CCS/TM4C129ENCPDT: TM4C129ENCPDT I2C uDMA example code
Part Number: TM4C129ENCPDT
Dear TI - Team,
I have managed to communicate over I2C with a LTC2945-chip. I am using the TM4C129E controller and the Ti-library (i2c.h). Currently i am using the API with FIFOS.
Since we are running an RTOS on our system i want to reduce the cpuload.
    I2CMasterControl(Cfg.ui32Base, I2C_MASTER_CMD_FIFO_BURST_SEND_FINISH);
    while(!(I2CMasterBusy(Cfg.ui32Base)));
    while(I2CMasterBusy(Cfg.ui32Base));
as shown above while functions are blocking.
I want to implement interrupts or uDMA, therfore i found following documentation:
http://www.ti.com/lit/an/spma073/spma073.pdf
in this documentation following codesampels are mentioned but never reverenced:
ektm4c129_i2c_master_udma_fifo
ektm4c129_i2c_master_hs
is there a way o get hands on this examples?
Thanks in advance.
regards
Lukas
