Other Parts Discussed in Thread: HALCOGEN
Dear team
The device is RM42L432.
1 Problems were found when i used SL_SelfTest_Flash.
flash_stResult_1bt was ST_PASS when running retVal = SL_SelfTest_Flash(FLASH_ECC_TEST_MODE_1BIT, TRUE, &flash_stResult_1bt);
But flash_stResult_2bt was ST_FAIL; when running retVal = SL_SelfTest_Flash(FLASH_ECC_TEST_MODE_2BIT, TRUE, &flash_stResult_2bt);
What may cause the difference?
2 Besides,I enabled interrupt trigger and nerror pin in FLASH_ECC_TEST_MODE_1BIT mode in HALcogen.
However, it does not trigger an interrupt and pull the pin low during operation.
BR,
SUSAN
