Part Number: TM4C1294NCPDT
Tool/software: TI-RTOS
Working on a project with UDP communication. The requirement is to send status data periodically over ethernet. I modified the udpecho.c example. In this I created another task for sending the data. I tried to use the same socket created from receiver task. The code snippet below. Here select, bytesSent1 and FD_ISSET returns -1. Could you guide me how to do this. inserting the modified UDpecho.c file
int bytesSent1;
int status;
UInt posted;
for (;;) {
System_printf("In ethcmdxmit Task\n");
System_flush();
posted = Event_pend(getPstsEvtHandle(), Event_Id_NONE, Event_Id_01, BIOS_WAIT_FOREVER);
if(!isXmitQEmpty())
System_printf("Queue updated\n");
tbuff=retrieveXmitQ();
FD_ZERO(&readSet);
FD_SET(server, &readSet);
addrlen = sizeof(clientAddr);
status = select(server + 1, &readSet, NULL, NULL, NULL);
System_printf("status = %d\n", status);
System_printf("error = %d\n", fdError());
// if (status > 0) {
if (FD_ISSET(server, &readSet)) {
bytesSent1=sendto(server, tbuff, 5, 0, (struct sockaddr *)&clientAddr, addrlen);
System_printf("bytesSent1 inside loop = %d\n", bytesSent1);
System_printf("bytesSent1 = %d\n", bytesSent1);
System_flush();
} //for loop
* Copyright (c) 2015, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== udpEcho.c ========
* Contains BSD sockets code.
#include <string.h>
#include <xdc/std.h>
#include <xdc/cfg/global.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Error.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/drivers/GPIO.h>
/* NDK BSD support */
#include <sys/socket.h>
/* Example/Board Header file */
#include "Board.h"
#include "ethcmd.h"
#include "vdsutils.h"
#include "pstatus.h"
#define UDPPORT 4000
#define UDPPACKETSIZE 256
char *tbuff;
/* prototype definition */
Void ethcmdxmit(UArg arg0, UArg arg1);
Void initEthXmitter(void);
Void testtask(UArg arg0, UArg arg1);
Void ethstsSend(UArg arg0, UArg arg1);
int server;
fd_set readSet;
fd_set wrSet;
struct sockaddr_in localAddr;
struct sockaddr_in clientAddr;
socklen_t addrlen;
Bool sockcreated=FALSE;
* ======== echoFxn ========
* Echoes UDP messages.
Void echoFxn(UArg arg0, UArg arg1)
int bytesRcvd;
int bytesSent;
int bytesSent1;
int status;
// int server;
// fd_set readSet;
// struct sockaddr_in localAddr;
// struct sockaddr_in clientAddr;
// socklen_t addrlen;
char buffer[UDPPACKETSIZE];
char custombuff[9]={1,2,3,4,5,6,7,8,9};
char tbf[5]= {0x23,0x45,0x67,0x89,0x90};
ethMsgObj ethrecvmsg;
Event_Handle tEvt;
Mailbox_Handle tMbx;
server = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (server == -1) {
System_printf("Error: socket not created.\n");
goto shutdown;
memset(&localAddr, 0, sizeof(localAddr));
localAddr.sin_family = AF_INET;
localAddr.sin_addr.s_addr = htonl(INADDR_ANY);
localAddr.sin_port = htons(arg0);
status = bind(server, (struct sockaddr *)&localAddr, sizeof(localAddr));
if (status == -1) {
System_printf("Error: bind failed.\n");
goto shutdown;
else sockcreated=TRUE;
System_printf("socket creation finished.\n");
System_flush();
do {
* readSet and addrlen are value-result arguments, which must be reset
* in between each select() and recvfrom() call
FD_ZERO(&readSet);
/* Wait forever for the reply */
if (status > 0) {
bytesRcvd = recvfrom(server, buffer, UDPPACKETSIZE, 0,
(struct sockaddr *)&clientAddr, &addrlen);
if (bytesRcvd > 0) {
bytesSent = sendto(server, buffer, bytesRcvd, 0,
bytesSent1=sendto(server, custombuff, 9, 0,
// copyCharArry(buffer,ethrecvmsg.msgbuf,30 );
// tMbx=getCmdMailboxHndle();
// Mailbox_post(tMbx, ðrecvmsg, TIMEOUT);
postCmdMBoxMsg(buffer,30 );
if (bytesSent < 0 || bytesSent != bytesRcvd) {
System_printf("Error: sendto failed.\n");
goto shutdown;
if(!isXmitQEmpty())
// copyCharArry(tbuff, tbf,5 );
} while (status > 0);
shutdown:
if (server > 0) {
close(server);
* ======== main ========
int main(void)
/* Call board init functions */
Board_initGeneral();
Board_initGPIO();
Board_initEMAC();
initEthCmd();
initEthXmitter();
// initTestTask();
initPstatus();
/* Turn on user LED */
GPIO_write(Board_LED0, Board_LED_ON);
System_printf("Starting the UDP Echo example\nSystem provider is set to "
"SysMin. Halt the target to view any SysMin contents in"
" ROV.\n");
/* SysMin will only print to the console when you call flush or exit */
System_flush();
System_printf("Just testing\n");
System_flush();
/* Start BIOS */
BIOS_start();
return (0);
Task_Handle taskHandle;
Task_Params taskParams;
Error_Block eb;
/* Make sure Error_Block is initialized */
Error_init(&eb);
Task_Params_init(&taskParams);
taskParams.stackSize = 1024;
taskParams.priority = 4;
taskParams.arg0 = UDPPORT;
taskHandle = Task_create((Task_FuncPtr)ethcmdxmit, &taskParams, &eb);
if (taskHandle == NULL) {
System_printf("main: Failed to create ethcmdxmit Task\n");
Void initTestTask(void)
Error_Block eb;
Error_init(&eb);
taskParams.priority = 3;
taskHandle = Task_create((Task_FuncPtr)testtask, &taskParams, &eb);
for (;;) {
System_printf("In test Task\n");
System_flush();
int bytesSent1;
int status;
UInt posted;
for (;;) {
System_flush();
if(sockcreated)
if(!isXmitQEmpty())
FD_ZERO(&readSet);
System_flush();
} //for loop
Void initEthsend(void)
Error_Block eb;
Error_init(&eb);
taskHandle = Task_create((Task_FuncPtr)ethstsSend, &taskParams, &eb);
Void psidletask(UArg arg0, UArg arg1)
