Part Number: MSP-EXPCC430RFX
Other Parts Discussed in Thread: SIMPLICITI, CC1312R, CC1310
I am using msp-expcc430. Through the
* MspExp430F5137RxUserExperience.c - Main User Experience Application
* Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* MSP-EXP430F5137Rx User Epxerience Code
* End device, connects to Access Point MSP-EXP430F6137Rx in a star network
* topology.
* Transmits device's analog data (Vcc, Temp) as well as button presses to the
* AP periodically.
* Version 1.0 D. Dang
* Texas Instruments, Inc.
* Copyright 2011 Texas Instruments Incorporated. All rights reserved.
#include "bsp.h"
#include "mrfi.h"
#include "nwk_types.h"
#include "nwk_api.h"
#include "bsp_leds.h"
#include "bsp_buttons.h"
#include "hal_leds.h"
#include "hal_buttons.h"
#include "hal_adc.h"
#define MESSAGE_BUTTON_PRESSED 0xFF
#define MESSAGE_HEART_BEAT 0xEE
#define USER_EXPERIENCE_FIRMWARE_MODE 0x00
#define USER_EXPERIENCE_PRODUCTION_TEST_MODE 0xFF
* Packet construct:
* Byte 0: Message Type [HeartBeat or ButtonPressed]
* Byte 1: Content Vcc MESSAGE_BUTTON_PRESSED
* Byte 2: Content Temp_MSB MESSAGE_BUTTON_PRESSED
* Byte 3: Content Temp_LSB MESSAGE_BUTTON_PRESSED
* Byte 4: PacketID MSB
* Byte 5: PacketID LSB
unsigned char FIRMWARE_MODE = 0xFF;
extern volatile unsigned char buttonsPressed;
static void linkTo(void);
static uint16_t sTid = 0;
/* Callback handler */
static uint8_t sCB(linkID_t);
static volatile uint8_t sPeerFrameSem = 0;
static linkID_t sLinkID1 = 0;
#define SPIN_ABOUT_A_SECOND NWK_DELAY(1000)
#define SPIN_ABOUT_A_QUARTER_SECOND NWK_DELAY(250)
/* How many times to try a Tx and miss an acknowledge before doing a scan */
#define MISSES_IN_A_ROW 2
void MspExp430F5137RxUserExperience (void)
addr_t lAddr; //adress
BSP_Init(); //initialize
//HalAdcInit();
//HalAdcSetQuitFromISR( 1 );
//SetupRtc();
//P1DIR |= BIT0;
P1DIR=0XFF;
P1OUT=0;
P2DIR=0XFF;
P2OUT=0;
P3DIR=0XFF;
P3OUT=0;
PJDIR=0XFF;
PJOUT=0;
P1REN |= BIT7;
P1OUT |= BIT7;
P1DIR &= ~(BIT7);
P1IES |= BIT7;//
P1IE |= BIT7 ;
P1IFG &= ~BIT7;
_EINT();
// Create a unique address based off the device's wafer ID &
// X/Y coordinates
lAddr.addr[0] = (*(uint8_t *)0x01A0E) ^ (*(uint8_t *)0x01A0A);
lAddr.addr[1] = (*(uint8_t *)0x01A0F) ^ (*(uint8_t *)0x01A0B);
lAddr.addr[2] = (*(uint8_t *)0x01A10) ^ (*(uint8_t *)0x01A0C);
lAddr.addr[3] = (*(uint8_t *)0x01A11) ^ (*(uint8_t *)0x01A0D);
SMPL_Ioctl(IOCTL_OBJ_ADDR, IOCTL_ACT_SET, &lAddr); //generate an address
/* Keep trying to join (a side effect of successful initialization) until
* successful. Toggle LEDS to indicate that joining has not occurred.
while (SMPL_SUCCESS != SMPL_Init(sCB))//join //wait until smpl_init reture smpl_success,
//can this change to interrupt way???
SPIN_ABOUT_A_SECOND;
/* LEDs on solid to indicate successful join. */
/* Unconditional link to AP which is listening due to successful join. */
linkTo();
while (1) ;
static void linkTo() //linking
uint8_t msg[1]; //create a group to save message
//int temperature;
uint8_t misses, done;
/* Keep trying to link... */ //??
while (SMPL_SUCCESS != SMPL_Link(&sLinkID1))
/* sleep until button press... */
SMPL_Ioctl( IOCTL_OBJ_RADIO, IOCTL_ACT_RADIO_SLEEP, 0);
RTCPS1CTL |= RT1PSIE;
while (1)
/* Send a message when either button pressed */
__bis_SR_register(LPM3_bits + GIE);
// __no_operation();
//if (buttonsPressed & 0x80) // writing message
//msg[0] = MESSAGE_BUTTON_PRESSED; //0xff
//msg[1] = MESSAGE_BUTTON_PRESSED;
//msg[2] = MESSAGE_BUTTON_PRESSED;
//msg[3] = MESSAGE_BUTTON_PRESSED;
//buttonsPressed = 0; //set it back to 0
//else // half a second heart beat
//HalAdcStartRead(); //quit lmp3 after done
//__bis_SR_register(LPM0_bits + GIE);
// HalAdcConvertTempVcc();
msg[0] = 1;
//msg[1] = HalAdcGetVcc();
//temperature = HalAdcGetTempDegF();
//msg[2] = *( (unsigned char*)(&temperature) ) ;
//msg[3] = *((unsigned char*)(&temperature)+1) ;
//sTid++;
//msg[4] = (unsigned char) (sTid>>8);
//msg[5] = (unsigned char) (sTid & 0xFF);
/* get radio ready...awakens in idle state */
SMPL_Ioctl( IOCTL_OBJ_RADIO, IOCTL_ACT_RADIO_AWAKE, 0);
/* Set TID and designate which LED to toggle */
//done = 0;
//while (!done)
//for (misses=0; misses < MISSES_IN_A_ROW; ++misses)
if (SMPL_SUCCESS == SMPL_Send(sLinkID1, msg, sizeof(msg))); //send message
// break;
// if (misses == MISSES_IN_A_ROW)
/* This can only happen if we are supporting Frequency Agility and we
* appear not to have received an acknowledge. Do a scan.
//ioctlScanChan_t scan;
//freqEntry_t freq[NWK_FREQ_TBL_SIZE];
//scan.freq = freq;
// SMPL_Ioctl(IOCTL_OBJ_FREQ, IOCTL_ACT_SCAN, &scan);
/* If we now know the channel (number == 1) change to it. In any case
* try it all again. If we changed channels we should get an ack now.
// if (1 == scan.numChan)
// SMPL_Ioctl(IOCTL_OBJ_FREQ, IOCTL_ACT_SET, freq);
// else
/* Got the ack. We're done. */
//done = 1;
/* radio back to sleep */
SMPL_Ioctl( IOCTL_OBJ_RADIO, IOCTL_ACT_RADIO_SLEEP, 0); //special void, manage the i/o
static uint8_t sCB(linkID_t lid)
if (lid == sLinkID1)
sPeerFrameSem++;
return 0;
return 1;
* @brief Initializes the RTC module for interval mode
* @param none
* @return none
* void SetupRtc(void)
RTCCTL01 = RTCMODE + RTCBCD + RTCHOLD + RTCTEV_1;
RTCCTL01 &= ~RTCHOLD;
RTCPS1CTL = RT1IP_7; // Interrupt freq: .5Hz
// RTCPS1CTL = RT1IP_6; // Interrupt freq: 1Hz
// RTCPS1CTL = RT1IP_5; // Interrupt freq: 2Hz
//RTCPS1CTL = RT1IP_4; // Interrupt freq: 4Hz
//RTCPS0CTL = RT0IP_7; // Interrupt freq: 128hz
//RTCCTL0 |= RTCTEVIE; // Enable interrupt
#pragma vector=RTC_VECTOR
__interrupt void RTC_ISR(void)
switch (RTCIV)
default:
__bic_SR_register_on_exit(LPM3_bits);
P1OUT ^=BIT0;
#pragma vector = PORT1_VECTOR
__interrupt void PORT_1(void) {
__delay_cycles(1000);
if((P1IN & BIT7) == 0){
P1IFG &= ~BIT7;
1. set the data rate to 500kbps by set the MDMCFG4(2D),3(3B) respectively, but failed. They can't communicate after I change this 2 register.
2.disable the calibration by set the MCSM0 to 0x0, but they can't communicate.
3. What can I do to the packet in order to reduce the time?
I had uploaded the codes.
many thanks
