TM4C1294KCPDT: TM4C for IoT applicaiton
Part Number: TM4C1294KCPDT
We have been using the TiVa series for a while, and are now working on a new thing with IoT. Is there a device similar to the TM4C1294 that also meets as many of the below requirements as possible?
  1. If possible, we would like to reuse codes from our TM4C1294 projects
  2. Needs at least 8 ADCs, hopefully 14-bit or higher resolution
  3. Needs USB, Ethernet, WiFi and hopefully Bluetooth
  4. WiFi can be on module so that we can pass CE or FCC easier
Thanks for the help!
Adam
  • Hi Adam,
      I did some search from the TI product webpage and find the SimpleLink wireless and wired MCUs. http://www.ti.com/microcontrollers/simplelink-mcus/products.html#p945=14 that may meet partially your requirements (i.e. 14bit ADC resolution and M4F, Wifi ). These products do not have USB as far as I know. I will suggest you search the TI product page and post your questions to the SimpleLink forum for additional questions.
      Is there any reason why you cannot continue with TM4C129x? If you 14bit ADC is what you require then you can use an external 14-bit ADC with the TM4C129. Same thing that you can the TM4C129 as the host MCU to interface with an external Wifi module to extend your capability.
