CCS/TMS570LS1224: Hercules™︎ safety microcontrollers forum
Expert 1660 points
Other Parts Discussed in Thread: TMS570LS1224, TMS570LS1227
art Number: TMS570LS1224
Dear all,
I wanna test SafeTI Diagnostic Library. i followed the demo file path: C:\ti\Hercules\SafeTI Diagnostic Library\2.4.0\build\TMS570LS1227_NoOS
in the project properties\resources\General I choose the following to allow the project run in my board
when i build the project i have these errors
  • Ahmad,
    You should be able to ignore those warning. as it appears that the executable may have been built. You can check to see the .map file in the project to see what section .intvecs has got assigned to by the linker. The other warning is about a redundant comparison in the code which should also be harmless.
    If you need to know details on why the warning occurs then please post the question on Code composer studio (Development tools)  forums.
    Rahul
  • sorry but how to reach .map file
  • Ahmad,
    The CCS project creates a debug folder where the .out is located. This will also typically contain a .map file if the linker option to generate one has been enabled.  If it is not being generated then look for --map_file option in ARM linker -> Basic Options.
    Rahul
    PS: I would recommned instead of looking at the Problems Tab in CCS Debug View. Look at View-> Console to see complete log of all the source files, compiler settings and destination folders to see where the object and executable is being archived.
  • this is the .map file
    ****************************************************************************** TI ARM Linker PC v18.12.1 ****************************************************************************** >> Linked Thu Oct 17 09:36:52 2019 OUTPUT FILE NAME: <SL_TMS570LS1227_NoOS.out> ENTRY POINT SYMBOL: "_c_int00" address: 0000cd0c MEMORY CONFIGURATION name origin length used unused attr fill ---------------------- -------- --------- -------- -------- ---- -------- VECTORS 00000000 00000020 00000020 00000000 X FLASH0 00000020 00147fe0 0000ee3c 001391a4 R X STACKS 08000000 00001800 00001800 00000000 RW RAM 08001800 0000ab00 00000590 0000a570 RW PROFILE 0800c300 00007d00 00000000 00007d00 RW LOG 08014000 00002000 00002000 00000000 RW deadbeef FEE f0200000 00000064 00000064 00000000 R deadbeef SEGMENT ALLOCATION MAP run origin load origin length init length attrs members ---------- ----------- ---------- ----------- ----- ------- 00000000 00000000 0000ee60 0000ee60 r-x 00000000 00000000 00000020 00000020 r-x .intvecs 00000020 00000020 0000e3b4 0000e3b4 r-x .text 0000e3d4 0000e3d4 000009d8 000009d8 r-- .const 0000edb0 0000edb0 000000b0 000000b0 r-- .cinit 08000000 08000000 00001800 00000000 r-- 08000000 08000000 00000400 00000000 r-- .STACK_DATA_abt 08000400 08000400 00000400 00000000 r-- .STACK_DATA_fiq 08000800 08000800 00000400 00000000 r-- .STACK_DATA_irq 08000c00 08000c00 00000400 00000000 r-- .STACK_DATA_svc 08001000 08001000 00000400 00000000 r-- .STACK_DATA_sys 08001400 08001400 00000400 00000000 r-- .STACK_DATA_und 08001800 08001800 00000590 00000000 rw- 08001800 08001800 000004f0 00000000 rw- .data 08001cf0 08001cf0 000000a0 00000000 rw- .bss 08014000 08014000 00002000 00002000 r-- 08014000 08014000 00002000 00002000 r-- $fill000 f0200000 f0200000 00000064 00000064 r-- f0200000 f0200000 00000064 00000064 r-- $fill001 SECTION ALLOCATION MAP output attributes/ section page origin length input sections -------- ---- ---------- ---------- ---------------- .excpt_vecs * 0 00000000 00000000 UNINITIALIZED .text 0 00000020 0000e3b4 00000020 00003cac sl_selftest.obj (.text) 00003ccc 00001c68 sys_selftest.obj (.text) 00005934 000011a0 app_main_NoOS.obj (.text) 00006ad4 00000ae8 sys_startup.obj (.text) 000075bc 00000988 mibspi.obj (.text) 00007f44 00000714 can.obj (.text) 00008658 000006f4 spi.obj (.text) 00008d4c 000006b8 adc.obj (.text) 00009404 00000618 system.obj (.text) 00009a1c 0000057c sys_vim.obj (.text) 00009f98 00000570 het.obj (.text) 0000a508 0000054c sl_esm.obj (.text) 0000aa54 0000051c pinmux.obj (.text) 0000af70 0000048c sci.obj (.text) 0000b3fc 000003c8 sys_dma.obj (.text) 0000b7c4 0000038c esm_application_callback.obj (.text) 0000bb50 0000034c sys_core.obj (.text) 0000be9c 00000340 rti.obj (.text) 0000c1dc 00000328 sys_pmm.obj (.text) 0000c504 000002d4 lin.obj (.text) 0000c7d8 000002c0 esm.obj (.text) 0000ca98 00000274 register_readback.obj (.text) 0000cd0c 00000248 sys_startup.obj (.text:retain) 0000cf54 00000244 sl_init.obj (.text) 0000d198 0000023c sl_asm_api.obj (.text) 0000d3d4 00000214 exception_handlers.obj (.text:retain) 0000d5e8 000001ec dcc.obj (.text) 0000d7d4 000001e8 gio.obj (.text) 0000d9bc 000001b4 sl_priv.obj (.text) 0000db70 00000140 sys_vim.obj (.text:retain) 0000dcb0 0000013c esm.obj (.text:retain) 0000ddec 00000104 sl_esm.obj (.text:retain) 0000def0 000000e0 sys_pmu.obj (.text) 0000dfd0 000000a8 sl_misc.obj (.text) 0000e078 0000009c rtsv7R4_T_be_v3D16_eabi.lib : memcpy_t2.asm.obj (.text) 0000e114 0000007a : memset_t2.asm.obj (.text) 0000e18e 0000006c : copy_decompress_lzss.c.obj (.text:decompress:lzss:__TI_decompress_lzss) 0000e1fa 00000002 : div0.asm.obj (.text) 0000e1fc 00000054 : i_div32.asm.obj (.text) 0000e250 00000050 misc.obj (.text) 0000e2a0 00000050 notification.obj (.text) 0000e2f0 00000050 rtsv7R4_T_be_v3D16_eabi.lib : u_div32.asm.obj (.text) 0000e340 00000044 : autoinit.c.obj (.text:__TI_auto_init_nobinit_nopinit:__TI_auto_init_nobinit_nopinit) 0000e384 00000026 : memcmp.c.obj (.text:memcmp) 0000e3aa 00000012 : copy_zero_init.c.obj (.text:decompress:ZI:__TI_zero_init_nomemset:__TI_zero_init_nomemset) 0000e3bc 0000000e : copy_decompress_none.c.obj (.text:decompress:none:__TI_decompress_none) 0000e3ca 00000004 : exit.c.obj (.text:abort:abort) 0000e3ce 00000002 --HOLE-- [fill = 0] 0000e3d0 00000004 sys_phantom.obj (.text:retain) .const 0 0000e3d4 000009d8 0000e3d4 000003a0 het.obj (.const:het1PROGRAM) 0000e774 000003a0 het.obj (.const:het2PROGRAM) 0000eb14 00000200 sys_vim.obj (.const:s_vim_init) 0000ed14 00000020 can.obj (.const:s_canByteOrder) 0000ed34 00000020 het.obj (.const:s_het1pwmPolarity) 0000ed54 00000020 het.obj (.const:s_het2pwmPolarity) 0000ed74 00000018 adc.obj (.const:s_adcFiFoSize) 0000ed8c 00000018 adc.obj (.const:s_adcSelect) 0000eda4 00000008 sl_selftest.obj (.const:.string:$P$T0$1) .cinit 0 0000edb0 000000b0 0000edb0 00000085 (.cinit..data.load) [load image, compression = lzss] 0000ee35 00000003 --HOLE-- [fill = 0] 0000ee38 0000000c (__TI_handler_table) 0000ee44 00000004 --HOLE-- [fill = 0] 0000ee48 00000008 (.cinit..bss.load) [load image, compression = zero_init] 0000ee50 00000010 (__TI_cinit_table) .STACK_DATA_abt * 0 08000000 00000400 UNINITIALIZED 08000000 00000400 --HOLE-- .STACK_DATA_fiq * 0 08000400 00000400 UNINITIALIZED 08000400 00000400 --HOLE-- .STACK_DATA_irq * 0 08000800 00000400 UNINITIALIZED 08000800 00000400 --HOLE-- .STACK_DATA_svc * 0 08000c00 00000400 UNINITIALIZED 08000c00 00000400 --HOLE-- .STACK_DATA_sys * 0 08001000 00000400 UNINITIALIZED 08001000 00000400 --HOLE-- .STACK_DATA_und * 0 08001400 00000400 UNINITIALIZED 08001400 00000400 --HOLE-- .data 0 08001800 000004f0 UNINITIALIZED 08001800 0000031c register_readback.obj (.data:$O1$$) 08001b1c 000000fc app_main_NoOS.obj (.data:$O1$$) 08001c18 00000040 sl_priv.obj (.data:sl_priv_flag_set) 08001c58 00000024 sys_startup.obj (.data:$O1$$) 08001c7c 00000020 esm_application_callback.obj (.data:$O1$$) 08001c9c 00000004 --HOLE-- 08001ca0 00000020 sl_selftest.obj (.data:sramEccTestBuff) 08001cc0 00000020 sys_startup.obj (.data) 08001ce0 00000008 sl_esm.obj (.data:$O1$$) 08001ce8 00000008 sl_selftest.obj (.data:$O1$$) .bss 0 08001cf0 000000a0 UNINITIALIZED 08001cf0 00000078 spi.obj (.bss:g_spiPacket_t) 08001d68 00000028 sci.obj (.bss:g_sciTransfer_t) PROFILE_DATA * 0 0800c300 00000000 UNINITIALIZED LOG_DATA 0 08014000 00000000 UNINITIALIZED .intvecs 0 00000000 00000020 00000000 00000020 sys_intvecs.obj (.intvecs) $fill000 0 08014000 00002000 08014000 00002000 --HOLE-- [fill = deadbeef] $fill001 0 f0200000 00000064 f0200000 00000064 --HOLE-- [fill = deadbeef] MODULE SUMMARY Module code ro data rw data ------ ---- ------- ------- .\demo_app\HALCoGen\TMS570LS1227_NoOS\source\ sys_selftest.obj 7272 0 0 sys_startup.obj 3376 0 68 het.obj 1392 1920 0 mibspi.obj 2440 0 0 sys_vim.obj 1724 512 0 spi.obj 1780 0 120 can.obj 1812 32 0 adc.obj 1720 48 0 system.obj 1560 0 0 pinmux.obj 1308 0 0 sci.obj 1164 0 40 esm.obj 1020 0 0 sys_dma.obj 968 0 0 sys_core.obj 844 0 0 rti.obj 832 0 0 sys_pmm.obj 808 0 0 lin.obj 724 0 0 dcc.obj 492 0 0 gio.obj 488 0 0 sys_pmu.obj 224 0 0 notification.obj 80 0 0 sys_intvecs.obj 32 0 0 sys_phantom.obj 4 0 0 +--+------------------------------+-------+---------+---------+ Total: 32064 2512 228 .\demo_app\common\source\ app_main_NoOS.obj 4512 0 252 register_readback.obj 628 0 796 esm_application_callback.obj 908 0 32 exception_handlers.obj 532 0 0 misc.obj 80 0 0 +--+------------------------------+-------+---------+---------+ Total: 6660 0 1080 .\safety_library\source\ sl_selftest.obj 15532 8 40 sl_esm.obj 1616 0 8 sl_init.obj 580 0 0 sl_asm_api.obj 572 0 0 sl_priv.obj 436 0 64 sl_misc.obj 168 0 0 +--+------------------------------+-------+---------+---------+ Total: 18904 8 112 C:/ti/ccs900/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/lib/rtsv7R4_T_be_v3D16_eabi.lib memcpy_t2.asm.obj 156 0 0 memset_t2.asm.obj 122 0 0 copy_decompress_lzss.c.obj 108 0 0 i_div32.asm.obj 84 0 0 u_div32.asm.obj 80 0 0 autoinit.c.obj 68 0 0 memcmp.c.obj 38 0 0 copy_zero_init.c.obj 18 0 0 copy_decompress_none.c.obj 14 0 0 exit.c.obj 4 0 0 div0.asm.obj 2 0 0 +--+------------------------------+-------+---------+---------+ Total: 694 0 0 Linker Generated: 0 169 0 +--+------------------------------+-------+---------+---------+ Grand Total: 58322 2689 1420 LINKER GENERATED COPY TABLES __TI_cinit_table @ 0000ee50 records: 2, size/record: 8, table size: 16 .data: load addr=0000edb0, load size=00000085 bytes, run addr=08001800, run size=000004f0 bytes, compression=lzss .bss: load addr=0000ee48, load size=00000008 bytes, run addr=08001cf0, run size=000000a0 bytes, compression=zero_init LINKER GENERATED HANDLER TABLE __TI_handler_table @ 0000ee38 records: 3, size/record: 4, table size: 12 index: 0, handler: __TI_zero_init index: 1, handler: __TI_decompress_lzss index: 2, handler: __TI_decompress_none GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name address name ------- ---- 0000e3cb C$$EXIT 0000b7c4 ESM_ApplicationCallback 0000c18c IsdwdKeySequenceCorrect 0000cbe4 Reg_Read_Compare 0000cab0 Reg_getCfgRegDetails 0000ca98 Reg_isBaselined UNDEFED SHT$$INIT_ARRAY$$Base UNDEFED SHT$$INIT_ARRAY$$Limit 0000e000 SL_CRC_Calculate 0000dff0 SL_Clear_nERROR 0000a9ec SL_ESM_Init 0000a9d4 SL_ESM_nERROR_Active 0000db50 SL_FLAG_CLEAR 0000db40 SL_FLAG_GET 0000db2c SL_FLAG_SET 0000d118 SL_Init_ECCFlash 0000d074 SL_Init_ECCTCMRAM 0000d028 SL_Init_Memory 0000d244 SL_Init_R4Registers 0000cf80 SL_Init_ResetReason 0000cf54 SL_Init_ResetReason_XInfo 0000d358 SL_Init_StackPointers 0000dfe0 SL_SW_Reset 00003b24 SL_SelfTestL2L3Interconnect 000036b0 SL_SelfTest_ADC 000034d8 SL_SelfTest_CAN 00003300 SL_SelfTest_CCMR4F 0000308c SL_SelfTest_DMA 00002f40 SL_SelfTest_EFuse 00002adc SL_SelfTest_FEE 000025e0 SL_SelfTest_Flash 000024b0 SL_SelfTest_GIO 00002004 SL_SelfTest_HET 00001e8c SL_SelfTest_HTU 00001d44 SL_SelfTest_LIN 00001a10 SL_SelfTest_MibSPI 00001910 SL_SelfTest_PBIST 000011a0 SL_SelfTest_PBIST_StopExec 000016d8 SL_SelfTest_PSCON 000015c0 SL_SelfTest_SCI 00001480 SL_SelfTest_SPI 00000754 SL_SelfTest_SRAM 000013c0 SL_SelfTest_STC 00001318 SL_SelfTest_Status_CCMR4F 00001290 SL_SelfTest_Status_EFuse 000011c8 SL_SelfTest_Status_PBIST 0000112c SL_SelfTest_Status_PSCON 00001084 SL_SelfTest_Status_STC 00000f14 SL_SelfTest_VIM 00000738 SL_SelfTest_WaitCompletion_PBIST 0000dfd0 SL_Set_nERROR 000005b8 SL_adcCalibration 00000594 SL_capGetSignal 00000584 SL_gioGetBit 0000057c SL_gioGetPort 0000055c SL_gioSetBit 00000554 SL_gioSetDirection 0000054c SL_gioSetPort 00000518 SL_hetEnableLoopback 000004f4 SL_linEnableLoopback 000004d0 SL_linGetData 000004a4 SL_linSend 00000490 SL_linSendHeader 00000478 SL_linSetLength 00000460 SL_mibspiEnableLoopback 000003e8 SL_mibspiGetData 000003b8 SL_mibspiIsTransferComplete 0000035c SL_mibspiSetData 00000348 SL_mibspiTransfer 00000324 SL_sciEnableLoopback 00000318 SL_sciReceiveByte 00000310 SL_sciSendByte 000002f8 SL_spiEnableLoopback 00000268 SL_spiTransmitAndReceiveData 00006a84 SendDebugText 00008cc8 SpiRxStatus 00008c74 SpiTxStatus 08000000 StackModeABT 08000400 StackModeFIQ 08000800 StackModeIRQ 08000c00 StackModeSVC 08001000 StackModeSYS 08001400 StackModeUND 0000db0c _SL_Approximate_value 0000d3c8 _SL_Barrier_Data_Access 0000d1e8 _SL_Disable_IRQ 0000d228 _SL_Get_ARM_Mode 0000d23c _SL_Get_DataFault_Address 0000d234 _SL_Get_DataFault_Status 0000daec _SL_HoldNClear_nError 0000d198 _SL_Init_ECCFlash 0000d1cc _SL_Init_ECCTCMRAM 0000d1b4 _SL_Init_EnableEventExport 0000d3a8 _SL_Kickoff_STC_execution 0000d208 _SL_Restore_IRQ 0000da68 _SL_SelfTest_SRAM_RAD 0000da18 _SL_SelfTest_adcGetSingleData 0000d9ec _SL_SelfTest_adcIsConversionComplete 0000d9bc _SL_SelfTest_adcStartConversion_selChn 0000ee50 __TI_CINIT_Base 0000ee60 __TI_CINIT_Limit 0000ee38 __TI_Handler_Table_Base 0000ee44 __TI_Handler_Table_Limit 0000be94 __TI_PINIT_Base 0000be98 __TI_PINIT_Limit 0000e341 __TI_auto_init_nobinit_nopinit 0000e18f __TI_decompress_lzss 0000e3bd __TI_decompress_none ffffffff __TI_pprof_out_hndl ffffffff __TI_prof_data_size ffffffff __TI_prof_data_start 00000000 __TI_static_base__ 0000e3ab __TI_zero_init_nomemset 0000e1fc __aeabi_idiv 0000e1fb __aeabi_idiv0 0000e1fc __aeabi_idivmod 0000e1fb __aeabi_ldiv0 0000e115 __aeabi_memclr 0000e115 __aeabi_memclr4 0000e115 __aeabi_memclr8 0000e079 __aeabi_memcpy 0000e079 __aeabi_memcpy4 0000e079 __aeabi_memcpy8 0000e117 __aeabi_memset 0000e117 __aeabi_memset4 0000e117 __aeabi_memset8 0000e2f0 __aeabi_uidiv 0000e2f0 __aeabi_uidivmod ffffffff __binit__ ffffffff __c_args__ 0000cd0c _c_int00 0000bdac _coreClearAuxiliaryDataFault_ 0000bdc0 _coreClearAuxiliaryInstructionFault_ 0000bd84 _coreClearDataFaultAddress_ 0000bd5c _coreClearDataFault_ 0000bd98 _coreClearInstructionFaultAddress_ 0000bd70 _coreClearInstructionFault_ 0000bcf0 _coreDisableEventBusExport_ 0000bd34 _coreDisableFlashEcc_ 0000bd10 _coreDisableRamEcc_ 0000bce0 _coreEnableEventBusExport_ 0000bd20 _coreEnableFlashEcc_ 0000bd44 _coreEnableIrqVicOffset_ 0000bd00 _coreEnableRamEcc_ 0000bcc8 _coreEnableVfp_ 0000bda4 _coreGetAuxiliaryDataFault_ 0000bdb8 _coreGetAuxiliaryInstructionFault_ 0000bd7c _coreGetDataFaultAddress_ 0000bd54 _coreGetDataFault_ 0000bd90 _coreGetInstructionFaultAddress_ 0000bd68 _coreGetInstructionFault_ 0000bb50 _coreInitRegisters_ 0000bc5c _coreInitStackPointer_ 0000bdd4 _disable_FIQ_interrupt_ 0000bddc _disable_IRQ_interrupt_ 0000bdcc _disable_interrupt_ 0000bde4 _enable_interrupt_ 0000be74 _errata_CORTEXR4_57_ 0000be84 _errata_CORTEXR4_66_ 0000bdec _esmCcmErrorsClear_ 0000d3e0 _excpt_vec_abort_data 0000d3dc _excpt_vec_abort_pref 0000d3d8 _excpt_vec_svc 0000d3d4 _excpt_vec_udef_instr 0000bca8 _getCPSRValue_ 0000bcb0 _gotoCPUIdle_ 0000df4c _pmuDisableCountersGlobal_ 0000df3c _pmuEnableCountersGlobal_ 0000dfa8 _pmuGetCycleCount_ 0000dfb0 _pmuGetEventCount_ 0000dfbc _pmuGetOverflow_ 0000def0 _pmuInit_ 0000df7c _pmuResetCounters_ 0000df5c _pmuResetCycleCounter_ 0000df6c _pmuResetEventCounters_ 0000df9c _pmuSetCountEvent_ 0000df8c _pmuStartCounters_ 0000df94 _pmuStopCounters_ 0000e250 _svc UNDEFED _system_post_cinit 0000e3cb abort 000092f0 adc1GetConfigValue 00005824 adc1ParityCheck 000091fc adc2GetConfigValue 000057a4 adc2ParityCheck 000090e4 adcCalibration 000090d4 adcDisableNotification 000090b4 adcEnableNotification 00008fe8 adcGetData 00008fe0 adcGetEVTPin 00008ea0 adcInit 00008e90 adcIsConversionComplete 00008e80 adcIsFifoFull 00008da4 adcMidPointCalibration 0000e2ec adcNotification 00008d94 adcResetFiFo 00008d8c adcSetEVTPin 00008d5c adcStartConversion 00008d4c adcStopConversion 00006ad4 afterSTC 08001b80 all1portalgos 08001b1c all1portmemories 08001bac all2portalgos 08001bdc all2portmemories 08001b40 allROMalgos 08001b38 allROMmemories 08001b48 allopenslice2portmemories 08001b30 allopenslicealgos 08001b58 allpmosopen2portmemories 08001b20 allpmosopenalgos ffffffff binit 08001c8c callbkParam1 08001c90 callbkParam2 08001c94 callbkParam3 08001c98 callbkParam4 00008580 can1GetConfigValue 00005708 can1ParityCheck 000084d4 can2GetConfigValue 00005674 can2ParityCheck 00008428 can3GetConfigValue 000055e4 can3ParityCheck 00008418 canDisableErrorNotification 00008408 canDisableStatusChangeNotification 000083ec canDisableloopback 000083dc canEnableErrorNotification 000083cc canEnableStatusChangeNotification 000083b0 canEnableloopback 0000e2e8 canErrorNotification 00008340 canFillMessageObjectData 0000829c canGetData 00008290 canGetErrorLevel 00008258 canGetID 0000824c canGetLastError 0000810c canInit 00008100 canIoRxGetBit 000080dc canIoSetDirection 000080b8 canIoSetPort 000080ac canIoTxGetBit 0000808c canIsMessageBoxValid 0000806c canIsRxMessageArrived 0000804c canIsTxMessagePending 0000e2e4 canMessageNotification 00008000 canSendRemoteFrame 0000e2e0 canStatusChangeNotification 00007f90 canTransmit 00007f44 canUpdateID 0000a47c capGetSignal 08001c7d cccmr4f_errorforcing_app_callback 00005510 ccmSelfCheck 000054e0 ccmr4GetConfigValue 000053a0 checkB0RAMECC 00005240 checkB1RAMECC 000051b8 checkClockMonitor 00005110 checkFlashECC 0000500c checkFlashEEPROMECC 00004f68 checkPLL1Slip 00004ee8 checkPLL2Slip 00004e44 checkRAMAddrParity 00004cb8 checkRAMECC 00004bcc checkRAMUERRTest 00004b80 checkefcSelfTest 00004b1c cpuSelfTest 00004b18 cpuSelfTestFail 08001cd0 crcAtInit_FEE 08001cc8 crcAtInit_FLASH 08001cd8 crcAtInit_StaticRAM 08001cc0 crcAtInit_VIMRAM 00004b14 custom_dabort 0000d754 dcc1GetConfigValue 0000d6ec dcc2GetConfigValue 0000d6d8 dccDisable 0000d6b4 dccDisableNotification 0000d6a0 dccEnable 0000d688 dccEnableNotification 0000d67c dccGetErrStatus 0000d624 dccInit 0000e2dc dccNotification 0000d610 dccSelectClockSource 0000d608 dccSetCounter0Seed 0000d600 dccSetCounter1Seed 0000d5f0 dccSetSeed 0000d5e8 dccSetTolerance 00004ac8 disableParity 0000b77c dmaDefineRegion 0000b760 dmaDisable 0000b714 dmaDisableInterrupt 0000b704 dmaDisableParityCheck 0000b6e8 dmaDisableRegion 0000b6cc dmaEnable 0000b680 dmaEnableInterrupt 0000b670 dmaEnableParityCheck 0000b61c dmaEnableRegion 0000b58c dmaGetConfigValue 0000b564 dmaGetReq 0000e2d8 dmaGroupANotification 00004a4c dmaParityCheck 0000b528 dmaReqAssign 0000b4fc dmaSetChEnable 0000b418 dmaSetCtrlPacket 0000b3fc dmaSetPriority 0000c17c dwdClearFlag 0000c16c dwdCounterEnable 0000c154 dwdGenerateSysReset 0000c13c dwdGetStatus 0000c0e8 dwdGetViolationStatus 0000c0d4 dwdInit 0000c0bc dwdReset 0000c0b0 dwdSetPreload 0000c0a4 dwwdGetCurrentDownCounter 0000c088 dwwdInit 0000a46c edgeDisableNotification 0000a458 edgeEnableNotification 0000a444 edgeGetCounter 0000e2d4 edgeNotification 0000a430 edgeResetCounter 000049f8 efcCheck 000049a8 efcGetConfigValue 00004988 efcSelfTest 0000492c efcStuckZeroTest 000048e0 enableParity 00004694 errata_PBIST_4 0000ca60 esmActivateNormalOperation 0000ca44 esmClearStatus 0000ca38 esmClearStatusBuffer 0000ca28 esmDisableError 0000ca18 esmDisableInterrupt 0000ca08 esmEnableError 0000c9f8 esmEnableInterrupt 0000c9b4 esmEnterSelfTest 0000c9a8 esmError 0000c928 esmGetConfigValue 0000c8f0 esmGetStatus 0000c8d8 esmGetStatusBuffer 0000e2d0 esmGroup1Notification 0000e2cc esmGroup2Notification 0000dd40 esmHighInterrupt 0000c85c esmInit 0000dcb0 esmLowInterrupt 0000c830 esmSelfTestStatus 0000c820 esmSetCounterPreloadValue 0000c7e8 esmSetInterruptLevel 0000c7d8 esmTriggerErrorPinReset 08001c6c failInfoPBISTSRAM 08001c80 fee_1bit_faultinject_app_callback 08001c81 fee_2bit_faultinject_app_callback 08001c84 flash_2bit_faultinject_callback 08001c85 flash_addr_par_faultinject_callback 000045d4 fmcBus1ParityCheck 000045b0 fmcBus2Check 00004538 fmcECCcheck 08001cec g_L2L3_read_reserved_word 0000d978 gioDisableNotification 0000d948 gioEnableNotification 0000d938 gioGetBit 0000d88c gioGetConfigValue 0000d884 gioGetPort 0000d824 gioInit 0000e2c8 gioNotification 0000d804 gioSetBit 0000d7fc gioSetDirection 0000d7f4 gioSetPort 0000d7d4 gioToggleBit 0000a370 het1GetConfigValue 000044bc het1ParityCheck 0000a2a0 het2GetConfigValue 0000442c het2ParityCheck 0000a298 hetGetTimestamp 0000a1dc hetInit 0000e2c4 hetNotification 0000a1d0 hetResetTimestamp 000043ac htu1ParityCheck 0000432c htu2ParityCheck 08001c5c initSTFailCount 08001c60 initSTPassCount 0000c7bc linClearStatusFlag 0000c7b0 linDisableLoopback 0000c7a8 linDisableNotification 0000c790 linEnableLoopback 0000c788 linEnableNotification 0000c778 linEnterSleep 0000c690 linGetConfigValue 0000c66c linGetData 0000c660 linGetIdentifier 0000c658 linGetStatusFlag 0000c5cc linInit 0000c5c0 linIsRxReady 0000c5b4 linIsTxReady 0000c588 linSend 0000c574 linSendHeader 0000c55c linSendWakupSignal 0000c554 linSetFunctional 0000c53c linSetLength 0000c520 linSoftwareReset 0000c504 linTxRxError 00005958 main 08001b24 maintaskcount 000095d4 mapClocks 0000e385 memcmp 0000e079 memcpy 00004304 memoryInit 0000e2c0 memoryPort0TestFailNotification 0000e2bc memoryPort1TestFailNotification 0000e11d memset 00007d9c mibspi1GetConfigValue 00004254 mibspi1ParityCheck 00007c40 mibspi3GetConfigValue 000041a4 mibspi3ParityCheck 00007ae4 mibspi5GetConfigValue 000040f4 mibspi5ParityCheck 00007acc mibspiDisableGroupNotification 00007ac0 mibspiDisableLoopback 00007a68 mibspiEnableGroupNotification 00007a50 mibspiEnableLoopback 000079b4 mibspiGetData 0000e2b8 mibspiGroupNotification 000076a4 mibspiInit 00007674 mibspiIsTransferComplete 0000e2b4 mibspiNotification 00007654 mibspiPmodeSet 000075d8 mibspiSetData 000075d0 mibspiSetFunctional 000075bc mibspiTransfer 0000abe4 muxInit 000040bc pbistFail 00004030 pbistGetConfigValue 0000401c pbistIsTestCompleted 00004004 pbistIsTestPassed 00003fe0 pbistPortTestStatus 00003f58 pbistRun 00003e28 pbistSelfCheck 00003dfc pbistStop 08001b2c periodicSTFailCount 08001b28 periodicSTPassCount 00009568 periphInit 0000e3d0 phantomInterrupt 0000aa54 pinmuxGetConfigValue 08001c86 pll1_slip_faultinject_callback 08001c87 pll2_slip_faultinject_callback 0000c49c pmmGetConfigValue 0000c41c pmmInit 0000c404 pmmIsLogicPowerDomainActive 0000c3ec pmmIsMemPowerDomainActive 0000c398 pmmPerformSelfTest 0000c38c pmmSetMode 0000c30c pmmTurnOFFLogicPowerDomain 0000c2b8 pmmTurnOFFMemPowerDomain 0000c230 pmmTurnONLogicPowerDomain 0000c1dc pmmTurnONMemPowerDomain 08001c7c pscon_errorforcing_app_callback 08001c7e pscon_selftest_errorforcing_app_callback 0000a1c0 pwmDisableNotification 0000a1ac pwmEnableNotification 0000a13c pwmGetSignal 0000e2b0 pwmNotification 0000a0a8 pwmSetDuty 00009fd0 pwmSetSignal 00009fb4 pwmStart 00009f98 pwmStop 00000000 resetEntry 08001c58 resetReason 0000c07c rtiDisableNotification 0000c06c rtiEnableNotification 0000bfe0 rtiGetConfigValue 0000bfa8 rtiGetCurrentTick 0000bf9c rtiGetPeriod 0000bf1c rtiInit 0000e2ac rtiNotification 0000bee0 rtiResetCounter 0000bed4 rtiSetPeriod 0000beb8 rtiStartCounter 0000be9c rtiStopCounter 0000b3d4 sciDisableLoopback 0000b394 sciDisableNotification 0000b37c sciEnableLoopback 0000b348 sciEnableNotification 0000b29c sciGetConfigValue 0000b1bc sciInit 0000b1b0 sciIsIdleDetected 0000b1a4 sciIsRxReady 0000b198 sciIsTxReady 0000e2a8 sciNotification 0000b138 sciReceive 0000b120 sciReceiveByte 0000b108 sciRxError 0000b07c sciSend 0000b068 sciSendByte 0000b024 sciSetBaudrate 0000b01c sciSetFunctional 0000af70 scilinGetConfigValue 00003ccc selftestFailNotification 000095a4 setupFlash 00009520 setupPLL 00000020 sl_dmaConfigCtrlPacket 0000015c sl_dmaSetChEnable 00000074 sl_dmaSetCtrlPacket 0000023c sl_dmaSetProtectedRegion 00000178 sl_dmaSoftwrTestConfig 08001c18 sl_priv_flag_set 00008bb4 spi2GetConfigValue 00008af4 spi4GetConfigValue 00008ae8 spiDisableLoopback 00008ad8 spiDisableNotification 00008ac0 spiEnableLoopback 00008aac spiEnableNotification 0000e2a4 spiEndNotification 00008a30 spiGetData 00008904 spiInit 0000e2a0 spiNotification 00008884 spiReceiveData 000087f8 spiSendAndGetData 0000877c spiSendData 00008774 spiSetFunctional 000086e4 spiTransmitAndReceiveData 00008658 spiTransmitData 08001ca0 sramEccTestBuff 00009938 sramGetConfigValue 08001c82 sram_1bit_prof_faultinject_callback 08001c83 sram_2bit_faultinject_callback 08001c7f sram_radecode_diagnostics_app_callback 08001c64 static_ram 00003db0 stcGetConfigValue 00003d50 stcSelfCheck 00003d4c stcSelfCheckFail 0000971c systemGetConfigValue 0000968c systemInit 00009508 systemPowerDown 00009430 tcmflashGetConfigValue 00009404 trimLPO 0000edac ulFlashEndAddr 00000000 ulFlashStartAddr 08014000 ulLOGEndAddr 08014000 ulLOGStartAddr 0800c300 ulPROFILEEndAddr 0800c300 ulPROFILEStartAddr 08001c88 unknowncallback 00009ea8 vimChannelMap 00009e50 vimDisableInterrupt 00009d3c vimEnableInterrupt 00009a80 vimGetConfigValue 00009a1c vimInit 00003cd0 vimParityCheck 0000db70 vimParityErrorHandler 08001ce8 vimTestFlag GLOBAL SYMBOLS: SORTED BY Symbol Address address name ------- ---- 00000000 __TI_static_base__ 00000000 resetEntry 00000000 ulFlashStartAddr 00000020 sl_dmaConfigCtrlPacket 00000074 sl_dmaSetCtrlPacket 0000015c sl_dmaSetChEnable 00000178 sl_dmaSoftwrTestConfig 0000023c sl_dmaSetProtectedRegion 00000268 SL_spiTransmitAndReceiveData 000002f8 SL_spiEnableLoopback 00000310 SL_sciSendByte 00000318 SL_sciReceiveByte 00000324 SL_sciEnableLoopback 00000348 SL_mibspiTransfer 0000035c SL_mibspiSetData 000003b8 SL_mibspiIsTransferComplete 000003e8 SL_mibspiGetData 00000460 SL_mibspiEnableLoopback 00000478 SL_linSetLength 00000490 SL_linSendHeader 000004a4 SL_linSend 000004d0 SL_linGetData 000004f4 SL_linEnableLoopback 00000518 SL_hetEnableLoopback 0000054c SL_gioSetPort 00000554 SL_gioSetDirection 0000055c SL_gioSetBit 0000057c SL_gioGetPort 00000584 SL_gioGetBit 00000594 SL_capGetSignal 000005b8 SL_adcCalibration 00000738 SL_SelfTest_WaitCompletion_PBIST 00000754 SL_SelfTest_SRAM 00000f14 SL_SelfTest_VIM 00001084 SL_SelfTest_Status_STC 0000112c SL_SelfTest_Status_PSCON 000011a0 SL_SelfTest_PBIST_StopExec 000011c8 SL_SelfTest_Status_PBIST 00001290 SL_SelfTest_Status_EFuse 00001318 SL_SelfTest_Status_CCMR4F 000013c0 SL_SelfTest_STC 00001480 SL_SelfTest_SPI 000015c0 SL_SelfTest_SCI 000016d8 SL_SelfTest_PSCON 00001910 SL_SelfTest_PBIST 00001a10 SL_SelfTest_MibSPI 00001d44 SL_SelfTest_LIN 00001e8c SL_SelfTest_HTU 00002004 SL_SelfTest_HET 000024b0 SL_SelfTest_GIO 000025e0 SL_SelfTest_Flash 00002adc SL_SelfTest_FEE 00002f40 SL_SelfTest_EFuse 0000308c SL_SelfTest_DMA 00003300 SL_SelfTest_CCMR4F 000034d8 SL_SelfTest_CAN 000036b0 SL_SelfTest_ADC 00003b24 SL_SelfTestL2L3Interconnect 00003ccc selftestFailNotification 00003cd0 vimParityCheck 00003d4c stcSelfCheckFail 00003d50 stcSelfCheck 00003db0 stcGetConfigValue 00003dfc pbistStop 00003e28 pbistSelfCheck 00003f58 pbistRun 00003fe0 pbistPortTestStatus 00004004 pbistIsTestPassed 0000401c pbistIsTestCompleted 00004030 pbistGetConfigValue 000040bc pbistFail 000040f4 mibspi5ParityCheck 000041a4 mibspi3ParityCheck 00004254 mibspi1ParityCheck 00004304 memoryInit 0000432c htu2ParityCheck 000043ac htu1ParityCheck 0000442c het2ParityCheck 000044bc het1ParityCheck 00004538 fmcECCcheck 000045b0 fmcBus2Check 000045d4 fmcBus1ParityCheck 00004694 errata_PBIST_4 000048e0 enableParity 0000492c efcStuckZeroTest 00004988 efcSelfTest 000049a8 efcGetConfigValue 000049f8 efcCheck 00004a4c dmaParityCheck 00004ac8 disableParity 00004b14 custom_dabort 00004b18 cpuSelfTestFail 00004b1c cpuSelfTest 00004b80 checkefcSelfTest 00004bcc checkRAMUERRTest 00004cb8 checkRAMECC 00004e44 checkRAMAddrParity 00004ee8 checkPLL2Slip 00004f68 checkPLL1Slip 0000500c checkFlashEEPROMECC 00005110 checkFlashECC 000051b8 checkClockMonitor 00005240 checkB1RAMECC 000053a0 checkB0RAMECC 000054e0 ccmr4GetConfigValue 00005510 ccmSelfCheck 000055e4 can3ParityCheck 00005674 can2ParityCheck 00005708 can1ParityCheck 000057a4 adc2ParityCheck 00005824 adc1ParityCheck 00005958 main 00006a84 SendDebugText 00006ad4 afterSTC 000075bc mibspiTransfer 000075d0 mibspiSetFunctional 000075d8 mibspiSetData 00007654 mibspiPmodeSet 00007674 mibspiIsTransferComplete 000076a4 mibspiInit 000079b4 mibspiGetData 00007a50 mibspiEnableLoopback 00007a68 mibspiEnableGroupNotification 00007ac0 mibspiDisableLoopback 00007acc mibspiDisableGroupNotification 00007ae4 mibspi5GetConfigValue 00007c40 mibspi3GetConfigValue 00007d9c mibspi1GetConfigValue 00007f44 canUpdateID 00007f90 canTransmit 00008000 canSendRemoteFrame 0000804c canIsTxMessagePending 0000806c canIsRxMessageArrived 0000808c canIsMessageBoxValid 000080ac canIoTxGetBit 000080b8 canIoSetPort 000080dc canIoSetDirection 00008100 canIoRxGetBit 0000810c canInit 0000824c canGetLastError 00008258 canGetID 00008290 canGetErrorLevel 0000829c canGetData 00008340 canFillMessageObjectData 000083b0 canEnableloopback 000083cc canEnableStatusChangeNotification 000083dc canEnableErrorNotification 000083ec canDisableloopback 00008408 canDisableStatusChangeNotification 00008418 canDisableErrorNotification 00008428 can3GetConfigValue 000084d4 can2GetConfigValue 00008580 can1GetConfigValue 00008658 spiTransmitData 000086e4 spiTransmitAndReceiveData 00008774 spiSetFunctional 0000877c spiSendData 000087f8 spiSendAndGetData 00008884 spiReceiveData 00008904 spiInit 00008a30 spiGetData 00008aac spiEnableNotification 00008ac0 spiEnableLoopback 00008ad8 spiDisableNotification 00008ae8 spiDisableLoopback 00008af4 spi4GetConfigValue 00008bb4 spi2GetConfigValue 00008c74 SpiTxStatus 00008cc8 SpiRxStatus 00008d4c adcStopConversion 00008d5c adcStartConversion 00008d8c adcSetEVTPin 00008d94 adcResetFiFo 00008da4 adcMidPointCalibration 00008e80 adcIsFifoFull 00008e90 adcIsConversionComplete 00008ea0 adcInit 00008fe0 adcGetEVTPin 00008fe8 adcGetData 000090b4 adcEnableNotification 000090d4 adcDisableNotification 000090e4 adcCalibration 000091fc adc2GetConfigValue 000092f0 adc1GetConfigValue 00009404 trimLPO 00009430 tcmflashGetConfigValue 00009508 systemPowerDown 00009520 setupPLL 00009568 periphInit 000095a4 setupFlash 000095d4 mapClocks 0000968c systemInit 0000971c systemGetConfigValue 00009938 sramGetConfigValue 00009a1c vimInit 00009a80 vimGetConfigValue 00009d3c vimEnableInterrupt 00009e50 vimDisableInterrupt 00009ea8 vimChannelMap 00009f98 pwmStop 00009fb4 pwmStart 00009fd0 pwmSetSignal 0000a0a8 pwmSetDuty 0000a13c pwmGetSignal 0000a1ac pwmEnableNotification 0000a1c0 pwmDisableNotification 0000a1d0 hetResetTimestamp 0000a1dc hetInit 0000a298 hetGetTimestamp 0000a2a0 het2GetConfigValue 0000a370 het1GetConfigValue 0000a430 edgeResetCounter 0000a444 edgeGetCounter 0000a458 edgeEnableNotification 0000a46c edgeDisableNotification 0000a47c capGetSignal 0000a9d4 SL_ESM_nERROR_Active 0000a9ec SL_ESM_Init 0000aa54 pinmuxGetConfigValue 0000abe4 muxInit 0000af70 scilinGetConfigValue 0000b01c sciSetFunctional 0000b024 sciSetBaudrate 0000b068 sciSendByte 0000b07c sciSend 0000b108 sciRxError 0000b120 sciReceiveByte 0000b138 sciReceive 0000b198 sciIsTxReady 0000b1a4 sciIsRxReady 0000b1b0 sciIsIdleDetected 0000b1bc sciInit 0000b29c sciGetConfigValue 0000b348 sciEnableNotification 0000b37c sciEnableLoopback 0000b394 sciDisableNotification 0000b3d4 sciDisableLoopback 0000b3fc dmaSetPriority 0000b418 dmaSetCtrlPacket 0000b4fc dmaSetChEnable 0000b528 dmaReqAssign 0000b564 dmaGetReq 0000b58c dmaGetConfigValue 0000b61c dmaEnableRegion 0000b670 dmaEnableParityCheck 0000b680 dmaEnableInterrupt 0000b6cc dmaEnable 0000b6e8 dmaDisableRegion 0000b704 dmaDisableParityCheck 0000b714 dmaDisableInterrupt 0000b760 dmaDisable 0000b77c dmaDefineRegion 0000b7c4 ESM_ApplicationCallback 0000bb50 _coreInitRegisters_ 0000bc5c _coreInitStackPointer_ 0000bca8 _getCPSRValue_ 0000bcb0 _gotoCPUIdle_ 0000bcc8 _coreEnableVfp_ 0000bce0 _coreEnableEventBusExport_ 0000bcf0 _coreDisableEventBusExport_ 0000bd00 _coreEnableRamEcc_ 0000bd10 _coreDisableRamEcc_ 0000bd20 _coreEnableFlashEcc_ 0000bd34 _coreDisableFlashEcc_ 0000bd44 _coreEnableIrqVicOffset_ 0000bd54 _coreGetDataFault_ 0000bd5c _coreClearDataFault_ 0000bd68 _coreGetInstructionFault_ 0000bd70 _coreClearInstructionFault_ 0000bd7c _coreGetDataFaultAddress_ 0000bd84 _coreClearDataFaultAddress_ 0000bd90 _coreGetInstructionFaultAddress_ 0000bd98 _coreClearInstructionFaultAddress_ 0000bda4 _coreGetAuxiliaryDataFault_ 0000bdac _coreClearAuxiliaryDataFault_ 0000bdb8 _coreGetAuxiliaryInstructionFault_ 0000bdc0 _coreClearAuxiliaryInstructionFault_ 0000bdcc _disable_interrupt_ 0000bdd4 _disable_FIQ_interrupt_ 0000bddc _disable_IRQ_interrupt_ 0000bde4 _enable_interrupt_ 0000bdec _esmCcmErrorsClear_ 0000be74 _errata_CORTEXR4_57_ 0000be84 _errata_CORTEXR4_66_ 0000be94 __TI_PINIT_Base 0000be98 __TI_PINIT_Limit 0000be9c rtiStopCounter 0000beb8 rtiStartCounter 0000bed4 rtiSetPeriod 0000bee0 rtiResetCounter 0000bf1c rtiInit 0000bf9c rtiGetPeriod 0000bfa8 rtiGetCurrentTick 0000bfe0 rtiGetConfigValue 0000c06c rtiEnableNotification 0000c07c rtiDisableNotification 0000c088 dwwdInit 0000c0a4 dwwdGetCurrentDownCounter 0000c0b0 dwdSetPreload 0000c0bc dwdReset 0000c0d4 dwdInit 0000c0e8 dwdGetViolationStatus 0000c13c dwdGetStatus 0000c154 dwdGenerateSysReset 0000c16c dwdCounterEnable 0000c17c dwdClearFlag 0000c18c IsdwdKeySequenceCorrect 0000c1dc pmmTurnONMemPowerDomain 0000c230 pmmTurnONLogicPowerDomain 0000c2b8 pmmTurnOFFMemPowerDomain 0000c30c pmmTurnOFFLogicPowerDomain 0000c38c pmmSetMode 0000c398 pmmPerformSelfTest 0000c3ec pmmIsMemPowerDomainActive 0000c404 pmmIsLogicPowerDomainActive 0000c41c pmmInit 0000c49c pmmGetConfigValue 0000c504 linTxRxError 0000c520 linSoftwareReset 0000c53c linSetLength 0000c554 linSetFunctional 0000c55c linSendWakupSignal 0000c574 linSendHeader 0000c588 linSend 0000c5b4 linIsTxReady 0000c5c0 linIsRxReady 0000c5cc linInit 0000c658 linGetStatusFlag 0000c660 linGetIdentifier 0000c66c linGetData 0000c690 linGetConfigValue 0000c778 linEnterSleep 0000c788 linEnableNotification 0000c790 linEnableLoopback 0000c7a8 linDisableNotification 0000c7b0 linDisableLoopback 0000c7bc linClearStatusFlag 0000c7d8 esmTriggerErrorPinReset 0000c7e8 esmSetInterruptLevel 0000c820 esmSetCounterPreloadValue 0000c830 esmSelfTestStatus 0000c85c esmInit 0000c8d8 esmGetStatusBuffer 0000c8f0 esmGetStatus 0000c928 esmGetConfigValue 0000c9a8 esmError 0000c9b4 esmEnterSelfTest 0000c9f8 esmEnableInterrupt 0000ca08 esmEnableError 0000ca18 esmDisableInterrupt 0000ca28 esmDisableError 0000ca38 esmClearStatusBuffer 0000ca44 esmClearStatus 0000ca60 esmActivateNormalOperation 0000ca98 Reg_isBaselined 0000cab0 Reg_getCfgRegDetails 0000cbe4 Reg_Read_Compare 0000cd0c _c_int00 0000cf54 SL_Init_ResetReason_XInfo 0000cf80 SL_Init_ResetReason 0000d028 SL_Init_Memory 0000d074 SL_Init_ECCTCMRAM 0000d118 SL_Init_ECCFlash 0000d198 _SL_Init_ECCFlash 0000d1b4 _SL_Init_EnableEventExport 0000d1cc _SL_Init_ECCTCMRAM 0000d1e8 _SL_Disable_IRQ 0000d208 _SL_Restore_IRQ 0000d228 _SL_Get_ARM_Mode 0000d234 _SL_Get_DataFault_Status 0000d23c _SL_Get_DataFault_Address 0000d244 SL_Init_R4Registers 0000d358 SL_Init_StackPointers 0000d3a8 _SL_Kickoff_STC_execution 0000d3c8 _SL_Barrier_Data_Access 0000d3d4 _excpt_vec_udef_instr 0000d3d8 _excpt_vec_svc 0000d3dc _excpt_vec_abort_pref 0000d3e0 _excpt_vec_abort_data 0000d5e8 dccSetTolerance 0000d5f0 dccSetSeed 0000d600 dccSetCounter1Seed 0000d608 dccSetCounter0Seed 0000d610 dccSelectClockSource 0000d624 dccInit 0000d67c dccGetErrStatus 0000d688 dccEnableNotification 0000d6a0 dccEnable 0000d6b4 dccDisableNotification 0000d6d8 dccDisable 0000d6ec dcc2GetConfigValue 0000d754 dcc1GetConfigValue 0000d7d4 gioToggleBit 0000d7f4 gioSetPort 0000d7fc gioSetDirection 0000d804 gioSetBit 0000d824 gioInit 0000d884 gioGetPort 0000d88c gioGetConfigValue 0000d938 gioGetBit 0000d948 gioEnableNotification 0000d978 gioDisableNotification 0000d9bc _SL_SelfTest_adcStartConversion_selChn 0000d9ec _SL_SelfTest_adcIsConversionComplete 0000da18 _SL_SelfTest_adcGetSingleData 0000da68 _SL_SelfTest_SRAM_RAD 0000daec _SL_HoldNClear_nError 0000db0c _SL_Approximate_value 0000db2c SL_FLAG_SET 0000db40 SL_FLAG_GET 0000db50 SL_FLAG_CLEAR 0000db70 vimParityErrorHandler 0000dcb0 esmLowInterrupt 0000dd40 esmHighInterrupt 0000def0 _pmuInit_ 0000df3c _pmuEnableCountersGlobal_ 0000df4c _pmuDisableCountersGlobal_ 0000df5c _pmuResetCycleCounter_ 0000df6c _pmuResetEventCounters_ 0000df7c _pmuResetCounters_ 0000df8c _pmuStartCounters_ 0000df94 _pmuStopCounters_ 0000df9c _pmuSetCountEvent_ 0000dfa8 _pmuGetCycleCount_ 0000dfb0 _pmuGetEventCount_ 0000dfbc _pmuGetOverflow_ 0000dfd0 SL_Set_nERROR 0000dfe0 SL_SW_Reset 0000dff0 SL_Clear_nERROR 0000e000 SL_CRC_Calculate 0000e079 __aeabi_memcpy 0000e079 __aeabi_memcpy4 0000e079 __aeabi_memcpy8 0000e079 memcpy 0000e115 __aeabi_memclr 0000e115 __aeabi_memclr4 0000e115 __aeabi_memclr8 0000e117 __aeabi_memset 0000e117 __aeabi_memset4 0000e117 __aeabi_memset8 0000e11d memset 0000e18f __TI_decompress_lzss 0000e1fb __aeabi_idiv0 0000e1fb __aeabi_ldiv0 0000e1fc __aeabi_idiv 0000e1fc __aeabi_idivmod 0000e250 _svc 0000e2a0 spiNotification 0000e2a4 spiEndNotification 0000e2a8 sciNotification 0000e2ac rtiNotification 0000e2b0 pwmNotification 0000e2b4 mibspiNotification 0000e2b8 mibspiGroupNotification 0000e2bc memoryPort1TestFailNotification 0000e2c0 memoryPort0TestFailNotification 0000e2c4 hetNotification 0000e2c8 gioNotification 0000e2cc esmGroup2Notification 0000e2d0 esmGroup1Notification 0000e2d4 edgeNotification 0000e2d8 dmaGroupANotification 0000e2dc dccNotification 0000e2e0 canStatusChangeNotification 0000e2e4 canMessageNotification 0000e2e8 canErrorNotification 0000e2ec adcNotification 0000e2f0 __aeabi_uidiv 0000e2f0 __aeabi_uidivmod 0000e341 __TI_auto_init_nobinit_nopinit 0000e385 memcmp 0000e3ab __TI_zero_init_nomemset 0000e3bd __TI_decompress_none 0000e3cb C$$EXIT 0000e3cb abort 0000e3d0 phantomInterrupt 0000edac ulFlashEndAddr 0000ee38 __TI_Handler_Table_Base 0000ee44 __TI_Handler_Table_Limit 0000ee50 __TI_CINIT_Base 0000ee60 __TI_CINIT_Limit 08000000 StackModeABT 08000400 StackModeFIQ 08000800 StackModeIRQ 08000c00 StackModeSVC 08001000 StackModeSYS 08001400 StackModeUND 08001b1c all1portmemories 08001b20 allpmosopenalgos 08001b24 maintaskcount 08001b28 periodicSTPassCount 08001b2c periodicSTFailCount 08001b30 allopenslicealgos 08001b38 allROMmemories 08001b40 allROMalgos 08001b48 allopenslice2portmemories 08001b58 allpmosopen2portmemories 08001b80 all1portalgos 08001bac all2portalgos 08001bdc all2portmemories 08001c18 sl_priv_flag_set 08001c58 resetReason 08001c5c initSTFailCount 08001c60 initSTPassCount 08001c64 static_ram 08001c6c failInfoPBISTSRAM 08001c7c pscon_errorforcing_app_callback 08001c7d cccmr4f_errorforcing_app_callback 08001c7e pscon_selftest_errorforcing_app_callback 08001c7f sram_radecode_diagnostics_app_callback 08001c80 fee_1bit_faultinject_app_callback 08001c81 fee_2bit_faultinject_app_callback 08001c82 sram_1bit_prof_faultinject_callback 08001c83 sram_2bit_faultinject_callback 08001c84 flash_2bit_faultinject_callback 08001c85 flash_addr_par_faultinject_callback 08001c86 pll1_slip_faultinject_callback 08001c87 pll2_slip_faultinject_callback 08001c88 unknowncallback 08001c8c callbkParam1 08001c90 callbkParam2 08001c94 callbkParam3 08001c98 callbkParam4 08001ca0 sramEccTestBuff 08001cc0 crcAtInit_VIMRAM 08001cc8 crcAtInit_FLASH 08001cd0 crcAtInit_FEE 08001cd8 crcAtInit_StaticRAM 08001ce8 vimTestFlag 08001cec g_L2L3_read_reserved_word 0800c300 ulPROFILEEndAddr 0800c300 ulPROFILEStartAddr 08014000 ulLOGEndAddr 08014000 ulLOGStartAddr ffffffff __TI_pprof_out_hndl ffffffff __TI_prof_data_size ffffffff __TI_prof_data_start ffffffff __binit__ ffffffff __c_args__ ffffffff binit UNDEFED SHT$$INIT_ARRAY$$Base UNDEFED SHT$$INIT_ARRAY$$Limit UNDEFED _system_post_cinit [543 symbols]
  • i added
       .intvecs : {} > VECTORS
    in        SL_TMS570LS1227_NoOS_sys_link.cmd   and this solve the first error #10247
    is it true what i did??
  • could anyone help me in solving the other warning #188-D pointless comparison of unsigned integer with zero
    Here is my code
  • Dear Rahul,
    how to make sure that the library is working fine
    how to see the output of the test?
  • Your resolution of the warning by adding a section explicitly for the interrupt vectors seems to be correct.
    Add --verbose_diagnostics to your build.  That will help you see the problem.  For more discussion on diagnostics and how to handle them, see the diagnostics section of this presentation on the Wiki. For specific understanding of Compiler warning please post the questions in CCS forums as you can see here.
    https://e2e.ti.com/support/tools/ccs/f/81/t/271821
    The SDL has a user guide in the docs folder with SafeTIDiagnosticLibrary-User'sGuide-v2.4.0.chm file. IF you look for demo in the document. It described the building and running demo.
    Please refer to my response here and the blog post below for additional insights:
    https://e2e.ti.com/support/microcontrollers/hercules/f/312/p/832664/3080449
    https://e2e.ti.com/support/archive/launchyourdesign/m/boosterpackcontest/666452
    The example is also design to profile and logs the test fails and passing using the variables periodicSTPassCount, periodicSTFailCount  and log the profiling in Profile.txt when the compiler macro FUNCTION_PROFILING_ENABLED
    Rahul
