#include "driverlib/fpu.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/pin_map.h"
#include "driverlib/rom.h"
#include "driverlib/sysctl.h"
#include "driverlib/timer.h"
#include "driverlib/uart.h"
#include "utils/uartstdio.h"
//#include "utils/uartstdio.c"
//void PWMint();
#include <String.h>
//#include "strfunc.h"
#include "inc/hw_timer.h"
#include "inc/hw_gpio.h"
#include "driverlib/sysctl.c"
#include "driverlib/Timer.c"
#include "driverlib/Timer.h"
#include "driverlib/gpio.c"
#include "adafruitUltimateGPS.h"
#include <stdio.h>
#include "UART.h"
//#include "SysTickInts.h"
//#include "PLL.h"
bool isDeviceIDSyncPrepTime(char* currTimeString, uint8_t currDeviceID);
bool PPSInterruptOccured=false; //bool variable to store whether pps interrupt has occured or not after resync request
bool ResyncTimeout=false; //flag to state whether timeout for resync with PPS as occured or not
bool PPSTimerEnabled=false; //flag to store whether timer for PPS is enabled or not
uint32_t lastSyncWithPPS=0; //variable to store time elapsed after the last resync with PPS
int programState=0; //
const uint8_t device_id=1; // Device ID
int i=0;
int T_count=0;
int ResyncTime=720+1;
uint32_t g_ui32Flags;
// The error routine that is called if the driver library encounters an error.
// Configure the UART and its pins. This must be called before UARTprintf().
void
ConfigureUART(void)
// Enable GPIO port A which is used for UART0 pins.
// TODO: change this to whichever GPIO port you are using.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
// Configure the pin muxing for UART0 functions on port A0 and A1.
// This step is not necessary if your part does not support pin muxing.
// TODO: change this to select the port/pin you are using.
GPIOPinConfigure(GPIO_PA0_U0RX);
GPIOPinConfigure(GPIO_PA1_U0TX);
// Enable UART0 so that we can configure the clock.
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
// Use the internal 16MHz oscillator as the UART clock source.
UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC);
// Select the alternate (UART) function for these pins.
GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
// Initialize the UART for console I/O.
UARTStdioConfig(0, 115200, 16000000);
void configPiStatusGPIO()
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
//LED
GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_2);
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, 0x00);
int counter,i,j=0;
void configPPSGPIO()
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC); //enabling PORTC peripherals
GPIOPinTypeGPIOInput(GPIO_PORTC_BASE, GPIO_PIN_6); //setting Port C pin 6 to input type
GPIOIntTypeSet(GPIO_PORTC_BASE, GPIO_PIN_6, GPIO_RISING_EDGE);//setting int to rising edge(will be called at from low to high change)
GPIOPinTypeGPIOOutput(GPIO_PORTC_BASE, GPIO_PIN_7); //setting Port C pin 7 to output type
GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_7, 0x00); //writing 0 to PC7
void configPPSTimer()
ROM_SysTickPeriodSet(SysCtlClockGet()*100/1000); // 1ms period
ROM_IntMasterEnable();
ROM_SysTickIntEnable();
void syncWithGPSPPS()
UARTprintf("Waiting for PPS from GPS\r\n");
GPIOIntClear(GPIO_PORTC_BASE, GPIO_INT_PIN_6); //clear interrupt
ROM_IntEnable(INT_GPIOC);
GPIOIntEnable(GPIO_PORTC_BASE, GPIO_PIN_6); //enabling the interrupt
void PPSGPIOInterrupt()
ROM_SysTickPeriodSet(SysCtlClockGet()*100/1000); // if i put 100 here i donot get correct time period,i get arroud 44ms time period
ROM_SysTickEnable();
UARTprintf("\r\nShifting to State 2");
programState = 2;
counter=0;
T_count=0;
ROM_IntDisable(INT_GPIOC);
GPIOIntDisable(GPIO_PORTC_BASE, GPIO_PIN_6); //disabling the interrupt
//lastSyncWithPPS=0;
UARTprintf("PPS has occured and controller has been synced\r\n");
void TickHandler()
// if(counter>1){
GPIOPinWrite(GPIO_PORTC_BASE,GPIO_PIN_7,0x00);
GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_2,0x00);
counter=counter+1;
if(counter==100){
GPIOPinWrite(GPIO_PORTC_BASE,GPIO_PIN_7,0xFF);
GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_2,0xFF);
counter=0;
T_count=T_count+1;
UARTprintf("HIGH PULSE= %i\n",T_count);
int main(void)
SysCtlClockSet(SYSCTL_SYSDIV_2_5|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
ROM_FPULazyStackingEnable();
//configWatchDog(); //initialize watchdog - for testing comment it
ConfigureUART(); //initializing UART used by the application
//Uart_Init();
initGPS();
initStreamer();
UARTprintf("initialized\r\n");
configPiStatusGPIO();
//configPiStatusTimer();
configPPSGPIO();
configPPSTimer();
ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3); // PF1-3 as outputs
programState=1;
while (1)
//UARTprintf("d");
switch( programState)
case 0:
if (isGPSSentenceComplete() )
UARTprintf("\r\nShifting to State 1");
GPSGetData();
if (isGPSDataUpdated())
if(isDeviceIDSyncPrepTime((char*)GPSData->Time, device_id) == true)
UARTprintf(GPSData->Time);
UARTprintf("\r\n");
programState = 1;
UARTprintf("\r\n\n");
break;
case 1:
syncWithGPSPPS();
break;
case 2:
if(T_count==ResyncTime){
UARTprintf("Resynctimeout==true");
ROM_SysTickDisable();
programState = 1;
break;
default:
UARTprintf("Stuck at wrong program state...\r\nResetting to State 0...");
programState = 0;
char d_id[4];
strcpy(d_id, "1.000");
UARTprintf("\r\nDevice ID: ");
UARTprintf(d_id);
UARTprintf("\r\nDevice time: ");
UARTprintf(&currTimeString[5]);
if (strncmp(&currTimeString[5], "1.000", 3) == 0 || strncmp(&currTimeString[5], "6.000", 3) == 0){
UARTprintf("\r\nTriggered Time: ");
return true;
else{
return false;
