Part Number: CC430F5137
Hi , I'm experimenting some problem using CC430F5137 with RF runing. I have a lot of boards working but sometimes i get the microcontroller stuck in some boards and the only way to fix it is reprograming the microcontroller, reading the errata I found out that there are some problem with PMM, it is possible that changes or noise in the supply voltage can produce a prgram corruption?
EDIT: I read the program from the stuck boards and there is a part of the main block getting erased
