Compiler/TMS570LS1224: lin
Part Number: TMS570LS1224
Other Parts Discussed in Thread: HALCOGEN, TMS570LC4357
i am using tms570ls12xx launchapad . I am new to this. please how tostart lin communication
what is hardwares connection for  loop back and program for lin communication.
please guide me.
thanks and regards,
Mitryi
    You can enable LIN driver from HALCoGen. When enabled, lin.c and lin.h will be generated.
    There is an example code for LIN under HALCoGen examples for TMS570LC4357 MCU that can be used as reference. Also description how to configure the board can be found under HALCoGen->Help-->Help topics-->Examples
    If you intend to connect external module you will need a transceiver.
    Miro
    Thanks for the reply. how to connect wire for LIN loop back. can you send the wire connection diagram for that and document.
    Mitryi
    linEnableLoopback(linREG1,Digital_Lbk); from the example ( finction is declared in lin.c ) enables internal digital loopback and you dont have to make any external connections.
    Miro
