Hello, I've been fighting with the Software Angle Generator for quite some time. I made this topic previously: https://e2e.ti.com/support/microcontrollers/hercules/f/312/t/826325
In that topic I had thought I had figured it out, only to later find out I was making an error.
I still can not get the SWAG to function properly. Here is my current code:
TOOTH_PIN .equ 2
OUT_PIN .equ 18
ACTUAL_TEETH .equ 58
MISSING_TEETH .equ 2
TEETH_SKIP .equ ACTUAL_TEETH - 1
STEP_FACTOR .equ 8
GAP_START .equ ((STEP_FACTOR * (ACTUAL_TEETH - 1)) + 1)
GAP_END .equ (((STEP_FACTOR * (ACTUAL_TEETH + MISSING_TEETH )) - 1))
START BR { cond_addr=START_00,event=NOCOND};0
START_00 APCNT { type=FALL2FALL,control=OFF,prv=OFF,period=0};1
START_0 BR { cond_addr=WAIT_FOR_LOW,event=NOCOND};2
WAIT_FOR_LOW BR { next=START,cond_addr=WFL1,pin=2,event=HIGH};3
WFL1 MOV64 { next=START,remote=START_0,cond_addr=CALC_PERIOD,comp_mode=ECMP,reg=NONE};4
; FIFO holding last three measurements (S01 is oldest, S03 is newest)
CALC_PERIOD BR { next=START,cond_addr=S01,pin=2,event=FALL};5
S01 ADD {src1=REM, src2=ZERO, dest=IMM, data=999999, hr_data=0, remote=S02} ;N2 = S02 + 0
S02 ADD {src1=REM, src2=ZERO, dest=IMM, data=999999, hr_data=0, remote=S03} ;N1 = S03 + 0
S03 ADD {src1=T, src2=ZERO, dest=IMM, data=999999, hr_data=0} ;N = T + 0
S04 MOV64 { next=START,remote=START_0,cond_addr=COMPARE_PERIOD,comp_mode=ECMP,reg=NONE};
COMPARE_PERIOD ADD { src1=REM,src2=ZERO,dest=R,remote=S01,data=0}; R = N2
S05 ADD { src1=REM,src2=R,dest=R,remote=S02,data=0}; R = N2 + R
S06 ADD { src1=R,src2=ZERO,dest=NONE,rdest=REM,remote=S07,data=0};12
S07 MCMP { en_pin_action=ON,cond_addr=BRANCH_0,pin=4,order=REG_GE_DATA,action=SET,reg=T,data=99999,hr_data=0};13
S08 MOV64 { next=START,remote=START_0,cond_addr=CALC_PERIOD,comp_mode=ECMP,reg=NONE};14
BRANCH_0 MOV64 { next=START,remote=START_0,cond_addr=SWAG_PREP1,comp_mode=ECMP,reg=NONE};15
SWAG_PREP1 BR { next=START,cond_addr=SP1,pin=TOOTH_PIN,event=HIGH};16
SP1 MOV64 { next=START,remote=START_0,cond_addr=SWAG_PREP2,comp_mode=ECMP,reg=NONE};
SWAG_PREP2 BR { next=START,cond_addr=SP20,pin=TOOTH_PIN,event=FALL};18
SP20 ADD { src1=ZERO,src2=ZERO,dest=R,data=0};
SP200 MOV64 { remote=START,cond_addr=START_0,comp_mode=ECMP,reg=NONE};
SP21 MOV64 { next=START,remote=START_0,cond_addr=WAIT_ONE_REV,comp_mode=ECMP,reg=NONE};
WAIT_ONE_REV ECNT { pin=TOOTH_PIN,event=FALL,reg=R,data=0};22
WOR0 MCMP { next=START,cond_addr=WOR00,pin=0,order=REG_GE_DATA,reg=R,data=TEETH_SKIP};
WOR00 MOV64 { remote=START,cond_addr=START_00,comp_mode=ECMP,reg=NONE};
WOR1 MOV64 { next=START,remote=START_0,cond_addr=SWAG,comp_mode=ECMP,reg=NONE};
; Angle Counter
SWAG SCNT { step=STEP_FACTOR,gapstart=GAP_START,data=0}; 26
SG_01 ACNT { edge=FALLING,irq = ON, gapend=GAP_END,data=0};27
OUT20 ACMP { next=START,en_pin_action=ON,cond_addr=OUT20_PULSE_LOW,pin=OUT_PIN,action=SET,reg=B,data=0};22
; Switch OUT20
OUT20_PULSE_LOW MOV64 { next=START,remote=OUT20,en_pin_action=ON,cond_addr=OUT20_PULSE_HIGH,pin=OUT_PIN,comp_mode=ECMP,action=CLEAR,reg=B,data=0};
OUT20_PULSE_HIGH MOV64 { next=START,remote=OUT20,en_pin_action=ON,cond_addr=OUT20_PULSE_LOW, pin=OUT_PIN,comp_mode=ECMP,action=SET, reg=B,data=0};
Here is the code with some description of what it's doing:
And this is what my results look like:
As you can see, the results are incorrect.
I'm hoping someone can point me in the right direction and help me to figure out how to configure the SWAG properly. Has anyone been able to get it to work?
