TM4C1294NCPDT: Does the latest TivaWare include lwip 2.1.2?
Part Number: TM4C1294NCPDT
Mine is still with lwip 1.4.1, and it had some issues. If the latest TiVaWare includes lwip 2.1.2, I will consider biting the bullet and move my software to it.
btw, I heard taht lwip 2.1.2 changes a lot from lwip 1.4, so old example may not work "as is"
  • Hello David,
    No, it is still on lwIP 1.4.1. We don't currently have plans to make the leap to lwIP version 2 in TivaWare, but that could change if we get more feedback about it being a make or break feature.
    I would recommend that you review the release notes to see if any bug fixes may have positive impacts for your projects and at least selective apply those in your driverlib/usblib. :)
  • lwip 2.1.2 changes so much from 1.4.1, if I recall right, even some struct and api with same name were changed, which is not a good choice in my view, it made backward compatibility hard
    So it is not easy to just apply 2.1.2 patches to 1.4.1
  • Hello David,
    Agreed, sorry I was unclear.
    I meant look through the TivaWare Release Notes for 2.2.0 to see the bug fixes specific to TivaWare driver library and USB library in case there are any you want to roll in without needing to do the full transition from your current TivaWare to 2.2.0. That way if we fixed anything that would impact your systems, you have the latest code from that at least.
  • I am using Tivaware 2.1.4 anyway, not that far from 2.2.0.
    I just need lwip improvement, not any other drivers
  • Ooops, I accidentally deleted C:\ti\TivaWare_C_Series-2.1.4.178\utils\lwiplib.c, dated 1/31/2018. Can you find the same file for me? Many thanks!
  • Hi David,
    Here you go:
    // lwiplib.c - lwIP TCP/IP Library Abstraction Layer.
    // Copyright (c) 2008-2017 Texas Instruments Incorporated.  All rights reserved.
    // Software License Agreement
    // Texas Instruments (TI) is supplying this software for use solely and
    // exclusively on TI's microcontroller products. The software is owned by
    // TI and/or its suppliers, and is protected under applicable copyright
    // laws. You may not combine this software with "viral" open-source
    // software in order to form a larger program.
    // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
    // NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
    // NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
    // CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
    // DAMAGES, FOR ANY REASON WHATSOEVER.
    // This is part of revision 2.1.4.178 of the Tiva Utility Library.
    // Ensure that the lwIP compile time options are included first.
    #include <stdint.h>
    #include <stdbool.h>
    #include "utils/lwiplib.h"
    // Ensure that ICMP checksum offloading is enabled; otherwise the TM4C129
    // driver will not operate correctly.
    #ifndef LWIP_OFFLOAD_ICMP_CHKSUM
    #define LWIP_OFFLOAD_ICMP_CHKSUM 1
    #endif
    // Include lwIP high-level API code.
    #include "third_party/lwip-1.4.1/src/api/api_lib.c"
    #include "third_party/lwip-1.4.1/src/api/api_msg.c"
    #include "third_party/lwip-1.4.1/src/api/err.c"
    #include "third_party/lwip-1.4.1/src/api/netbuf.c"
    #include "third_party/lwip-1.4.1/src/api/netdb.c"
    #include "third_party/lwip-1.4.1/src/api/netifapi.c"
    #include "third_party/lwip-1.4.1/src/api/sockets.c"
    #include "third_party/lwip-1.4.1/src/api/tcpip.c"
    // Include the core lwIP TCP/IP stack code.
    #include "third_party/lwip-1.4.1/src/core/def.c"
    #include "third_party/lwip-1.4.1/src/core/dhcp.c"
    #include "third_party/lwip-1.4.1/src/core/dns.c"
    #include "third_party/lwip-1.4.1/src/core/init.c"
    #include "third_party/lwip-1.4.1/src/core/mem.c"
    #include "third_party/lwip-1.4.1/src/core/memp.c"
    #include "third_party/lwip-1.4.1/src/core/netif.c"
    #include "third_party/lwip-1.4.1/src/core/pbuf.c"
    #include "third_party/lwip-1.4.1/src/core/raw.c"
    #include "third_party/lwip-1.4.1/src/core/stats.c"
    #include "third_party/lwip-1.4.1/src/core/sys.c"
    #include "third_party/lwip-1.4.1/src/core/tcp.c"
    #include "third_party/lwip-1.4.1/src/core/tcp_in.c"
    #include "third_party/lwip-1.4.1/src/core/tcp_out.c"
    #include "third_party/lwip-1.4.1/src/core/timers.c"
    #include "third_party/lwip-1.4.1/src/core/udp.c"
    // Include the IPV4 code.
    #include "third_party/lwip-1.4.1/src/core/ipv4/autoip.c"
    #include "third_party/lwip-1.4.1/src/core/ipv4/icmp.c"
    #include "third_party/lwip-1.4.1/src/core/ipv4/igmp.c"
    #include "third_party/lwip-1.4.1/src/core/ipv4/inet.c"
    #include "third_party/lwip-1.4.1/src/core/ipv4/inet_chksum.c"
    #include "third_party/lwip-1.4.1/src/core/ipv4/ip.c"
    #include "third_party/lwip-1.4.1/src/core/ipv4/ip_addr.c"
    #include "third_party/lwip-1.4.1/src/core/ipv4/ip_frag.c"
    // Include the IPV6 code.
    // Note:  Code is experimental and not ready for use.
    // References are included for completeness.
    #if 0
    #include "third_party/lwip-1.4.1/src/core/ipv6/icmp6.c"
    #include "third_party/lwip-1.4.1/src/core/ipv6/inet6.c"
    #include "third_party/lwip-1.4.1/src/core/ipv6/ip6.c"
    #include "third_party/lwip-1.4.1/src/core/ipv6/ip6_addr.c"
    #endif
    // Include the lwIP SNMP code.
    #include "third_party/lwip-1.4.1/src/core/snmp/asn1_dec.c"
    #include "third_party/lwip-1.4.1/src/core/snmp/asn1_enc.c"
    #include "third_party/lwip-1.4.1/src/core/snmp/mib2.c"
    #include "third_party/lwip-1.4.1/src/core/snmp/mib_structs.c"
    #include "third_party/lwip-1.4.1/src/core/snmp/msg_in.c"
    #include "third_party/lwip-1.4.1/src/core/snmp/msg_out.c"
    // Include the network interface code.
    #include "third_party/lwip-1.4.1/src/netif/etharp.c"
    // Include the network interface PPP code.
    #include "third_party/lwip-1.4.1/src/netif/ppp/auth.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/chap.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/chpms.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/fsm.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/ipcp.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/lcp.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/magic.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/md5.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/pap.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/ppp.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/ppp_oe.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/randm.c"
    #include "third_party/lwip-1.4.1/src/netif/ppp/vj.c"
    // Include Tiva-specific lwIP interface/porting layer code.
    #include "third_party/lwip-1.4.1/ports/tiva-tm4c129/perf.c"
    #include "third_party/lwip-1.4.1/ports/tiva-tm4c129/sys_arch.c"
    #include "third_party/lwip-1.4.1/ports/tiva-tm4c129/netif/tiva-tm4c129.c"
    //! \addtogroup lwiplib_api
    // The lwIP Library abstration layer provides for a host callback function to
    // be called periodically in the lwIP context.  This is the timer interval, in
    // ms, for this periodic callback.  If the timer interval is defined to 0 (the
    // default value), then no periodic host callback is performed.
    #ifndef HOST_TMR_INTERVAL
    #define HOST_TMR_INTERVAL       0
    #else
    extern void lwIPHostTimerHandler(void);
    #endif
    // The link detect polling interval.
    #define LINK_TMR_INTERVAL       10
    // Set the PHY configuration to the default (internal) option if necessary.
    #ifndef EMAC_PHY_CONFIG
    #define EMAC_PHY_CONFIG         (EMAC_PHY_TYPE_INTERNAL |                     \
                                     EMAC_PHY_INT_MDIX_EN |                       \
                                     EMAC_PHY_AN_100B_T_FULL_DUPLEX)
    #endif
    // Driverlib headers needed for this library module.
    #include "inc/hw_ints.h"
    #include "inc/hw_memmap.h"
    #include "inc/hw_nvic.h"
    #include "driverlib/debug.h"
    #include "driverlib/emac.h"
    #include "driverlib/rom.h"
    #include "driverlib/rom_map.h"
    #include "driverlib/sysctl.h"
    #if !NO_SYS
    #if RTOS_FREERTOS
    #include "FreeRTOS.h"
    #include "task.h"
    #include "queue.h"
    #include "semphr.h"
    #endif
    #if ((RTOS_FREERTOS) < 1)
        #error No RTOS is defined.  Please define an RTOS.
    #endif
    #if ((RTOS_FREERTOS) > 1)
        #error More than one RTOS defined.  Please define only one RTOS at a time.
    #endif
    #endif
    // The lwIP network interface structure for the Tiva Ethernet MAC.
    static struct netif g_sNetIF;
    // The application's interrupt handler for hardware timer events from the MAC.
    tHardwareTimerHandler g_pfnTimerHandler;
    // The local time for the lwIP Library Abstraction layer, used to support the
    // Host and lwIP periodic callback functions.
    #if NO_SYS
    uint32_t g_ui32LocalTimer = 0;
    #endif
    // The local time when the TCP timer was last serviced.
    #if NO_SYS
    static uint32_t g_ui32TCPTimer = 0;
    #endif
    // The local time when the HOST timer was last serviced.
    #if NO_SYS && HOST_TMR_INTERVAL
    static uint32_t g_ui32HostTimer = 0;
    #endif
    // The local time when the ARP timer was last serviced.
    #if NO_SYS && LWIP_ARP
    static uint32_t g_ui32ARPTimer = 0;
    #endif
    // The local time when the AutoIP timer was last serviced.
    #if NO_SYS && LWIP_AUTOIP
    static uint32_t g_ui32AutoIPTimer = 0;
    #endif
    // The local time when the DHCP Coarse timer was last serviced.
    #if NO_SYS && LWIP_DHCP
    static uint32_t g_ui32DHCPCoarseTimer = 0;
    #endif
    // The local time when the DHCP Fine timer was last serviced.
    static uint32_t g_ui32DHCPFineTimer = 0;
    #endif
    // The local time when the IP Reassembly timer was last serviced.
    #if NO_SYS && IP_REASSEMBLY
    static uint32_t g_ui32IPReassemblyTimer = 0;
    #endif
    // The local time when the IGMP timer was last serviced.
    #if NO_SYS && LWIP_IGMP
    static uint32_t g_ui32IGMPTimer = 0;
    #endif
    // The local time when the DNS timer was last serviced.
    #if NO_SYS && LWIP_DNS
    static uint32_t g_ui32DNSTimer = 0;
    #endif
    // The local time when the link detect timer was last serviced.
    #if NO_SYS && (LWIP_AUTOIP || LWIP_DHCP)
    static uint32_t g_ui32LinkTimer = 0;
    #endif
    // The default IP address acquisition mode.
    static uint32_t g_ui32IPMode = IPADDR_USE_STATIC;
    // The most recently detected link state.
    #if LWIP_AUTOIP || LWIP_DHCP
    static bool g_bLinkActive = false;
    #endif
    // The IP address to be used.  This is used during the initialization of the
    // stack and when the interface configuration is changed.
    static uint32_t g_ui32IPAddr;
    // The netmask to be used.  This is used during the initialization of the stack
    // and when the interface configuration is changed.
    static uint32_t g_ui32NetMask;
    // The gateway address to be used.  This is used during the initialization of
    // the stack and when the interface configuration is changed.
    static uint32_t g_ui32GWAddr;
    // The stack size for the interrupt task.
    #if !NO_SYS
    #define STACKSIZE_LWIPINTTASK   128
    #endif
    // The handle for the "queue" (semaphore) used to signal the interrupt task
    // from the interrupt handler.
    #if !NO_SYS
    static xQueueHandle g_pInterrupt;
    #endif
    // This task handles reading packets from the Ethernet controller and supplying
    // them to the TCP/IP thread.
    #if !NO_SYS
    static void
    lwIPInterruptTask(void *pvArg)
        // Loop forever.
        while(1)
            // Wait until the semaphore has been signaled.
            while(xQueueReceive(g_pInterrupt, &pvArg, portMAX_DELAY) != pdPASS)
            // Processes any packets waiting to be sent or received.
            tivaif_interrupt(&g_sNetIF, (uint32_t)pvArg);
            // Re-enable the Ethernet interrupts.
            MAP_EMACIntEnable(EMAC0_BASE, (EMAC_INT_RECEIVE | EMAC_INT_TRANSMIT |
                                           EMAC_INT_TX_STOPPED |
                                           EMAC_INT_RX_NO_BUFFER |
                                           EMAC_INT_RX_STOPPED | EMAC_INT_PHY));
    #endif
    // This function performs a periodic check of the link status and responds
    // appropriately if it has changed.
    static void
    lwIPLinkDetect(void)
        bool bHaveLink;
        struct ip_addr ip_addr;
        struct ip_addr net_mask;
        struct ip_addr gw_addr;
        // See if there is an active link.
        bHaveLink = MAP_EMACPHYRead(EMAC0_BASE, PHY_PHYS_ADDR, EPHY_BMSR) &
                                    EPHY_BMSR_LINKSTAT;
        // Return without doing anything else if the link state hasn't changed.
        if(bHaveLink == g_bLinkActive)
            return;
        // Save the new link state.
        g_bLinkActive = bHaveLink;
        // Clear any address information from the network interface.
        ip_addr.addr = 0;
        net_mask.addr = 0;
        gw_addr.addr = 0;
        netif_set_addr(&g_sNetIF, &ip_addr, &net_mask, &gw_addr);
        // See if there is a link now.
        if(bHaveLink)
            // Start DHCP, if enabled.
    #if LWIP_DHCP
            if(g_ui32IPMode == IPADDR_USE_DHCP)
                dhcp_start(&g_sNetIF);
    #endif
            // Start AutoIP, if enabled and DHCP is not.
    #if LWIP_AUTOIP
            if(g_ui32IPMode == IPADDR_USE_AUTOIP)
                autoip_start(&g_sNetIF);
    #endif
        else
            // Stop DHCP, if enabled.
    #if LWIP_DHCP
                dhcp_stop(&g_sNetIF);
    #endif
            // Stop AutoIP, if enabled and DHCP is not.
    #if LWIP_AUTOIP
                autoip_stop(&g_sNetIF);
    #endif
    #endif
    // This function services all of the lwIP periodic timers, including TCP and
    // Host timers.  This should be called from the lwIP context, which may be
    // the Ethernet interrupt (in the case of a non-RTOS system) or the lwIP
    // thread, in the event that an RTOS is used.
    #if NO_SYS
    static void
    lwIPServiceTimers(void)
        // Service the host timer.
    #if HOST_TMR_INTERVAL
        if((g_ui32LocalTimer - g_ui32HostTimer) >= HOST_TMR_INTERVAL)
            g_ui32HostTimer = g_ui32LocalTimer;
            lwIPHostTimerHandler();
    #endif
        // Service the ARP timer.
    #if LWIP_ARP
        if((g_ui32LocalTimer - g_ui32ARPTimer) >= ARP_TMR_INTERVAL)
            g_ui32ARPTimer = g_ui32LocalTimer;
            etharp_tmr();
    #endif
        // Service the TCP timer.
    #if LWIP_TCP
        if((g_ui32LocalTimer - g_ui32TCPTimer) >= TCP_TMR_INTERVAL)
            g_ui32TCPTimer = g_ui32LocalTimer;
            tcp_tmr();
    #endif
        // Service the AutoIP timer.
    #if LWIP_AUTOIP
        if((g_ui32LocalTimer - g_ui32AutoIPTimer) >= AUTOIP_TMR_INTERVAL)
            g_ui32AutoIPTimer = g_ui32LocalTimer;
            autoip_tmr();
    #endif
        // Service the DCHP Coarse Timer.
    #if LWIP_DHCP
        if((g_ui32LocalTimer - g_ui32DHCPCoarseTimer) >= DHCP_COARSE_TIMER_MSECS)
            g_ui32DHCPCoarseTimer = g_ui32LocalTimer;
            dhcp_coarse_tmr();
    #endif
        // Service the DCHP Fine Timer.
    #if LWIP_DHCP
        if((g_ui32LocalTimer - g_ui32DHCPFineTimer) >= DHCP_FINE_TIMER_MSECS)
            g_ui32DHCPFineTimer = g_ui32LocalTimer;
            dhcp_fine_tmr();
    #endif
        // Service the IP Reassembly Timer
    #if IP_REASSEMBLY
        if((g_ui32LocalTimer - g_ui32IPReassemblyTimer) >= IP_TMR_INTERVAL)
            g_ui32IPReassemblyTimer = g_ui32LocalTimer;
            ip_reass_tmr();
    #endif
        // Service the IGMP Timer
    #if LWIP_IGMP
        if((g_ui32LocalTimer - g_ui32IGMPTimer) >= IGMP_TMR_INTERVAL)
            g_ui32IGMPTimer = g_ui32LocalTimer;
            igmp_tmr();
    #endif
        // Service the DNS Timer
    #if LWIP_DNS
        if((g_ui32LocalTimer - g_ui32DNSTimer) >= DNS_TMR_INTERVAL)
            g_ui32DNSTimer = g_ui32LocalTimer;
            dns_tmr();
    #endif
        // Service the link timer.
        if((g_ui32LocalTimer - g_ui32LinkTimer) >= LINK_TMR_INTERVAL)
            g_ui32LinkTimer = g_ui32LocalTimer;
            lwIPLinkDetect();
    #endif
    #endif
    // Handles the timeout for the host callback function timer when using a RTOS.
    #if !NO_SYS && HOST_TMR_INTERVAL
    static void
    lwIPPrivateHostTimer(void *pvArg)
        // Call the application-supplied host timer callback function.
        // Re-schedule the host timer callback function timeout.
        sys_timeout(HOST_TMR_INTERVAL, lwIPPrivateHostTimer, NULL);
    #endif
    // Handles the timeout for the link detect timer when using a RTOS.
    #if !NO_SYS && (LWIP_AUTOIP || LWIP_DHCP)
    static void
    lwIPPrivateLinkTimer(void *pvArg)
        // Perform the link detection.
        lwIPLinkDetect();
        // Re-schedule the link detect timer timeout.
        sys_timeout(LINK_TMR_INTERVAL, lwIPPrivateLinkTimer, NULL);
    #endif
    // Completes the initialization of lwIP.  This is directly called when not
    // using a RTOS and provided as a callback to the TCP/IP thread when using a
    // RTOS.
    static void
    lwIPPrivateInit(void *pvArg)
        // If not using a RTOS, initialize the lwIP stack.
    #if NO_SYS
        lwip_init();
    #endif
        // If using a RTOS, create a queue (to be used as a semaphore) to signal
        // the Ethernet interrupt task from the Ethernet interrupt handler.
    #if !NO_SYS
    #if RTOS_FREERTOS
        g_pInterrupt = xQueueCreate(1, sizeof(void *));
    #endif
    #endif
        // If using a RTOS, create the Ethernet interrupt task.
    #if !NO_SYS
    #if RTOS_FREERTOS
        xTaskCreate(lwIPInterruptTask, (signed portCHAR *)"eth_int",
                    STACKSIZE_LWIPINTTASK, 0, tskIDLE_PRIORITY + 1,
                    0);
    #endif
    #endif
        // Setup the network address values.
        if(g_ui32IPMode == IPADDR_USE_STATIC)
            ip_addr.addr = htonl(g_ui32IPAddr);
            net_mask.addr = htonl(g_ui32NetMask);
            gw_addr.addr = htonl(g_ui32GWAddr);
        else
            ip_addr.addr = 0;
            net_mask.addr = 0;
            gw_addr.addr = 0;
        // Create, configure and add the Ethernet controller interface with
        // default settings.  ip_input should be used to send packets directly to
        // the stack when not using a RTOS and tcpip_input should be used to send
        // packets to the TCP/IP thread's queue when using a RTOS.
    #if NO_SYS
        netif_add(&g_sNetIF, &ip_addr, &net_mask, &gw_addr, NULL, tivaif_init,
                  ip_input);
    #else
                  tcpip_input);
    #endif
        netif_set_default(&g_sNetIF);
        // Bring the interface up.
        netif_set_up(&g_sNetIF);
        // Setup a timeout for the host timer callback function if using a RTOS.
    #endif
        // Setup a timeout for the link detect callback function if using a RTOS.
    #endif
    //! Initializes the lwIP TCP/IP stack.
    //! \param ui32SysClkHz is the current system clock rate in Hz.
    //! \param pui8MAC is a pointer to a six byte array containing the MAC
    //! address to be used for the interface.
    //! \param ui32IPAddr is the IP address to be used (static).
    //! \param ui32NetMask is the network mask to be used (static).
    //! \param ui32GWAddr is the Gateway address to be used (static).
    //! \param ui32IPMode is the IP Address Mode.  \b IPADDR_USE_STATIC will force
    //! static IP addressing to be used, \b IPADDR_USE_DHCP will force DHCP with
    //! fallback to Link Local (Auto IP), while \b IPADDR_USE_AUTOIP will force
    //! Link Local only.
    //! This function performs initialization of the lwIP TCP/IP stack for the
    //! Ethernet MAC, including DHCP and/or AutoIP, as configured.
    //! \return None.
    void
    lwIPInit(uint32_t ui32SysClkHz, const uint8_t *pui8MAC, uint32_t ui32IPAddr,
             uint32_t ui32NetMask, uint32_t ui32GWAddr, uint32_t ui32IPMode)
        // Check the parameters.
    #if LWIP_DHCP && LWIP_AUTOIP
        ASSERT((ui32IPMode == IPADDR_USE_STATIC) ||
               (ui32IPMode == IPADDR_USE_DHCP) ||
               (ui32IPMode == IPADDR_USE_AUTOIP));
    #elif LWIP_DHCP
               (ui32IPMode == IPADDR_USE_DHCP));
    #elif LWIP_AUTOIP
    #else
        ASSERT(ui32IPMode == IPADDR_USE_STATIC);
    #endif
        // Enable the ethernet peripheral.
        MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_EMAC0);
        MAP_SysCtlPeripheralReset(SYSCTL_PERIPH_EMAC0);
        // Enable the internal PHY if it's present and we're being
        // asked to use it.
        if((EMAC_PHY_CONFIG & EMAC_PHY_TYPE_MASK) == EMAC_PHY_TYPE_INTERNAL)
            // We've been asked to configure for use with the internal
            // PHY.  Is it present?
            if(MAP_SysCtlPeripheralPresent(SYSCTL_PERIPH_EPHY0))
                // Yes - enable and reset it.
                MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_EPHY0);
                MAP_SysCtlPeripheralReset(SYSCTL_PERIPH_EPHY0);
            else
                // Internal PHY is not present on this part so hang here.
                while(1)
        // Wait for the MAC to come out of reset.
        while(!MAP_SysCtlPeripheralReady(SYSCTL_PERIPH_EMAC0))
        // Configure for use with whichever PHY the user requires.
        EMACPHYConfigSet(EMAC0_BASE, EMAC_PHY_CONFIG);
        // Initialize the MAC and set the DMA mode.
        MAP_EMACInit(EMAC0_BASE, ui32SysClkHz,
                     EMAC_BCONFIG_MIXED_BURST | EMAC_BCONFIG_PRIORITY_FIXED,
                     4, 4, 0);
        // Set MAC configuration options.
        MAP_EMACConfigSet(EMAC0_BASE, (EMAC_CONFIG_FULL_DUPLEX |
                                       EMAC_CONFIG_CHECKSUM_OFFLOAD |
                                       EMAC_CONFIG_7BYTE_PREAMBLE |
                                       EMAC_CONFIG_IF_GAP_96BITS |
                                       EMAC_CONFIG_USE_MACADDR0 |
                                       EMAC_CONFIG_SA_FROM_DESCRIPTOR |
                                       EMAC_CONFIG_BO_LIMIT_1024),
                          (EMAC_MODE_RX_STORE_FORWARD |
                           EMAC_MODE_TX_STORE_FORWARD |
                           EMAC_MODE_TX_THRESHOLD_64_BYTES |
                           EMAC_MODE_RX_THRESHOLD_64_BYTES), 0);
        // Program the hardware with its MAC address (for filtering).
        MAP_EMACAddrSet(EMAC0_BASE, 0, (uint8_t *)pui8MAC);
        EMACPHYExtendedWrite(EMAC0_BASE, 0, EPHY_LEDCFG, 0x0588);  //set LED1 Configuration : Link OK/Blink on TX/RX Activity(0x8)
        // Save the network configuration for later use by the private
        // initialization.
        g_ui32IPMode = ui32IPMode;
        g_ui32IPAddr = ui32IPAddr;
        g_ui32NetMask = ui32NetMask;
        g_ui32GWAddr = ui32GWAddr;
        // Initialize lwIP.  The remainder of initialization is done immediately if
        // not using a RTOS and it is deferred to the TCP/IP thread's context if
        // using a RTOS.
    #if NO_SYS
        lwIPPrivateInit(0);
    #else
        tcpip_init(lwIPPrivateInit, 0);
    #endif
    //! Registers an interrupt callback function to handle the IEEE-1588 timer.
    //! \param pfnTimerFunc points to a function which is called whenever the
    //! Ethernet MAC reports an interrupt relating to the IEEE-1588 hardware timer.
    //! This function allows an application to register a handler for all
    //! interrupts generated by the IEEE-1588 hardware timer in the Ethernet MAC.
    //! To allow minimal latency timer handling, the callback function provided
    //! will be called in interrupt context, regardless of whether or not lwIP is
    //! configured to operate with an RTOS.  In an RTOS environment, the callback
    //! function is responsible for ensuring that all processing it performs is
    //! compatible with the low level interrupt context it is called in.
    //! The callback function takes two parameters.  The first is the base address
    //! of the MAC reporting the timer interrupt and the second is the timer
    //! interrupt status as reported by EMACTimestampIntStatus().  Note that
    //! EMACTimestampIntStatus() causes the timer interrupt sources to be cleared
    //! so the application should not call EMACTimestampIntStatus() within the
    //! handler.
    //! \return None.
    void
    lwIPTimerCallbackRegister(tHardwareTimerHandler pfnTimerFunc)
        // Remember the callback function address passed.
        g_pfnTimerHandler = pfnTimerFunc;
    //! Handles periodic timer events for the lwIP TCP/IP stack.
    //! \param ui32TimeMS is the incremental time for this periodic interrupt.
    //! This function will update the local timer by the value in \e ui32TimeMS.
    //! If the system is configured for use without an RTOS, an Ethernet interrupt
    //! will be triggered to allow the lwIP periodic timers to be serviced in the
    //! Ethernet interrupt.
    //! \return None.
    #if NO_SYS
    void
    lwIPTimer(uint32_t ui32TimeMS)
        // Increment the lwIP Ethernet timer.
        g_ui32LocalTimer += ui32TimeMS;
        // Generate an Ethernet interrupt.  This will perform the actual work
        // of checking the lwIP timers and taking the appropriate actions.  This is
        // needed since lwIP is not re-entrant, and this allows all lwIP calls to
        // be placed inside the Ethernet interrupt handler ensuring that all calls
        // into lwIP are coming from the same context, preventing any reentrancy
        // issues.  Putting all the lwIP calls in the Ethernet interrupt handler
        // avoids the use of mutexes to avoid re-entering lwIP.
        HWREG(NVIC_SW_TRIG) |= INT_EMAC0 - 16;
    #endif
    //! Handles Ethernet interrupts for the lwIP TCP/IP stack.
    //! This function handles Ethernet interrupts for the lwIP TCP/IP stack.  At
    //! the lowest level, all receive packets are placed into a packet queue for
    //! processing at a higher level.  Also, the transmit packet queue is checked
    //! and packets are drained and transmitted through the Ethernet MAC as needed.
    //! If the system is configured without an RTOS, additional processing is
    //! performed at the interrupt level.  The packet queues are processed by the
    //! lwIP TCP/IP code, and lwIP periodic timers are serviced (as needed).
    //! \return None.
    void
    lwIPEthernetIntHandler(void)
        uint32_t ui32Status;
        uint32_t ui32TimerStatus;
    #if !NO_SYS
        portBASE_TYPE xWake;
    #endif
        // Read and Clear the interrupt.
        ui32Status = EMACIntStatus(EMAC0_BASE, true);
    #if EEE_SUPPORT
        if(ui32Status & EMAC_INT_LPI)
            EMACLPIStatus(EMAC0_BASE);
    #endif
        // If the PMT mode exit status bit is set then enable the MAC transmit
        // and receive paths, read the PMT status to clear the interrupt and
        // clear the interrupt flag.
        if(ui32Status & EMAC_INT_POWER_MGMNT)
            MAP_EMACTxEnable(EMAC0_BASE);
            MAP_EMACRxEnable(EMAC0_BASE);
            EMACPowerManagementStatusGet(EMAC0_BASE);
            ui32Status &= ~(EMAC_INT_POWER_MGMNT);
        // If the interrupt really came from the Ethernet and not our
        // timer, clear it.
        if(ui32Status)
            MAP_EMACIntClear(EMAC0_BASE, ui32Status);
        // Check to see whether a hardware timer interrupt has been reported.
        if(ui32Status & EMAC_INT_TIMESTAMP)
            // Yes - read and clear the timestamp interrupt status.
            ui32TimerStatus = EMACTimestampIntStatus(EMAC0_BASE);
            // If a timer interrupt handler has been registered, call it.
            if(g_pfnTimerHandler)
                g_pfnTimerHandler(EMAC0_BASE, ui32TimerStatus);
        // The handling of the interrupt is different based on the use of a RTOS.
    #if NO_SYS
        // No RTOS is being used.  If a transmit/receive interrupt was active,
        // run the low-level interrupt handler.
        if(ui32Status)
            tivaif_interrupt(&g_sNetIF, ui32Status);
        // Service the lwIP timers.
        lwIPServiceTimers();
    #else
        // A RTOS is being used.  Signal the Ethernet interrupt task.
        xQueueSendFromISR(g_pInterrupt, (void *)&ui32Status, &xWake);
        // Disable the Ethernet interrupts.  Since the interrupts have not been
        // handled, they are not asserted.  Once they are handled by the Ethernet
        // interrupt task, it will re-enable the interrupts.
        MAP_EMACIntDisable(EMAC0_BASE, (EMAC_INT_RECEIVE | EMAC_INT_TRANSMIT |
        // Potentially task switch as a result of the above queue write.
    #if RTOS_FREERTOS
        if(xWake == pdTRUE)
            portYIELD_FROM_ISR(true);
    #endif
    #endif
    //! Returns the IP address for this interface.
    //! This function will read and return the currently assigned IP address for
    //! the Stellaris Ethernet interface.
    //! \return Returns the assigned IP address for this interface.
    uint32_t
    lwIPLocalIPAddrGet(void)
        if(g_bLinkActive)
            return((uint32_t)g_sNetIF.ip_addr.addr);
        else
            return(0xffffffff);
    #else
    #endif
    //! Returns the network mask for this interface.
    //! This function will read and return the currently assigned network mask for
    //! \return the assigned network mask for this interface.
    uint32_t
    lwIPLocalNetMaskGet(void)
        return((uint32_t)g_sNetIF.netmask.addr);
    //! Returns the gateway address for this interface.
    //! This function will read and return the currently assigned gateway address
    //! for the Stellaris Ethernet interface.
    //! \return the assigned gateway address for this interface.
    uint32_t
    lwIPLocalGWAddrGet(void)
        return((uint32_t)g_sNetIF.gw.addr);
    //! Returns the local MAC/HW address for this interface.
    //! \param pui8MAC is a pointer to an array of bytes used to store the MAC
    //! address.
    //! This function will read the currently assigned MAC address into the array
    //! passed in \e pui8MAC.
    //! \return None.
    void
    lwIPLocalMACGet(uint8_t *pui8MAC)
        MAP_EMACAddrGet(EMAC0_BASE, 0, pui8MAC);
    // Completes the network configuration change.  This is directly called when
    // not using a RTOS and provided as a callback to the TCP/IP thread when using
    // a RTOS.
    static void
    lwIPPrivateNetworkConfigChange(void *pvArg)
        uint32_t ui32IPMode;
        // Get the new address mode.
        ui32IPMode = (uint32_t)pvArg;
        if(ui32IPMode == IPADDR_USE_STATIC)
    #if LWIP_DHCP || LWIP_AUTOIP
        else
            ip_addr.addr = 0;
            net_mask.addr = 0;
            gw_addr.addr = 0;
    #endif
        // Switch on the current IP Address Aquisition mode.
        switch(g_ui32IPMode)
            // Static IP
            case IPADDR_USE_STATIC:
                // Set the new address parameters.  This will change the address
                // configuration in lwIP, and if necessary, will reset any links
                // that are active.  This is valid for all three modes.
                // If we are going to DHCP mode, then start the DHCP server now.
    #if LWIP_DHCP
                if((ui32IPMode == IPADDR_USE_DHCP) && g_bLinkActive)
    #endif
                // If we are going to AutoIP mode, then start the AutoIP process
                // now.
    #if LWIP_AUTOIP
                if((ui32IPMode == IPADDR_USE_AUTOIP) && g_bLinkActive)
    #endif
                // And we're done.
                break;
            // DHCP (with AutoIP fallback).
    #if LWIP_DHCP
            case IPADDR_USE_DHCP:
                // If we are going to static IP addressing, then disable DHCP and
                // force the new static IP address.
                // If we are going to AUTO IP addressing, then disable DHCP, set
                // the default addresses, and start AutoIP.
    #if LWIP_AUTOIP
                else if(ui32IPMode == IPADDR_USE_AUTOIP)
                    if(g_bLinkActive)
    #endif
                break;
    #endif
            // AUTOIP
    #if LWIP_AUTOIP
            case IPADDR_USE_AUTOIP:
                // If we are going to static IP addressing, then disable AutoIP and
                // If we are going to DHCP addressing, then disable AutoIP, set the
                // default addresses, and start dhcp.
    #if LWIP_DHCP
                else if(ui32IPMode == IPADDR_USE_DHCP)
                    if(g_bLinkActive)
    #endif
                break;
    #endif
        // Save the new mode.
    //! Change the configuration of the lwIP network interface.
    //! \param ui32IPAddr is the new IP address to be used (static).
    //! \param ui32NetMask is the new network mask to be used (static).
    //! \param ui32GWAddr is the new Gateway address to be used (static).
    //! \param ui32IPMode is the IP Address Mode.  \b IPADDR_USE_STATIC 0 will
    //! force static IP addressing to be used, \b IPADDR_USE_DHCP will force DHCP
    //! with fallback to Link Local (Auto IP), while \b IPADDR_USE_AUTOIP will
    //! force Link Local only.
    //! This function will evaluate the new configuration data.  If necessary, the
    //! interface will be brought down, reconfigured, and then brought back up
    //! with the new configuration.
    //! \return None.
    void
    lwIPNetworkConfigChange(uint32_t ui32IPAddr, uint32_t ui32NetMask,
    #elif LWIP_DHCP
    #elif LWIP_AUTOIP
    #else
    #endif
        // Save the network configuration for later use by the private network
        // configuration change.
        // Complete the network configuration change.  The remainder is done
        // immediately if not using a RTOS and it is deferred to the TCP/IP
        // thread's context if using a RTOS.
    #if NO_SYS
        lwIPPrivateNetworkConfigChange((void *)ui32IPMode);
    #else
        tcpip_callback(lwIPPrivateNetworkConfigChange, (void *)ui32IPMode);
    #endif
    // Close the Doxygen group.
  • thanks again!
