Part Number: TMS570LS3137
Could you please let us know that the issue reported in the below link has been fixed or not?
https://e2e.ti.com/support/microcontrollers/hercules/f/312/p/743689/2746334#2746334
Hi QJ,
I have checked in MCAL 6.0 release notes and could not find this issue in bug fixes. Could you please confirm the MCAL version containing this fix.
It means then SPI channel 5 will not work properly with Autosar MCAL driver in TMS570LS3137. Does my understanding is correct?
When can we expect the fix for this issue in MCAL driver?.
Untill then, could you please propose any alternate solution or quick fix for this issue?
Manually setting bit 10 and bit 11 in the EB generated files should solve this problem temporarily correct?
The SPI5 SIMO[0] and SOMI[0] will not work properly with AutoSar MCAL driver. The bit 10 and bit 11 of SPIPC0 register have to be set manually.
Manually setting bit 10 and bit 11 in the EB generated files should solve this problem.
