Part Number: TMS570LS1114
Other Parts Discussed in Thread: HALCOGEN
Dear support team,
in order to check incoming pulse-signal frequencies, I tried to use the capture function of the N2HET module.
The values are then read in CCS via capGetSignal(). In HalCoGen, I get the informationm, that HR share must be enable for Pin n and n+1. ( LIMITATION ! )
So that means, that I managed to read the right frequency, if the incoming signals are not pinned on neighbouring pins, e.g. it didn't work, if I try to measure a signal frequency on N2HET[12] and a different one on N2HET[13].
The problem is, that my hardware design forces me to calculate incoming frequencies on neighbouring pins. Can capGetSignal() be modified in such a way, that the limitation mentioned above is no longer a problem?
Thank you and kind regards
Sebastian
