CCS/TM4C1294NCPDT: TI-RTOS UDP close
Part Number: TM4C1294NCPDT
MCU: TM4C1294NCPDT
RTOS version : tirtos_tivac_2_16_01_14
NDK version : ndk_2_25_00_09
Hi
I have some problem.
UDP sento failed and socket close crash.
When sento failed and i using fdClose(fd), but MCU has no response anymore.
I using debug tool, find a problem.
Seems into a infinite loop here.
hIf = BindIPHost2IF ((IPN)ptr_ipmreq->imr_interface.s_addr);
if (!hIf)
return (EINVAL);
This is my code UDP socket:
int fd = (int)socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
	if (fd < 0) {
		return -1;
	struct ip_mreq mreq;
	struct sockaddr_in sa = {0};
	int enable = 1;
	int hops = 255;
	if (setsockopt((SOCKET)fd, SOL_SOCKET, SO_REUSEADDR, &enable, sizeof(enable))) {
		goto err;
    if (setsockopt((SOCKET)fd, SOL_SOCKET, SO_REUSEPORT, &enable, sizeof(enable))) {
		goto err;
    if (setsockopt((SOCKET)fd, SOL_SOCKET, SO_BROADCAST, &enable, sizeof(enable))) {
   		goto err;
	if (setsockopt((SOCKET)fd, IPPROTO_IP, IP_TTL, &hops, sizeof(hops))) {
		goto err;
	mreq.imr_multiaddr.s_addr = htonl(0xE00000FB);
	mreq.imr_interface = interface_addr;
	if (setsockopt((SOCKET)fd, IPPROTO_IP, IP_ADD_MEMBERSHIP, &mreq, sizeof(mreq))) {
		goto err;
	sa.sin_family = AF_INET;
	sa.sin_port = ntohs(5353);
	sa.sin_addr.s_addr = INADDR_ANY;
	if (bind((SOCKET)fd, (struct sockaddr*) &sa, sizeof(sa))) {
		goto err;
	send_addr->sin_family = AF_INET;
	send_addr->sin_addr.s_addr = mreq.imr_multiaddr.s_addr;
	send_addr->sin_port = ntohs(5353);
How do i check what's problem?
Allen
