Hi TI:
which method shloud i use to register can interrupt?
Hwi_create or CANIntRegister?
it's in a rtos enviroment.
Hi TI:
If you use RTOS then you need to use Hwi_create. If you use CANIntRegister then you will confuse the TI-RTOS. You only use CANIntRegister when you are using the TivaWare in a non TI-RTOS environment.
