Part Number: TMDX570LC43HDK
Other Parts Discussed in Thread: HALCOGEN
We would like to use the TMS570 HDK board for automation and CAN communication. It will replace a PLC. The main usage is a PIL (infinite loop) with CAN communication, get data from sensors and activate some relays.
The HDK seems like iy suits our needs (we need a high level of safety). We have some experience with PLC and microcontroller programming, but still a little bit new to the TI world.
I have some questions about the needed setup so I we can make the best choices and don't buy unecessary licenses / parts.
Hardware :
- From my understanding, the HDK board has CAN tranceivers and GIO pin exposed, so we only need wires and compatibles sensors. Is that true ?
Software :
- For programming, we would like to keep it simple, so we thought Simulink could be a good option ( but the licenses are expensive). Is it possible to use the HDK board with simulink embedded coder ? Will we have direct acces to blocks for GIO and CAN ?
- For CAN, is it compatible with the Vehicle Network toolbox from simulink ? is this toolbox necessary for CAN communication ?
- If we use simulink, can we use StateFlow ? (for tasks timing)
- Should we use FreeRTOS along with simulink or only simulink is suffiscient ? (I saw people trying to use both along but I don't why )
- It semms like the process is ti generate the config files with HalCoGen, then use only simulink so program the board (without using CCS). I am right ?
I read somewhere in the forum from an old post that using PIL with hercules prevented acces to GIO. Is that true ?
Thanks again for your help, your answears will help use make the right purchase.
