Part Number: TM4C123GH6PGE
Hi all,
Solar Water Pump Controller(Variable Frequency Drive) using your TIVA C Series (TM4C123GH6PGE) to run 3 ph Induction Motor.In this project, we use all possible technique that we got through your portal.The concept is based on SVPWM to generated Pulses and V/F method for Speed Control and Freuency of PWM working is 4kHz.
Now the requirement is two generate separate pwm i.e complementary to each other with 50 kHz frequency.
So,my question is -is it possible to generate pwm with different frequency in same program.
If it possible please tell me possible method.
Please help us and we are always depends on your Technology and Products.
Thank you
