TMS570LC4357: EMC or EMI environment test and certificate
Part Number: TMS570LC4357
Dear all,
Could anyone share some info regarding the CPU, and preferbly the complete Hercules HDK compability of handeling electromagnetic fields?
Is there any certificate, tests or explaination on the application environments specification?
Thanks in advance.
    The Hercules HDKs have not gone through any EMC/EMI testing. These are development kits only and are not intended to be used in actual end equipment.
    Regards, Sunil
  • Hi Sunil
    Then is there anything related to the CPU of this HDKs ?
    I assume for the CPU, there must be some sort of quality certificate regarding EMC or EMI tests?
    Thanks in advance.
  • Hi Lu,
    We have test data that was collected internally. There is no certificate as such, but the data does show "acceptable" EMC performance, using typical automotive emissions limits.
    This data is not publicly shared. Also, in my experience the performance we measured using our test setup does not match "real world" application use cases. So our test data cannot be taken as indicative of the performance you can expect in your system.
    Regards, Sunil
