Part Number: TMS570LC4357
Hercules microcontroller has 32 ETM data trace ports.
Is it necessary to use all 32 trace ports during debugging? Our software debug VnV team is not sure on the number of ETM trace ports required. We are planning to use Lauterbach debugger (ETMv3 ARM ETM trace) for debug VnV.
If all 32 data trace ports are required, then is it possible to multiplex the signals dynamically (based on register setting)? The reason I am asking this is because, few of ETM trace ports are multiplexed with EMIF lines.
We are utilizing the EMIF interface in our design and would like to know if the register setting can be changed to use ETM data trace ports based on the need dynamically.
Regarsd,
Archana Rao
