Part Number: TMS570LS3137
Other Parts Discussed in Thread: HALCOGEN
Hi Team,
Can you please help in answering below questions:
1. Does Pbist self check or pbist/lbist tests performed during startup code generated from Halcogen is dependent on clock sources (number of clock sources and its configuration)?
2. The reason is that from the document, we understand that L/P BIST tests requires GCLK, HCLK and it can be either from PLL1 or PLL2.
Please confirm, if use only one clock source say could be PLL2 and disable all other sources, will it impact P/L BIST tests?
