CCS/LAUNCHXL-TMS57004: TWO RTI TIMER for TMS570
Part Number: LAUNCHXL-TMS57004
I am using TMS570 and BQ76PL455 EVM.
Now I am trying to add some timers and interrupts to sample code. But only one of interrupts seem to work.
How can I solve this problem?
/** @file rti.c
*   @brief RTI Driver Source File
*   @date 25.July.2013
*   @version 03.06.00
*   This file contains:
*   - API Functions
*   - Interrupt Handlers
*   which are relevant for the RTI driver.
/* (c) Texas Instruments 2009-2013, All rights reserved. */
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "rti.h"
#include "sys_vim.h"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/** @fn void rtiInit(void)
*   @brief Initializes RTI Driver
*   This function initializes the RTI driver.
/* USER CODE BEGIN (2) */
/* USER CODE END */
void rtiInit(void)
/* USER CODE BEGIN (3) */
/* USER CODE END */
    /** @b Initialize @b RTI1: */
    /** - Setup NTU source, debug options and disable both counter blocks */
    rtiREG1->GCTRL = (1U << 16U) | 0x00000000U;
    /** - Setup timebase for free running counter 0 */
    rtiREG1->TBCTRL = 0x00000000U;
    /** - Enable/Disable capture event sources for both counter blocks */
    rtiREG1->CAPCTRL = 0U | 0U;
    /** - Setup input source compare 0-3 */
    rtiREG1->COMPCTRL = 0x00001000U | 0x00000100U | 0x00000000U | 0x00000000U;
    /** - Reset up counter 0 */
    rtiREG1->CNT[0U].UCx = 0x00000000U;
    /** - Reset free running counter 0 */
    rtiREG1->CNT[0U].FRCx = 0x00000000U;
    /** - Setup up counter 0 compare value
    *     - 0x00000000: Divide by 2^32
    *     - 0x00000001-0xFFFFFFFF: Divide by (CPUC0 + 1)
    rtiREG1->CNT[0U].CPUCx = 7U;
    /** - Reset up counter 1 */
    rtiREG1->CNT[1U].UCx = 0x00000000U;
    /** - Reset free running counter 1 */
    rtiREG1->CNT[1U].FRCx  = 0x00000000U;
    /** - Setup up counter 1 compare value
    *     - 0x00000001-0xFFFFFFFF: Divide by (CPUC1 + 1)
    rtiREG1->CNT[1U].CPUCx = 7U;
    /** - Setup compare 0 value. This value is compared with selected free running counter. */
    rtiREG1->CMP[0U].COMPx = 10000U;
    /** - Setup update compare 0 value. This value is added to the compare 0 value on each compare match. */
    rtiREG1->CMP[0U].UDCPx = 10000U;
    /** - Setup compare 1 value. This value is compared with selected free running counter. */
    rtiREG1->CMP[1U].COMPx = 50000U;
    /** - Setup update compare 1 value. This value is added to the compare 1 value on each compare match. */
    rtiREG1->CMP[1U].UDCPx = 50000U;
    /** - Setup compare 2 value. This value is compared with selected free running counter. */
    rtiREG1->CMP[2U].COMPx = 80000U;
    /** - Setup update compare 2 value. This value is added to the compare 2 value on each compare match. */
    rtiREG1->CMP[2U].UDCPx = 80000U;
    /** - Setup compare 3 value. This value is compared with selected free running counter. */
    rtiREG1->CMP[3U].COMPx = 100000U;
    /** - Setup update compare 3 value. This value is added to the compare 3 value on each compare match. */
    rtiREG1->CMP[3U].UDCPx = 100000U;
    /** - Clear all pending interrupts */
    rtiREG1->INTFLAG = 0x0007000FU;
    /** - Disable all interrupts */
    rtiREG1->CLEARINTENA = 0x00070F0FU;
    /**   @note This function has to be called before the driver can be used.\n
    *           This function has to be executed in privileged mode.\n
    *           This function does not start the counters.
/* USER CODE BEGIN (4) */
/* USER CODE END */
/* USER CODE BEGIN (5) */
/* USER CODE END */
/** @fn void rtiStartCounter(uint32 counter)
*   @brief Starts RTI Counter block
*   @param[in] counter Select counter block to be started:
*              - rtiCOUNTER_BLOCK0: RTI counter block 0 will be started
*              - rtiCOUNTER_BLOCK1: RTI counter block 1 will be started
*   This function starts selected counter block of the selected RTI module.
/* USER CODE BEGIN (6) */
/* USER CODE END */
/* USER CODE BEGIN (7) */
/* USER CODE END */
    rtiREG1->GCTRL |= (1U << (counter & 3U));
    /**   @note The function rtiInit has to be called before this function can be used.\n
/* USER CODE BEGIN (8) */
/* USER CODE END */
/* USER CODE BEGIN (9) */
/* USER CODE END */
/** @fn void rtiStopCounter(uint32 counter)
*   @brief Stops RTI Counter block
*   @param[in] counter Select counter to be stopped:
*              - rtiCOUNTER_BLOCK0: RTI counter block 0 will be stopped
*              - rtiCOUNTER_BLOCK1: RTI counter block 1 will be stopped
*   This function stops selected counter block of the selected RTI module.
/* USER CODE BEGIN (10) */
/* USER CODE END */
/* USER CODE BEGIN (11) */
/* USER CODE END */
    rtiREG1->GCTRL &= ~(1U << (counter & 3U));
/* USER CODE BEGIN (12) */
/* USER CODE END */
/* USER CODE BEGIN (13) */
/* USER CODE END */
/** @fn uint32 rtiResetCounter(uint32 counter)
*   @brief Reset RTI Counter block
*   @param[in] counter Select counter block to be reset:
*              - rtiCOUNTER_BLOCK0: RTI counter block 0 will be reset
*              - rtiCOUNTER_BLOCK1: RTI counter block 1 will be reset
*   @return The function will return:
*           - 0: When the counter reset wasn't successful
*           - 1: When the counter reset was successful
*   This function resets selected counter block of the selected RTI module.
/* USER CODE BEGIN (14) */
/* USER CODE END */
    uint32 success = 0U;
/* USER CODE BEGIN (15) */
/* USER CODE END */
    /*SAFETYMCUSW 134 S MR:12.2 <APPROVED> "Hardware status bit read check" */
    if ((!(rtiREG1->GCTRL & (1U << (counter & 3U)))) != 0U)
        rtiREG1->CNT[counter].UCx = 0x00000000U;
        rtiREG1->CNT[counter].FRCx = 0x00000000U;
        success = 1U;
    *           The selected counter block has to be stopped before it can reset.
/* USER CODE BEGIN (16) */
/* USER CODE END */
    return success;
/* USER CODE BEGIN (17) */
/* USER CODE END */
/** @fn void rtiSetPeriod(uint32 compare, uint32 period)
*   @brief Set new period of RTI compare
*   @param[in] compare Select compare to change period:
*              - rtiCOMPARE0: RTI compare 0 will change the period
*              - rtiCOMPARE1: RTI compare 1 will change the period
*              - rtiCOMPARE2: RTI compare 2 will change the period
*              - rtiCOMPARE3: RTI compare 3 will change the period
*   @param[in] period new period in [ticks - 1]:
*              - 0x00000000: Divide by 1
*              - n: Divide by n + 1
*   This function will change the period of the selected compare.
/* USER CODE BEGIN (18) */
/* USER CODE END */
/* USER CODE BEGIN (19) */
/* USER CODE END */
    rtiREG1->CMP[compare].UDCPx = period;
    *           When the corresponding counter block is not stopped,\n
    *           the period will change on the next compare match of the old period.
/* USER CODE BEGIN (20) */
/* USER CODE END */
/* USER CODE BEGIN (21) */
/* USER CODE END */
/** @fn uint32 rtiGetPeriod(uint32 compare)
*   @brief Get current period of RTI compare
*   @param[in] compare Select compare to return the current period:
*              - rtiCOMPARE0: RTI compare 0 will return the current period
*              - rtiCOMPARE1: RTI compare 1 will return the current period
*              - rtiCOMPARE2: RTI compare 2 will return the current period
*              - rtiCOMPARE3: RTI compare 3 will return the current period
*   @return Current period of selected compare in [ticks - 1]:
*   This function will return the period of the selected compare.
/* USER CODE BEGIN (22) */
/* USER CODE END */
    uint32 period;
/* USER CODE BEGIN (23) */
/* USER CODE END */
    period = rtiREG1->CMP[compare].UDCPx;
/* USER CODE BEGIN (24) */
/* USER CODE END */
    return period;
/* USER CODE BEGIN (25) */
/* USER CODE END */
/** @fn uint32 rtiGetCurrentTick(uint32 compare)
*   @brief Get current tick of RTI compare
*   @param[in] compare Select compare to return the current tick:
*              - rtiCOMPARE0: RTI compare 0 will return the current tick
*              - rtiCOMPARE1: RTI compare 1 will return the current tick
*              - rtiCOMPARE2: RTI compare 2 will return the current tick
*              - rtiCOMPARE3: RTI compare 3 will return the current tick
*   @return Current tick of selected compare
*   This function will return the current tick of the selected compare.
/* USER CODE BEGIN (26) */
/* USER CODE END */
    uint32 tick;
    uint32 counter = ((rtiREG1->COMPCTRL & (1U << (compare << 2U))) !=0U ) ? 1U : 0U;
	uint32 RTI_CNT_FRCx = rtiREG1->CNT[counter].FRCx;
	uint32 RTI_CMP_COMPx = rtiREG1->CMP[compare].COMPx;
	uint32 RTI_CMP_UDCPx = rtiREG1->CMP[compare].UDCPx;
/* USER CODE BEGIN (27) */
/* USER CODE END */
    tick = RTI_CNT_FRCx - (RTI_CMP_COMPx - RTI_CMP_UDCPx);
/* USER CODE BEGIN (28) */
/* USER CODE END */
    return tick;
/* USER CODE BEGIN (29) */
/* USER CODE END */
/** @fn void dwdInit(uint16 dwdPreload)
*   @brief Initialize DWD Expiration Period
*   @param[in] dwdPreload DWD Preload value for expiration time.
*              - Texp = (dwdPreload +1) / RTICLK
*   This function can be called to set the DWD expiration
/* USER CODE BEGIN (30) */
/* USER CODE END */
    /* Clear the violations if already present */
	rtiREG1->WDSTATUS = 0xFFU;
	rtiREG1->DWDPRLD = dwdPreload;
/* USER CODE BEGIN (31) */
/* USER CODE END */
/* USER CODE BEGIN (32) */
/* USER CODE END */
/** @fn void dwwdInit(dwwdReaction_t Reaction, uint16 dwdPreload, dwwdWindowSize_t Window_Size)
*   @param[in] Reaction DWWD reaction if the watchdog is serviced outside the time window.
*              - Generate_Reset
*              - Generate_NMI
*   @param[in] dwdPreload DWWD Preload value for the watchdog expiration time.
*   @param[in] Window_Size DWWD time window size
*              - Size_100_Percent
*              - Size_50_Percent
*              - Size_25_Percent
*              - Size_12_5_Percent
*              - Size_6_25_Percent
*              - Size_3_125_Percent
/* USER CODE BEGIN (33) */
/* USER CODE END */
    rtiREG1->WWDSIZECTRL = (uint32) Window_Size;
	rtiREG1->DWDPRLD     = (uint32) dwdPreload;
	rtiREG1->WWDRXNCTRL  = (uint32) Reaction;
/* USER CODE BEGIN (34) */
/* USER CODE END */
/* USER CODE BEGIN (35) */
/* USER CODE END */
/** @fn uint32 dwwdGetCurrentDownCounter(void)
*   @brief Get the current DWWD Down Counter
*   This function will get the current DWWD down counter value.
/* USER CODE BEGIN (36) */
/* USER CODE END */
    return (rtiREG1->DWDCNTR);
/* USER CODE BEGIN (37) */
/* USER CODE END */
/* USER CODE BEGIN (38) */
/* USER CODE END */
/** @fn void dwdCounterEnable(void)
*   @brief Enable DWD
*   This function will Enable the DWD counter.
/* USER CODE BEGIN (39) */
/* USER CODE END */
	rtiREG1->DWDCTRL = 0xA98559DAU;
/* USER CODE BEGIN (40) */
/* USER CODE END */
/* USER CODE BEGIN (41) */
/* USER CODE END */
/* USER CODE BEGIN (42) */
/* USER CODE END */
/* USER CODE BEGIN (43) */
/* USER CODE END */
/* USER CODE BEGIN (44) */
/* USER CODE END */
/** @fn void dwdSetPreload(uint16 dwdPreload)
*   @param[in] dwdPreload DWD Preload value for the watchdog expiration time.
*   This function can be called to set the Preload value for the watchdog expiration time.
/* USER CODE BEGIN (45) */
/* USER CODE END */
/* USER CODE BEGIN (46) */
/* USER CODE END */
/* USER CODE BEGIN (47) */
/* USER CODE END */
/** @fn void dwdReset(void)
*   @brief Reset Digital Watchdog
*   This function can be called to reset Digital Watchdog.
void dwdReset(void)
/* USER CODE BEGIN (48) */
/* USER CODE END */
	rtiREG1->WDKEY = 0x0000E51AU;
	rtiREG1->WDKEY = 0x0000A35CU;
/* USER CODE BEGIN (49) */
/* USER CODE END */
/** @fn void dwdGenerateSysReset(void)
*   @brief Generate System Reset through DWD
*   This function can be called to generate system reset using DWD.
/* USER CODE BEGIN (50) */
/* USER CODE END */
	rtiREG1->WDKEY = 0x00002345U;
/* USER CODE BEGIN (51) */
/* USER CODE END */
/* USER CODE BEGIN (52) */
/* USER CODE END */
/** @fn boolean IsdwdKeySequenceCorrect(void)
*   @brief Check if DWD Key sequence correct.
*           - TRUE: When the DWD key sequence is written correctly.
*           - FALSE: When the DWD key sequence is written incorrectly / not written.
*   This function will get status of the DWD Key sequence.
	boolean Status;
/* USER CODE BEGIN (53) */
/* USER CODE END */
	if((rtiREG1->WDSTATUS & 0x4U) == 0x4U)
		Status = FALSE;
	else
		Status = TRUE;
/* USER CODE BEGIN (54) */
/* USER CODE END */
	return Status;
/* USER CODE BEGIN (55) */
/* USER CODE END */
/** @fn dwdResetStatus_t dwdGetStatus(void)
*   @brief Check if Reset is generated due to DWD.
*           - Reset_Generated: When the Reset is generated due to DWD.
*           - No_Reset_Generated: No Reset is generated due to DWD.
*   This function will get dwd Reset status.
/* USER CODE BEGIN (56) */
/* USER CODE END */
	dwdResetStatus_t Reset_Status;
	if((rtiREG1->WDSTATUS & 0x2U) == 0x2U)
		Reset_Status = Reset_Generated;
	else
		Reset_Status = No_Reset_Generated;
/* USER CODE BEGIN (57) */
/* USER CODE END */
	return Reset_Status;
/* USER CODE BEGIN (58) */
/* USER CODE END */
/** @fn void dwdClearFlag(void)
*   @brief Clear the DWD violation flag.
*   This function will clear dwd status register.
/* USER CODE BEGIN (59) */
/* USER CODE END */
/* USER CODE BEGIN (60) */
/* USER CODE END */
/* USER CODE BEGIN (61) */
/* USER CODE END */
/** @fn dwdViolation_t dwdGetViolationStatus(void)
*   @brief Check the status of the DWD or DWWD violation happened.
*   @return The function will return one of following violations occured:
*           - NoTime_Violation
*           - Key_Seq_Violation
*           - Time_Window_Violation
*           - EndTime_Window_Violation
*           - StartTime_Window_Violation
*   This function will get status of the DWD or DWWD violation status.
/* USER CODE BEGIN (62) */
/* USER CODE END */
	dwdViolation_t Violation_Status;
	if ((rtiREG1->WDSTATUS & 0x04U) == 0x04U)
		Violation_Status = Key_Seq_Violation;
	else if((rtiREG1->WDSTATUS & 0x8U) == 0x8U)
		Violation_Status = StartTime_Window_Violation;
	else if ((rtiREG1->WDSTATUS & 0x10U) == 0x10U)
		Violation_Status = EndTime_Window_Violation;
	else if ((rtiREG1->WDSTATUS & 0x20U) == 0x20U)
		Violation_Status = Time_Window_Violation;
	else
		Violation_Status = NoTime_Violation;
/* USER CODE BEGIN (63) */
/* USER CODE END */
	return Violation_Status;
/* USER CODE BEGIN (64) */
/* USER CODE END */
/** @fn void rtiEnableNotification(uint32 notification)
*   @brief Enable notification of RTI module
*   @param[in] notification Select notification of RTI module:
*              - rtiNOTIFICATION_COMPARE0: RTI compare 0 notification
*              - rtiNOTIFICATION_COMPARE1: RTI compare 1 notification
*              - rtiNOTIFICATION_COMPARE2: RTI compare 2 notification
*              - rtiNOTIFICATION_COMPARE3: RTI compare 3 notification
*              - rtiNOTIFICATION_TIMEBASE: RTI Timebase notification
*              - rtiNOTIFICATION_COUNTER0: RTI counter 0 overflow notification
*              - rtiNOTIFICATION_COUNTER1: RTI counter 1 overflow notification
*   This function will enable the selected notification of a RTI module.
*   It is possible to enable multiple notifications masked.
/* USER CODE BEGIN (65) */
/* USER CODE END */
/* USER CODE BEGIN (66) */
/* USER CODE END */
    rtiREG1->INTFLAG = notification;
    rtiREG1->SETINTENA   = notification;
/* USER CODE BEGIN (67) */
/* USER CODE END */
/* USER CODE BEGIN (68) */
/* USER CODE END */
/** @fn void rtiDisableNotification(uint32 notification)
*   @brief Disable notification of RTI module
*   This function will disable the selected notification of a RTI module.
*   It is possible to disable multiple notifications masked.
/* USER CODE BEGIN (69) */
/* USER CODE END */
/* USER CODE BEGIN (70) */
/* USER CODE END */
    rtiREG1->CLEARINTENA = notification;
/* USER CODE BEGIN (71) */
/* USER CODE END */
/* USER CODE BEGIN (72) */
/* USER CODE END */
/** @fn void rtiGetConfigValue(rti_config_reg_t *config_reg, config_value_type_t type)
*   @brief Get the initial or current values of the configuration registers
*	@param[in] *config_reg: pointer to the struct to which the initial or current value of the configuration registers need to be stored
*	@param[in] type: 	whether initial or current value of the configuration registers need to be stored
*						- InitialValue: initial value of the configuration registers will be stored in the struct pointed by config_reg
*						- CurrentValue: initial value of the configuration registers will be stored in the struct pointed by config_reg
*   This function will copy the initial or current value (depending on the parameter 'type') of the configuration
*   registers to the struct pointed by config_reg
	if (type == InitialValue)
		config_reg->CONFIG_GCTRL = RTI_GCTRL_CONFIGVALUE;
		config_reg->CONFIG_TBCTRL = RTI_TBCTRL_CONFIGVALUE;
		config_reg->CONFIG_CAPCTRL = RTI_CAPCTRL_CONFIGVALUE;
		config_reg->CONFIG_COMPCTRL = RTI_COMPCTRL_CONFIGVALUE;
		config_reg->CONFIG_UDCP0 = RTI_UDCP0_CONFIGVALUE;
		config_reg->CONFIG_UDCP1 = RTI_UDCP1_CONFIGVALUE;
		config_reg->CONFIG_UDCP2 = RTI_UDCP2_CONFIGVALUE;
		config_reg->CONFIG_UDCP3 = RTI_UDCP3_CONFIGVALUE;
	else
	/*SAFETYMCUSW 134 S MR:12.2 <APPROVED> "Register read back support" */
		config_reg->CONFIG_GCTRL = rtiREG1->GCTRL;
		config_reg->CONFIG_TBCTRL = rtiREG1->TBCTRL;
		config_reg->CONFIG_CAPCTRL = rtiREG1->CAPCTRL;
		config_reg->CONFIG_COMPCTRL = rtiREG1->COMPCTRL;
		config_reg->CONFIG_UDCP0 = rtiREG1->CMP[0U].UDCPx;
		config_reg->CONFIG_UDCP1 = rtiREG1->CMP[1U].UDCPx;
		config_reg->CONFIG_UDCP2 = rtiREG1->CMP[2U].UDCPx;
		config_reg->CONFIG_UDCP3 = rtiREG1->CMP[3U].UDCPx;
/* USER CODE BEGIN (76) */
/* USER CODE END */
/** @fn void rtiCompare1Interrupt(void)
*   @brief RTI1 Compare 1 Interrupt Handler
*   RTI1 Compare 1 interrupt handler
#pragma CODE_STATE(rtiCompare0Interrupt, 32)
#pragma INTERRUPT(rtiCompare0Interrupt, IRQ)
void rtiCompare0Interrupt(void)
    rtiREG1->INTFLAG = 1U;
    rtiNotification(rtiNOTIFICATION_COMPARE0);
#pragma CODE_STATE(rtiCompare1Interrupt, 32)
#pragma INTERRUPT(rtiCompare1Interrupt, IRQ)
/* USER CODE BEGIN (77) */
/* USER CODE END */
    rtiREG1->INTFLAG = 2U;
    rtiNotification(rtiNOTIFICATION_COMPARE1);
/* USER CODE BEGIN (78) */
/* USER CODE END */
void rtiCompare2Interrupt(void)
/* USER CODE END */
    rtiREG1->INTFLAG = 4U;
    rtiNotification(rtiNOTIFICATION_COMPARE2);
/* USER CODE END */
void rtiCompare3Interrupt(void)
/* USER CODE END */
    rtiREG1->INTFLAG = 8U;
    rtiNotification(rtiNOTIFICATION_COMPARE3);
/* USER CODE END */
//---------------------------------------EKLENENEN KOD------------------------------5.3.2020 //
 * rti_deneme.c
 *  Created on: 5 Mar 2020
 *      Author: ykarata1
#include "sys_common.h"
#include "system.h"
#include <stdio.h>
#include <inttypes.h>
#include <math.h>
#include <stdbool.h>
#include "gio.h"
#include "sci.h"
#include "rti.h"
#include "swi_util.h"
#include "pl455.h"
#include "adc.h"
#include "stdlib.h"
int UART_RX_RDY = 0;
int RTI_TIMEOUT = 0;
void main (void)
    rtiInit(); // yapmayınca ilk tur da voltajlar 0 okunuyor.
    vimInit();
    rtiEnableNotification(rtiNOTIFICATION_COMPARE0);
    rtiEnableNotification(rtiNOTIFICATION_COMPARE1);
    rtiEnableNotification(rtiNOTIFICATION_COMPARE2);
    rtiEnableNotification(rtiNOTIFICATION_COMPARE3);
    _enable_IRQ(); // silince çalışmıyor
    esmInit();
    rtiStartCounter(rtiCOUNTER_BLOCK0);
    while(1)
void rtiNotification(unsigned notification)
    if (notification == rtiNOTIFICATION_COMPARE0)
        printf("MERHABA \r\n");
    else if (notification == rtiNOTIFICATION_COMPARE1)
        printf("SELAM \r\n");
    else if (notification == rtiNOTIFICATION_COMPARE2)
        printf("2 \r\n");
    else if (notification == rtiNOTIFICATION_COMPARE3)
        printf("3 \r\n");
void esmGroup1Notification(unsigned channel)
    return;
void esmGroup2Notification(unsigned channel)
    return;
Result is:
Always goes like that.
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
SELAM
WHat is wrong on that topic?
