Part Number: LAUNCHXL2-570LC43
Other Parts Discussed in Thread: HALCOGEN,
I used HALCoGen to generate software code to communicate 2 LAUNCHXL2-570LC43 MCUs through MIBSPI3, the 2 MCUs transfer and receive an array of 128 word(16-bits).
Master MCU generates SPI clock and output data on MOSI line for 128 element of the array just fine (checked with oscilloscope), but at the same time Slave MCU only output the first word of the data (16-bits) and the remaining is '0's', I checked Slave code every time the master triggers communication to send 128 word the slave sends only first element in the array and another trigger from the master the slave sends the second element in the array and so on; so each time Master MCU sends 128 element, it receives 1 element only from the slave.
In Slave code this condition "if(mibspiIsTransferComplete(mibspiREG3, 0)==1)" become true after master sends the array of 128 element 128 times.
In master code I didn't use automatic chip select.
here is the Master configuration:
/** @file HL_mibspi.c
* @brief MIBSPI Driver Implementation File
* @date 11-Dec-2018
* @version 04.07.01
* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
#include "HL_mibspi.h"
#include "HL_sys_vim.h"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_001 */
/* DesignId : MIBSPI_DesignId_001 */
/* Requirements : HL_CONQ_MIBSPI_SR9 */
/** @fn void mibspiInit(void)
* @brief Initializes the MIBSPI Driver
* This function initializes the MIBSPI module.
uint32 i ;
/* USER CODE BEGIN (2) */
/* USER CODE END */
/** @b initialize @b MIBSPI3 */
/** bring MIBSPI out of reset */
mibspiREG3->GCR0 = 0U;
mibspiREG3->GCR0 = 1U;
/** enable MIBSPI3 multibuffered mode and enable buffer RAM */
mibspiREG3->MIBSPIE = (mibspiREG3->MIBSPIE & 0xFFFFFFFEU) | 1U;
/** MIBSPI3 master mode and clock configuration */
mibspiREG3->GCR1 = (mibspiREG3->GCR1 & 0xFFFFFFFCU) | ((uint32)((uint32)1U << 1U) /* CLOKMOD */
| 1U); /* MASTER */
/** MIBSPI3 enable pin configuration */
mibspiREG3->INT0 = (mibspiREG3->INT0 & 0xFEFFFFFFU) | (uint32)((uint32)0U << 24U); /* ENABLE HIGHZ */
/** - Delays */
mibspiREG3->DELAY = (uint32)((uint32)5U << 24U) /* C2TDELAY */
| (uint32)((uint32)0U << 16U) /* T2CDELAY */
| (uint32)((uint32)0U << 8U) /* T2EDELAY */
| (uint32)((uint32)0U << 0U); /* C2EDELAY */
/** - Data Format 0 */
mibspiREG3->FMT0 = (uint32)((uint32)0U << 24U) /* wdelay */
| (uint32)((uint32)0U << 23U) /* parity Polarity */
| (uint32)((uint32)0U << 22U) /* parity enable */
| (uint32)((uint32)0U << 21U) /* wait on enable */
| (uint32)((uint32)0U << 20U) /* shift direction */
| (uint32)((uint32)0U << 17U) /* clock polarity */
| (uint32)((uint32)0U << 16U) /* clock phase */
| (uint32)((uint32)74U << 8U) /* baudrate prescale */
| (uint32)((uint32)16U << 0U); /* data word length */
/** - Data Format 1 */
mibspiREG3->FMT1 = (uint32)((uint32)0U << 24U) /* wdelay */
| (uint32)((uint32)2U << 8U) /* baudrate prescale */
/** - Data Format 2 */
mibspiREG3->FMT2 = (uint32)((uint32)0U << 24U) /* wdelay */
/** - Data Format 3 */
mibspiREG3->FMT3 = (uint32)((uint32)0U << 24U) /* wdelay */
/** - Default Chip Select */
mibspiREG3->DEF = (uint32)(0x02U);
/** - wait for buffer initialization complete before accessing MibSPI registers */
/*SAFETYMCUSW 28 D MR:NA <APPROVED> "Hardware status bit read check" */
while ((mibspiREG3->FLG & 0x01000000U) != 0U)
} /* Wait */
/** enable MIBSPI RAM Parity */
mibspiREG3->PAR_ECC_CTRL = (mibspiREG3->PAR_ECC_CTRL & 0xFFFFFFF0U) | (0x0000000AU);
/** - initialize transfer groups */
mibspiREG3->TGCTRL[0U] = (uint32)((uint32)1U << 30U) /* oneshot */
| (uint32)((uint32)0U << 29U) /* pcurrent reset */
| (uint32)((uint32)TRG_ALWAYS << 20U) /* trigger event */
| (uint32)((uint32)TRG_DISABLED << 16U) /* trigger source */
| (uint32)((uint32)0U << 8U); /* start buffer */
mibspiREG3->TGCTRL[1U] = (uint32)((uint32)0U << 30U) /* oneshot */
| (uint32)((uint32)TRG_NEVER << 20U) /* trigger event */
| (uint32)((uint32)128U << 8U); /* start buffer */
mibspiREG3->TGCTRL[2U] = (uint32)((uint32)0U << 30U) /* oneshot */
| (uint32)((uint32)(128U+0U) << 8U); /* start buffer */
mibspiREG3->TGCTRL[3U] = (uint32)((uint32)1U << 30U) /* oneshot */
| (uint32)((uint32)(128U+0U+0U) << 8U); /* start buffer */
mibspiREG3->TGCTRL[4U] = (uint32)((uint32)1U << 30U) /* oneshot */
| (uint32)((uint32)(128U+0U+0U+0U) << 8U); /* start buffer */
mibspiREG3->TGCTRL[5U] = (uint32)((uint32)1U << 30U) /* oneshot */
| (uint32)((uint32)(128U+0U+0U+0U+0U) << 8U); /* start buffer */
mibspiREG3->TGCTRL[6U] = (uint32)((uint32)1U << 30U) /* oneshot */
| (uint32)((uint32)(128U+0U+0U+0U+0U+0U) << 8U); /* start buffer */
mibspiREG3->TGCTRL[7U] = (uint32)((uint32)1U << 30U) /* oneshot */
| (uint32)((uint32)(128U+0U+0U+0U+0U+0U+0U) << 8U); /* start buffer */
mibspiREG3->TGCTRL[8U] = (uint32)(128U+0U+0U+0U+0U+0U+0U+0U) << 8U;
mibspiREG3->LTGPEND = (mibspiREG3->LTGPEND & 0xFFFF00FFU) | (uint32)(((uint32)(128U+0U+0U+0U+0U+0U+0U+0U)-1U) << 8U);
/** - initialize buffer ram */
i = 0U;
#if (128U > 0U)
#if (128U > 1U)
while (i < (128U-1U))
mibspiRAM3->tx[i].control = (uint16)((uint16)4U << 13U) /* buffer mode */
| (uint16)((uint16)0U << 12U) /* chip select hold */
| (uint16)((uint16)0U << 10U) /* enable WDELAY */
| (uint16)((uint16)1U << 11U) /* lock transmission */
| (uint16)((uint16)0U << 8U) /* data format */
| ((uint16)(~((uint16)0x02U ^ (uint16)CS_1)) & (uint16)0x00FFU); /* chip select */
i++;
#endif
i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
while (i < ((128U+0U)-1U))
| (uint16)((uint16)0U << 11U) /* lock transmission */
| ((uint16)(~((uint16)0x02U ^ (uint16)CS_NONE)) & (uint16)0x00FFU); /* chip select */
i++;
#endif
i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
while (i < ((128U+0U+0U)-1U))
i++;
#endif
i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
while (i < ((128U+0U+0U+0U)-1U))
i++;
#endif
i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
while (i < ((128U+0U+0U+0U+0U)-1U))
i++;
#endif
i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
while (i < ((128U+0U+0U+0U+0U+0U)-1U))
i++;
#endif
i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
while (i < ((128U+0U+0U+0U+0U+0U+0U)-1U))
i++;
#endif
i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
while (i < ((128U+0U+0U+0U+0U+0U+0U+0U)-1U))
i++;
#endif
i++;
#endif
/** - set interrupt levels */
mibspiREG3->LVL = (uint32)((uint32)0U << 9U) /* TXINT */
| (uint32)((uint32)0U << 8U) /* RXINT */
| (uint32)((uint32)0U << 6U) /* OVRNINT */
| (uint32)((uint32)0U << 4U) /* BITERR */
| (uint32)((uint32)0U << 3U) /* DESYNC */
| (uint32)((uint32)0U << 2U) /* PARERR */
| (uint32)((uint32)0U << 1U) /* TIMEOUT */
| (uint32)((uint32)0U << 0U); /* DLENERR */
/** - clear any pending interrupts */
mibspiREG3->FLG |= 0xFFFFU;
/** - enable interrupts */
mibspiREG3->INT0 = (mibspiREG3->INT0 & 0xFFFF0000U)
/** @b initialize @b MIBSPI3 @b Port */
/** - MIBSPI3 Port output values */
mibspiREG3->PC3 = (uint32)((uint32)0U << 0U) /* SCS[0] */
| (uint32)((uint32)1U << 1U) /* SCS[1] */
| (uint32)((uint32)0U << 2U) /* SCS[2] */
| (uint32)((uint32)0U << 3U) /* SCS[3] */
| (uint32)((uint32)0U << 4U) /* SCS[4] */
| (uint32)((uint32)0U << 5U) /* SCS[5] */
| (uint32)((uint32)0U << 8U) /* ENA */
| (uint32)((uint32)0U << 9U) /* CLK */
| (uint32)((uint32)0U << 10U) /* SIMO */
| (uint32)((uint32)0U << 11U); /* SOMI */
/** - MIBSPI3 Port direction */
mibspiREG3->PC1 = (uint32)((uint32)0U << 0U) /* SCS[0] */
| (uint32)((uint32)1U << 9U) /* CLK */
| (uint32)((uint32)1U << 10U) /* SIMO */
/** - MIBSPI3 Port open drain enable */
mibspiREG3->PC6 = (uint32)((uint32)0U << 0U) /* SCS[0] */
| (uint32)((uint32)0U << 1U) /* SCS[1] */
/** - MIBSPI3 Port pullup / pulldown selection */
mibspiREG3->PC8 = (uint32)((uint32)1U << 0U) /* SCS[0] */
| (uint32)((uint32)1U << 2U) /* SCS[2] */
| (uint32)((uint32)1U << 3U) /* SCS[3] */
| (uint32)((uint32)1U << 4U) /* SCS[4] */
| (uint32)((uint32)1U << 5U) /* SCS[5] */
| (uint32)((uint32)1U << 8U) /* ENA */
| (uint32)((uint32)1U << 11U); /* SOMI */
/** - MIBSPI3 Port pullup / pulldown enable*/
mibspiREG3->PC7 = (uint32)((uint32)1U << 0U) /* SCS[0] */
/* MIBSPI3 set all pins to functional */
mibspiREG3->PC0 = (uint32)((uint32)0U << 0U) /* SCS[0] */
/** - Finally start MIBSPI3 */
mibspiREG3->GCR1 = (mibspiREG3->GCR1 & 0xFEFFFFFFU) | 0x01000000U;
/* USER CODE BEGIN (3) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_002 */
/* DesignId : */
/* Requirements : */
/** @fn boolean mibspiIsBuffInitialized(mibspiBASE_t *mibspi)
* @brief Checks if Mibspi buffer is initialized.
* @param[in] mibspi - Mibspi module base address
* This function brings Mibspi module out of reset.
volatile boolean status;
/* USER CODE BEGIN (4) */
/* USER CODE END */
if((mibspi->FLG & 0x01000000U) != 0x01000000U)
status = TRUE;
else
status = FALSE;
/* USER CODE BEGIN (5) */
/* USER CODE END */
return (status);
/* SourceId : MIBSPI_SourceId_003 */
/* DesignId : */
/** @fn void mibspiOutofReset(mibspiBASE_t *mibspi)
* @brief Bring Mibspi Module Out of Reset
/* USER CODE BEGIN (6) */
/* USER CODE END */
mibspi->GCR0 |= 0x1U;
/* USER CODE BEGIN (7) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_004 */
/* DesignId : */
/** @fn void mibspiReset(mibspiBASE_t *mibspi)
* @brief Take Mibspi Module to Reset
* This function takes Mibspi module to reset.
/* USER CODE BEGIN (8) */
/* USER CODE END */
mibspi->GCR0 = 0x0U;
/* USER CODE BEGIN (9) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_005 */
/* DesignId : MIBSPI_DesignId_002 */
/* Requirements : HL_CONQ_MIBSPI_SR10 */
/** @fn void mibspiSetFunctional(mibspiBASE_t *mibspi, uint32 port)
* @brief Change functional behavior of pins at runtime.
* @param[in] mibspi - mibspi module base address
* @param[in] port - Value to write to PC0 register
* Change the value of the PC0 register at runtime, this allows to
* dynamically change the functionality of the MIBSPI pins between functional
* and GIO mode.
/* USER CODE BEGIN (10) */
/* USER CODE END */
mibspi->PC0 = port;
/* USER CODE BEGIN (11) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_006 */
/* DesignId : MIBSPI_DesignId_003 */
/* Requirements : HL_CONQ_MIBSPI_SR11 */
/** @fn void mibspiSetData(mibspiBASE_t *mibspi, uint32 group, uint16 * data)
* @brief Set Buffer Data
* @param[in] mibspi - Spi module base address
* @param[in] group - Transfer group (0..7)
* @param[in] data - new data for transfer group
* This function updates the data for the specified transfer group,
* the length of the data must match the length of the transfer group.
/* USER CODE BEGIN (12) */
/* USER CODE END */
mibspiRAM_t *ram = mibspi == mibspiREG1 ? mibspiRAM1 :
(mibspi == mibspiREG2 ? mibspiRAM2 :
(mibspi == mibspiREG3 ? mibspiRAM3 :
(mibspi == mibspiREG4 ? mibspiRAM4 : mibspiRAM5)));
uint32 start = (mibspi->TGCTRL[group] >> 8U) & 0xFFU;
uint32 end = (group == 7U) ? (((mibspi->LTGPEND & 0x00007F00U) >> 8U) + 1U) : ((mibspi->TGCTRL[group+1U] >> 8U) & 0xFFU);
if (end == 0U) {end = 128U;}
while (start < end)
/*SAFETYMCUSW 45 D MR:21.1 <APPROVED> "Valid non NULL input parameters are only allowed in this driver" */
ram->tx[start].data = *data;
data++;
start++;
/* USER CODE BEGIN (13) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_007 */
/* DesignId : MIBSPI_DesignId_004 */
/* Requirements : HL_CONQ_MIBSPI_SR12 */
/** @fn void mibspiGetData(mibspiBASE_t *mibspi, uint32 group, uint16 * data)
* @brief Retrieves Buffer Data from receive buffer
* @param[out] data - pointer to data array
* @return error flags from data buffer, if there was a receive error on
* one of the buffers this will be reflected in the return value.
* This function transfers the data from the specified transfer group receive
* buffers to the data array, the length of the data must match the length
* of the transfer group.
uint32 mibspiGetData(mibspiBASE_t *mibspi, uint32 group, uint16 * data)
/* USER CODE BEGIN (14) */
/* USER CODE END */
uint16 mibspiFlags = 0U;
uint32 ret;
while (start < end)
mibspiFlags |= ram->rx[start].flags;
*data = ram->rx[start].data;
data++;
start++;
ret = ((uint32)mibspiFlags >> 8U) & 0x5FU;
/* USER CODE BEGIN (15) */
/* USER CODE END */
return ret;
/* SourceId : MIBSPI_SourceId_008 */
/* DesignId : MIBSPI_DesignId_005 */
/* Requirements : HL_CONQ_MIBSPI_SR13 */
/** @fn void mibspiTransfer(mibspiBASE_t *mibspi, uint32 group)
* @brief Transmit Transfer Group
* Initiates a transfer for the specified transfer group.
/* USER CODE BEGIN (16) */
/* USER CODE END */
mibspi->TGCTRL[group] |= 0x80000000U;
/* USER CODE BEGIN (17) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_009 */
/* DesignId : MIBSPI_DesignId_006 */
/* Requirements : HL_CONQ_MIBSPI_SR14 */
/** @fn boolean mibspiIsTransferComplete(mibspiBASE_t *mibspi, uint32 group)
* @brief Check for Transfer Group Ready
* @return TRUE is transfer complete, otherwise FALSE.
* Checks to see if the transfer for the specified transfer group
* has finished.
boolean status;
/* USER CODE BEGIN (18) */
/* USER CODE END */
if(((((mibspi->TGINTFLG & 0xFFFF0000U) >> 16U)>> group) & 1U) == 1U)
mibspi->TGINTFLG = (mibspi->TGINTFLG & 0x0000FFFFU) | ((uint32)((uint32)1U << group) << 16U);
status = TRUE;
else
status = FALSE;
/* USER CODE BEGIN (19) */
/* USER CODE END */
return (status);
/* SourceId : MIBSPI_SourceId_010 */
/* DesignId : MIBSPI_DesignId_009 */
/* Requirements : HL_CONQ_MIBSPI_SR17 */
/** @fn void mibspiEnableLoopback(mibspiBASE_t *mibspi, loopBackType_t Loopbacktype)
* @brief Enable Loopback mode for self test
* @param[in] Loopbacktype - Digital or Analog
* This function enables the Loopback mode for self test.
/* USER CODE BEGIN (20) */
/* USER CODE END */
/* Clear Loopback incase enabled already */
mibspi->IOLPKTSTCR = 0U;
/* Enable Loopback either in Analog or Digital Mode */
mibspi->IOLPKTSTCR = (uint32)0x00000A00U
| (uint32)((uint32)Loopbacktype << 1U);
/* USER CODE BEGIN (21) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_011 */
/* DesignId : MIBSPI_DesignId_010 */
/* Requirements : HL_CONQ_MIBSPI_SR18 */
/** @fn void mibspiDisableLoopback(mibspiBASE_t *mibspi)
* This function disable the Loopback mode.
/* USER CODE BEGIN (22) */
/* USER CODE END */
/* Disable Loopback Mode */
mibspi->IOLPKTSTCR = 0x00000500U;
/* USER CODE BEGIN (23) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_012 */
/* DesignId : MIBSPI_DesignId_011 */
/* Requirements : HL_CONQ_MIBSPI_SR21 */
/** @fn void mibspiPmodeSet(mibspiBASE_t *mibspi, mibspiPmode_t Pmode, mibspiDFMT_t DFMT)
* @brief Set the Pmode for the selected Data Format register
* @param[in] Pmode - Mibspi Parellel mode
* PMODE_NORMAL
* PMODE_2_DATALINE
* PMODE_4_DATALINE
* PMODE_8_DATALINE
* @param[in] DFMT - Mibspi Data Format register
* DATA_FORMAT0
* DATA_FORMAT1
* DATA_FORMAT2
* DATA_FORMAT3
* This function sets the Pmode for the selected Data Format register.
uint32 pmctrl_reg;
/* Set the Pmode for the selected Data Format register */
pmctrl_reg = (mibspi->PMCTRL & (~(uint32)((uint32)0xFFU << (8U * DFMT))));
mibspi->PMCTRL = (pmctrl_reg | (uint32)((uint32)Pmode << ((8U * DFMT))));
/* SourceId : MIBSPI_SourceId_013 */
/* DesignId : MIBSPI_DesignId_007 */
/* Requirements : HL_CONQ_MIBSPI_SR15 */
/** @fn void mibspiEnableGroupNotification(mibspiBASE_t *mibspi, uint32 group, uint32 level)
* @brief Enable Transfer Group interrupt
* @param[in] level - Interrupt level
* This function enables the transfer group finished interrupt.
/* USER CODE BEGIN (24) */
/* USER CODE END */
if (level != 0U)
mibspi->TGITLVST = (mibspi->TGITLVST & 0x0000FFFFU) | (uint32)((uint32)((uint32)1U << group) << 16U);
else
mibspi->TGITLVCR = (mibspi->TGITLVCR & 0x0000FFFFU) | (uint32)((uint32)((uint32)1U << group) << 16U);
mibspi->TGITENST = (mibspi->TGITENST & 0x0000FFFFU) | (uint32)((uint32)((uint32)1U << group) << 16U);
/* USER CODE BEGIN (25) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_014 */
/* DesignId : MIBSPI_DesignId_008 */
/* Requirements : HL_CONQ_MIBSPI_SR16 */
/** @fn void mibspiDisableGroupNotification(mibspiBASE_t *mibspi, uint32 group)
* @brief Disable Transfer Group interrupt
* This function disables the transfer group finished interrupt.
/* USER CODE BEGIN (26) */
/* USER CODE END */
mibspi->TGITENCR = (mibspi->TGITENCR & 0x0000FFFFU) | (uint32)((uint32)((uint32)1U << group) << 16U);
/* USER CODE BEGIN (27) */
/* USER CODE END */
/* SourceId : MIBSPI_SourceId_017 */
/* DesignId : MIBSPI_DesignId_012 */
/* Requirements : HL_CONQ_MIBSPI_SR24 */
/** @fn void mibspi3GetConfigValue(mibspi_config_reg_t *config_reg, config_value_type_t type)
* @brief Get the initial or current values of the configuration registers
* @param[in] *config_reg: pointer to the struct to which the initial or current
* value of the configuration registers need to be stored
* @param[in] type: whether initial or current value of the configuration registers need to be stored
* - InitialValue: initial value of the configuration registers will be stored
* in the struct pointed by config_reg
* - CurrentValue: initial value of the configuration registers will be stored
* This function will copy the initial or current value (depending on the parameter 'type')
* of the configuration registers to the struct pointed by config_reg
if (type == InitialValue)
config_reg->CONFIG_GCR1 = MIBSPI3_GCR1_CONFIGVALUE;
config_reg->CONFIG_INT0 = MIBSPI3_INT0_CONFIGVALUE;
config_reg->CONFIG_LVL = MIBSPI3_LVL_CONFIGVALUE;
config_reg->CONFIG_PCFUN = MIBSPI3_PCFUN_CONFIGVALUE;
config_reg->CONFIG_PCDIR = MIBSPI3_PCDIR_CONFIGVALUE;
config_reg->CONFIG_PCPDR = MIBSPI3_PCPDR_CONFIGVALUE;
config_reg->CONFIG_PCDIS = MIBSPI3_PCDIS_CONFIGVALUE;
config_reg->CONFIG_PCPSL = MIBSPI3_PCPSL_CONFIGVALUE;
config_reg->CONFIG_DELAY = MIBSPI3_DELAY_CONFIGVALUE;
config_reg->CONFIG_FMT0 = MIBSPI3_FMT0_CONFIGVALUE;
config_reg->CONFIG_FMT1 = MIBSPI3_FMT1_CONFIGVALUE;
config_reg->CONFIG_FMT2 = MIBSPI3_FMT2_CONFIGVALUE;
config_reg->CONFIG_FMT3 = MIBSPI3_FMT3_CONFIGVALUE;
config_reg->CONFIG_MIBSPIE = MIBSPI3_MIBSPIE_CONFIGVALUE;
config_reg->CONFIG_LTGPEND = MIBSPI3_LTGPEND_CONFIGVALUE;
config_reg->CONFIG_TGCTRL[0U] = MIBSPI3_TGCTRL0_CONFIGVALUE;
config_reg->CONFIG_TGCTRL[1U] = MIBSPI3_TGCTRL1_CONFIGVALUE;
config_reg->CONFIG_TGCTRL[2U] = MIBSPI3_TGCTRL2_CONFIGVALUE;
config_reg->CONFIG_TGCTRL[3U] = MIBSPI3_TGCTRL3_CONFIGVALUE;
config_reg->CONFIG_TGCTRL[4U] = MIBSPI3_TGCTRL4_CONFIGVALUE;
config_reg->CONFIG_TGCTRL[5U] = MIBSPI3_TGCTRL5_CONFIGVALUE;
config_reg->CONFIG_TGCTRL[6U] = MIBSPI3_TGCTRL6_CONFIGVALUE;
config_reg->CONFIG_TGCTRL[7U] = MIBSPI3_TGCTRL7_CONFIGVALUE;
config_reg->CONFIG_PAR_ECC_CTRL = MIBSPI3_PAR_ECC_CTRL_CONFIGVALUE;
else
/*SAFETYMCUSW 134 S MR:12.2 <APPROVED> "Register read back support" */
config_reg->CONFIG_GCR1 = mibspiREG3->GCR1;
config_reg->CONFIG_INT0 = mibspiREG3->INT0;
config_reg->CONFIG_LVL = mibspiREG3->LVL;
config_reg->CONFIG_PCFUN = mibspiREG3->PC0;
config_reg->CONFIG_PCDIR = mibspiREG3->PC1;
config_reg->CONFIG_PCPDR = mibspiREG3->PC6;
config_reg->CONFIG_PCDIS = mibspiREG3->PC7;
config_reg->CONFIG_PCPSL = mibspiREG3->PC8;
config_reg->CONFIG_DELAY = mibspiREG3->DELAY;
config_reg->CONFIG_FMT0 = mibspiREG3->FMT0;
config_reg->CONFIG_FMT1 = mibspiREG3->FMT1;
config_reg->CONFIG_FMT2 = mibspiREG3->FMT2;
config_reg->CONFIG_FMT3 = mibspiREG3->FMT3;
config_reg->CONFIG_MIBSPIE = mibspiREG3->MIBSPIE;
config_reg->CONFIG_LTGPEND = mibspiREG3->LTGPEND;
config_reg->CONFIG_TGCTRL[0U] = mibspiREG3->TGCTRL[0U];
config_reg->CONFIG_TGCTRL[1U] = mibspiREG3->TGCTRL[1U];
config_reg->CONFIG_TGCTRL[2U] = mibspiREG3->TGCTRL[2U];
config_reg->CONFIG_TGCTRL[3U] = mibspiREG3->TGCTRL[3U];
config_reg->CONFIG_TGCTRL[4U] = mibspiREG3->TGCTRL[4U];
config_reg->CONFIG_TGCTRL[5U] = mibspiREG3->TGCTRL[5U];
config_reg->CONFIG_TGCTRL[6U] = mibspiREG3->TGCTRL[6U];
config_reg->CONFIG_TGCTRL[7U] = mibspiREG3->TGCTRL[7U];
config_reg->CONFIG_PAR_ECC_CTRL = mibspiREG3->PAR_ECC_CTRL;
here is the Slave configuration:
* @date 11-Dec-2018
* @version 04.07.01
* are met:
* distribution.
/* USER CODE END */
/* USER CODE END */
uint32 i ;
/* USER CODE END */
mibspiREG3->GCR1 = (mibspiREG3->GCR1 & 0xFFFFFFFCU) | ((uint32)((uint32)0U << 1U) /* CLOKMOD */
| 0U); /* MASTER */
} /* Wait */
i = 0U;
i++;
#endif
i++;
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#endif
i++;
#endif
/* USER CODE END */
/* DesignId : */
/* USER CODE END */
status = TRUE;
else
status = FALSE;
/* USER CODE END */
return (status);
/* DesignId : */
/* USER CODE END */
/* USER CODE END */
/* DesignId : */
/* USER CODE END */
/* USER CODE END */
* and GIO mode.
/* USER CODE END */
/* USER CODE END */
/* USER CODE END */
data++;
start++;
/* USER CODE END */
/* USER CODE END */
uint32 ret;
data++;
start++;
/* USER CODE END */
/* USER CODE END */
/* USER CODE END */
* has finished.
boolean status;
/* USER CODE END */
status = TRUE;
else
status = FALSE;
/* USER CODE END */
return (status);
/* USER CODE END */
/* USER CODE END */
/* USER CODE END */
/* USER CODE END */
* PMODE_NORMAL
* PMODE_2_DATALINE
* PMODE_4_DATALINE
* PMODE_8_DATALINE
* DATA_FORMAT0
* DATA_FORMAT1
* DATA_FORMAT2
* DATA_FORMAT3
uint32 pmctrl_reg;
/* USER CODE END */
else
/* USER CODE END */
/* USER CODE END */
/* USER CODE END */
else
if(SPI_Module[SPI3].MasterSlave!=SLAVE)
// Master puts CS to low
mibspiREG3->PC3&= ~(0x00000002U);
mibspiTransfer(mibspiREG3, 0);
while (1)
// Master puts CS to high
mibspiREG3->PC3|= (0x00000002U);
mibspiGetData(mibspiREG3, 0, (uint16_t *) SPI_Module[SPI3].DataReceivedArray);
ArraytoStruct_Ver2(SPI_Module[SPI3].DataReceivedArray);
StructtoArray_Ver2(SPI_Module[SPI3].DataSentArray);
mibspiSetData(mibspiREG3, 0, (uint16_t *) SPI_Module[SPI3].DataSentArray);
} // End of main()
