Part Number: RM46L852
Other Parts Discussed in Thread: HALCOGEN
I'm looking for some clarification about the (warm) reset behavior of the RM46. In the technical reference manual for each register the state after reset is documented. Some register are persistent in case of a reset what is also documented. I wonder if
- This documented state after reset is applicable for cold as well as for warm reset if not documented different or if the document only describes the state after a cold reset.
- The CPU reset is different from other (warm) reset reasons like PLL slip, Watchdog, etc. as it seems in the code generated by HALCoGen that after a self-test of CPU STC and CPU the code continues calling afterSTC() without an additional call to eg. systemInit() so I assume that no registers outside the CPU core are affected by a CPU reset ?
Oliver
