Part Number: TMS570LS3137
Other Parts Discussed in Thread: HALCOGEN
What's the sample rate of ADC,Two 12-Bit Multibuffered ADC Modules,
- ADC1: 24 Channels
- ADC2: 16 Channels Shared With ADC1
What is the channel number of PWM.
Please see my answer in your other thread to derive the ADC sampling rate for this device:
https://e2e.ti.com/support/microcontrollers/hercules/f/312/p/821814/3040620#3040620
Could you please clarify what you mean by the channel number of PWM?
The N2HET module can be used to generate a PWM, and the N2HET can be used to trigger an ADC conversion. Details on the N2HET module can be found in section 7.4 of the datasheet and chapter 20 of the Technical Reference Manual.
Also, HALCoGen supports PWM generation using the N2HET module (see screenshot below):
The following N2HET related application notes may also be useful:
