Part Number: RM48L952
Please, Someone reply this post.
XDS110 Connection Test is OK on CCS.
But, When downloading out file, erro occurs.
JY Kim.
Can you try the following:
Hello Kim,
The PRSC error is related to reset - TMS570 may be held in reset, or external circuitry may be holding the device in reset. I would strongly check if the TMS570 itself is being held in reset at the time you are trying to connect using CCS.
Hello Wang,
Please check RM48L952.ccxml.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<configurations XML_version="1.2" id="configurations_0">
<configuration XML_version="1.2" id="Texas Instruments XDS110 USB Debug Probe_0">
<instance XML_version="1.2" desc="Texas Instruments XDS110 USB Debug Probe_0" href="connections/TIXDS110_Connection.xml" id="Texas Instruments XDS110 USB Debug Probe_0" xml="TIXDS110_Connection.xml" xmlpath="connections"/>
<connection XML_version="1.2" id="Texas Instruments XDS110 USB Debug Probe_0">
<instance XML_version="1.2" href="drivers/tixds510icepick_c.xml" id="drivers" xml="tixds510icepick_c.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers/tixds510cs_dap.xml" id="drivers" xml="tixds510cs_dap.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers/tixds510cortexR.xml" id="drivers" xml="tixds510cortexR.xml" xmlpath="drivers"/>
<property Type="choicelist" Value="0" id="Debug Probe Selection"/>
<property Type="choicelist" Value="1" id="The JTAG TCLK Frequency (MHz)">
<choice Name="Fixed with user specified value" value="SPECIFIC">
<property Type="stringfield" Value="1.25MHz" id="-- Enter a value from 100.0kHz to 2.5MHz"/>
</choice>
</property>
<property Type="choicelist" Value="0" id="Power Selection">
<choice Name="Probe supplied power" value="1">
<property Type="stringfield" Value="3.3V" id="Voltage Level"/>
</choice>
</property>
<platform XML_version="1.2" id="platform_0">
<instance XML_version="1.2" desc="RM48L952_0" href="devices/rm48l952.xml" id="RM48L952_0" xml="rm48l952.xml" xmlpath="devices"/>
<device HW_revision="1" XML_version="1.2" description="RM48L952 QFP/BGA, 3MB Flash, 256kB RAM, 10/100M Ethernet, USB host and slave" id="RM48L952_0" partnum="RM48L952" simulation="no">
<router HW_revision="1.0" XML_version="1.2" desc="IcePick" description="ICEPick_C Router" id="IcePick_C_0" isa="ICEPICK_C">
<property Type="choicelist" Value="0" id="bypass"/>
<subpath id="Port16">
<router HW_revision="" XML_version="1.2" desc="Dap" description="CS_DAP Router" id="CS_DAP_0" isa="CS_DAP">
<subpath id="PortR4">
<cpu HW_revision="" XML_version="1.2" description="Cortex_R4 CPU" deviceSim="false" id="Cortex_R4_0" isa="Cortex_R4">
<property Type="filepathfield" Value="..\..\emulation\gel\rm48l952.gel" id="GEL File"/>
</cpu>
<property Type="numericfield" Value="4" id="Port Number"/>
<property Type="choicelist" Value="0" id="Force Configuration"/>
<property Type="choicelist" Value="1" id="Initial Configuration"/>
<property Type="choicelist" Value="1" id="Custom Configuration"/>
</subpath>
<property Type="choicelist" Value="0" id="Device Management"/>
</router>
</subpath>
</router>
</device>
</platform>
</connection>
</configuration>
</configurations>
JY Kim.
Hello Wang,
I have modified RM48L952.ccxml as fowlling.
<property Type="numericfield" Value="0" id="Port Number"/>
I tried Target Configuration -> Launch Selected Configuration.
CortexR4 click and then connect button on the toolbar.
The result was as follows.
How can i do next?
JY Kim.
Hi Kim,
What is the purpose to change "numericfield" Value="4" to "numericfield" Value="0"? I don't know what this number is used for.
Can you please create a new ccxml using CCS or uniflash for RM48 device?
Hi Wang,
I create a new ccxml using CCS for RM48L952 device.
</choice>
</property>
</platform>
</connection>
</configuration>
</configurations>
I try again Target Configuration -> Launch Selected Configuration.
Then, CortexR4 click and connect button on the toolbar.
IcePick, Dap and CortexR4 connected.
But, can't load .out on the CCS or uniFalsh because (Error -242 @ 0x0), (Error -1170 @0x0).
Please note, Test Connection for XDS110 was OK.
And, There was no problem in using XDS200.
Please again check.
JY Kim.
Did you use the same out file and same flash settings for xds110 and xds200?
Hello Wang,
I repeat,
Program downloading OK in using XDS100 and XDS200.
Only XDS110 cannot downloading the program.
I don't know what problem.
Can someone help me with this problem?
JY Kim.
I don't know what is wrong with your xds110 debugger. Can you upgrade the firmware of your xds110 debugger?
You can download the latest driver from ti.com. Or you can reprogram the firmware using xdsdfu which is located ccsxx/ccs_base/common/uscif/xds110.
In CMD window, type xdsdfu -h to learn how to use it:
xdsdfu -f firmwarexxx.bin -r
The firmware is in the same folder.
Are you using a TI evaluation board for this, or did you design your own board with an XDS110 emulator on it?
The TI evaluation boards for RM48x do not include an XDS110 emulator.
Hello Wang,
Hi Wang,
It is not the xds110 working yet.
Please tell me the solution.
JY Kim.
Does your xds110 debugger work on other board? Does your xds110 debugger on TI HDK or launchpad? Is the nTRST signal connected to GND on your target board? xds110 doesn't use this pin, but this pin should be pulled low.
Hi Wang,
I connected the nTRST(pin number 2) signal to GND on my target board.
But, Test Connection error occur(-233 SC_ERR_PATH_BROKEN) on Target Configuration.
And, IcePick: Error connecting to the target: (Error -2131 @ 0x0) occurrence when running debug.
Please check.
Thanks and Regards,
JY Kim.
Hi JY,
nTRST should not be connected to GND directly. A resistor (for example 2.2Kohms) is required.
Hi Wang,
I tried again your recommend.
My targer board pull-down 2.2k at nTRST.
The same error occurs( CortexR4: Error: (Error -242 @ 0x0) and CortexR4: Error: (Error -1170 @ 0x0) ).
Note that, nTRST of RM48L952 is internal pull-down(default pull state). Refer to the datasheet.
Also, i checked nTRST pull-down resister in xds110.
I think there should be another soultion.
Thanks and Regards,
JY Kim.
