Part Number: EK-TM4C123GXL
I am trying to interface tm4c123g6pm with soil moisture sensor and cc31000 module. i am done with the cc31000 module code and output but not able to interface it with soil moisture sensor. could you please guide me regarding the code and pin no of tm4c123g6pm i should use to interface it correctly.
Also soil moisture sensor needs power supply of 5v and tm4c gives 3.3v. so can i use 3.3v of tm4c to give power supply to soil moisture sensor?
Like soil moisture sensor i am also using a 5v relay to drive a pump. Can i drive 5v relay with tm4c output?
