Part Number: TM4C1230C3PM
I am adding a bootloader to a current design based on TM4C1230C3PM. I updated TivaWare to the most current (2.1.4.178). I edited my bl_config.h file to reflect the way I'd like to bootload (forced via pin using UART2 on PG4 and PG5). The relevant configuration code shown below. The first issue I had was that bl_main.c references UART_RX_PCTL and UART_TX_PCTL where as they are defined UART_RXPIN_PCTL and UART_TXPIN_PCTL in bl_config.h. It seems really odd that this error would exist in a TivaWare release. I fixed that by editing bl_main.c to match bl_config.h. That allowed me to build and flash my device. Now, I can successfully control execution via the forced update pin. Low it enters the bootloader, high it loads my application and runs. I cannot however update my application. I am not sure if that's because I have not configured it correctly or if it's because of the software I am using (or something else?). I am using LMFLASH to attempt to update via serial. Looking at the bootloader commands for the old Stellaris bootloader versus the Tiva bootloader I can see no reason why LMFLASH wouldn't work. I also don't see any equivalent program to LMFLASH.
So, in general, does my configuration look reasonable for what I am attempting to achieve and is there a better tool than LMFLASH for serial update using the TivaWare bootloader?
//***************************************************************************** // // The frequency of the crystal used to clock the microcontroller. // // This defines the crystal frequency used by the microcontroller running the // boot loader. If this is unknown at the time of production, then use the // UART_AUTOBAUD feature to properly configure the UART. // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** #define CRYSTAL_FREQ 16000000 //***************************************************************************** // // This enables the boosting of the LDO voltage to 2.75V. For boot loader // configurations that enable the PLL (for example, using the Ethernet port) // on a part that has the PLL errata, this should be enabled. This applies to // revision A2 of Fury-class devices. // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** //#define BOOST_LDO_VOLTAGE //***************************************************************************** // // The starting address of the application. This must be a multiple of 1024 // bytes (making it aligned to a page boundary). A vector table is expected at // this location, and the perceived validity of the vector table (stack located // in SRAM, reset vector located in flash) is used as an indication of the // validity of the application image. // // The flash image of the boot loader must not be larger than this value. // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** #define APP_START_ADDRESS 0x00001000 //***************************************************************************** // // The address at which the application locates its exception vector table. // This must be a multiple of 1KB (making it aligned to a page boundary). // Typically, an application will start with its vector table and this value // will default to APP_START_ADDRESS. This option is provided to cater for // applications which run from external memory which may not be accessible by // the NVIC (the vector table offset register is only 30 bits long). // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** #define VTABLE_START_ADDRESS 0x00001000 //***************************************************************************** // // The size of a single, erasable page in the flash. This must be a power // of 2. The default value of 1KB represents the page size for the internal // flash on all Tiva MCUs and this value should only be overridden if // configuring a boot loader to access external flash devices with a page size // different from this. // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** #define FLASH_PAGE_SIZE 0x00000400 //***************************************************************************** // // The amount of space at the end of flash to reserved. This must be a // multiple of 1024 bytes (making it aligned to a page boundary). This // reserved space is not erased when the application is updated, providing // non-volatile storage that can be used for parameters. // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** //#define FLASH_RSVD_SPACE 0x00000800 //***************************************************************************** // // The number of words of stack space to reserve for the boot loader. // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** #define STACK_SIZE 64 //***************************************************************************** // // The number of words in the data buffer used for receiving packets. This // value must be at least 3. If using autobauding on the UART, this must be at // least 20. The maximum usable value is 65 (larger values will result in // unused space in the buffer). // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** #define BUFFER_SIZE 20 //***************************************************************************** // // Enables updates to the boot loader. Updating the boot loader is an unsafe // operation since it is not fully fault tolerant (losing power to the device // part way though could result in the boot loader no longer being present in // flash). // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** //#define ENABLE_BL_UPDATE //***************************************************************************** // // This definition will cause the the boot loader to erase the entire flash on // updates to the boot loader or to erase the entire application area when the // application is updated. This erases any unused sections in the flash before // the firmware is updated. // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** //#define FLASH_CODE_PROTECTION //***************************************************************************** // // Enables the call to decrypt the downloaded data before writing it into // flash. The decryption routine is empty in the reference boot loader source, // which simply provides a placeholder for adding an actual decrypter. // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** //#define ENABLE_DECRYPTION //***************************************************************************** // // Enables support for the MOSCFAIL handler in the NMI interrupt. // Note: Sandstorm or Fury devices do not provide the MOSCFAIL reset, so this // feature should not be enabled for these devices. // // Depends on: None // Exclusive of: None // Requires: None // //***************************************************************************** //#define ENABLE_MOSCFAIL_HANDLER //***************************************************************************** // // Enables the pin-based forced update check. When enabled, the boot loader // will go into update mode instead of calling the application if a pin is read // at a particular polarity, forcing an update operation. In either case, the // application is still able to return control to the boot loader in order to // start an update. // // Depends on: None // Exclusive of: None // Requires: FORCED_UPDATE_PERIPH, FORCED_UPDATE_PORT, FORCED_UPDATE_PIN, // FORCED_UPDATE_POLARITY // //***************************************************************************** #define ENABLE_UPDATE_CHECK //***************************************************************************** // // The GPIO module to enable in order to check for a forced update. This will // be one of the SYSCTL_RCGCGPIO_Rx values, where Rx represnts the required // GPIO port. This applies to Blizzard class and later devices for FORCED_UPDATE_PORT. // // Depends on: ENABLE_UPDATE_CHECK // Exclusive of: None // Requries: None // //***************************************************************************** #define FORCED_UPDATE_PERIPH SYSCTL_RCGCGPIO_R1 //***************************************************************************** // // The GPIO port to check for a forced update. This will be one of the // GPIO_PORTx_BASE values, where "x" is replaced with the port name (such as // B). The value of "x" should match the value of "x" for // FORCED_UPDATE_PERIPH. // // Depends on: ENABLE_UPDATE_CHECK // Exclusive of: None // Requries: None // //***************************************************************************** #define FORCED_UPDATE_PORT GPIO_PORTB_BASE //***************************************************************************** // // The pin to check for a forced update. This is a value between 0 and 7. // // Depends on: ENABLE_UPDATE_CHECK // Exclusive of: None // Requries: None // //***************************************************************************** #define FORCED_UPDATE_PIN 7 //***************************************************************************** // // The polarity of the GPIO pin that results in a forced update. This value // should be 0 if the pin should be low and 1 if the pin should be high. // // Depends on: ENABLE_UPDATE_CHECK // Exclusive of: None // Requries: None // //***************************************************************************** #define FORCED_UPDATE_POLARITY 0 //***************************************************************************** // // This enables a weak pull up for the GPIO pin used in a forced update. This // value should be 0 if the pin should be have an internal weak pull down and // 1 if the pin should have an interal weak pull up. // Only FORCED_UPDATE_WPU or FORCED_UPDATE_WPD or neither should be defined. // // Depends on: ENABLE_UPDATE_CHECK // Exclusive of: None // Requries: None // //***************************************************************************** //#define FORCED_UPDATE_WPU //#define FORCED_UPDATE_WPD //***************************************************************************** // // This enables the use of the GPIO_LOCK mechanism for configuration of // protected GPIO pins (for example JTAG pins). If this value is not defined, // the locking mechanism will not be used. The only legal values for this // feature are GPIO_LOCK_KEY for Fury devices and GPIO_LOCK_KEY_DD for all // other devices except Sandstorm devices, which do not support this feature. // // Depends on: ENABLE_UPDATE_CHECK // Exclusive of: None // Requries: None // //***************************************************************************** //#define FORCED_UPDATE_KEY GPIO_LOCK_KEY //#define FORCED_UPDATE_KEY GPIO_LOCK_KEY_DD //***************************************************************************** // // Selects the UART as the port for communicating with the boot loader. // // Depends on: None // Exclusive of: CAN_ENABLE_UPDATE, ENET_ENABLE_UPDATE, I2C_ENABLE_UPDATE, // SSI_ENABLE_UPDATE, USB_ENABLE_UPDATE // Requires: UART_AUTOBAUD or UART_FIXED_BAUDRATE, UART_CLOCK_ENABLE, // UARTx_BASE, UART_RXPIN_CLOCK_ENABLE, UART_RXPIN_BASE, // UART_RXPIN_PCTL, UART_RXPIN_POS, UART_TXPIN_CLOCK_ENABLE, // UART_TXPIN_BASE, UART_TXPIN_PCTL and UART_TXPIN_POS // //***************************************************************************** #define UART_ENABLE_UPDATE //***************************************************************************** // // Enables automatic baud rate detection. This can be used if the crystal // frequency is unknown, or if operation at different baud rates is desired. // // Depends on: UART_ENABLE_UPDATE // Exclusive of: UART_FIXED_BAUDRATE // Requires: None // //***************************************************************************** //#define UART_AUTOBAUD //***************************************************************************** // // Selects the baud rate to be used for the UART. // // Depends on: UART_ENABLE_UPDATE, CRYSTAL_FREQ // Exclusive of: UART_AUTOBAUD // Requires: None // //***************************************************************************** #define UART_FIXED_BAUDRATE 115200 //***************************************************************************** // // Selects the clock enable for the UART peripheral module // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UARTx_BASE // //***************************************************************************** #define UART_CLOCK_ENABLE SYSCTL_RCGCUART_R2 //***************************************************************************** // // Selects the base address of the UART peripheral module // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UART_CLOCK_ENABLE // //***************************************************************************** #define UARTx_BASE UART2_BASE //***************************************************************************** // // Selects the clock enable for the GPIO corresponding to UART RX pin // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UART_RXPIN_BASE, UART_RXPIN_PCTL and UART_RXPIN_POS // //***************************************************************************** #define UART_RXPIN_CLOCK_ENABLE SYSCTL_RCGCGPIO_R6 //***************************************************************************** // // Selects the base address for the GPIO corresponding to UART RX pin // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UART_RXPIN_CLOCK_ENABLE, UART_RXPIN_PCTL and UART_RXPIN_POS // //***************************************************************************** #define UART_RXPIN_BASE GPIO_PORTG_BASE //***************************************************************************** // // Selects the port control value for the GPIO corresponding to UART RX pin // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UART_RXPIN_CLOCK_ENABLE, UART_RXPIN_BASE and UART_RXPIN_POS // //***************************************************************************** #define UART_RXPIN_PCTL 0x1 //***************************************************************************** // // Selects the pin number for the GPIO corresponding to UART RX pin // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UART_RXPIN_CLOCK_ENABLE, UART_RXPIN_BASE and UART_RXPIN_PCTL // //***************************************************************************** #define UART_RXPIN_POS 4 //***************************************************************************** // // Selects the clock enable for the GPIO corresponding to UART TX pin // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UART_TXPIN_BASE, UART_TXPIN_PCTL and UART_TXPIN_POS // //***************************************************************************** #define UART_TXPIN_CLOCK_ENABLE SYSCTL_RCGCGPIO_R6 //***************************************************************************** // // Selects the base address for the GPIO corresponding to UART TX pin // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UART_TXPIN_CLOCK_ENABLE, UART_TXPIN_PCTL and UART_TXPIN_POS // //***************************************************************************** #define UART_TXPIN_BASE GPIO_PORTG_BASE //***************************************************************************** // // Selects the port control value for the GPIO corresponding to UART TX pin // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UART_TXPIN_CLOCK_ENABLE, UART_TXPIN_BASE and UART_TXPIN_POS // //***************************************************************************** #define UART_TXPIN_PCTL 0x1 //***************************************************************************** // // Selects the pin number for the GPIO corresponding to UART TX pin // // Depends on: UART_ENABLE_UPDATE // Exclusive of: None // Requires: UART_TXPIN_CLOCK_ENABLE, UART_TXPIN_BASE and UART_TXPIN_PCTL // //***************************************************************************** #define UART_TXPIN_POS 5
