CCS/TM4C1294NCPDT: Different adc for channel 2 and channel 3 not working, only ch0 and ch1 are working else other channel not working
Part Number: TM4C1294NCPDT
Hii
I have written the code to read the different adc channel.
connection for chanel 0 and channel 1
PE3-AIN0----connected to external voltage
PE2-AIN1----shorted with launchpad GND
External voltage ground is shorted with launchapd GND
Whatever the voltage i am applying on AIN0 I am getting the same voltage but when I am doing the same connection on channel 2 and channel 3 then its not working
PE1-AIN2----connected to external voltage
PE0-AIN3----shorted with launchpad GND
Below code I have tried once go through it and let me know if I am doing any wrong
void DifferentialADCInit()
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
GPIOPinTypeADC(GPIO_PORTD_BASE, GPIO_PIN_6 | GPIO_PIN_7);
ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_PROCESSOR, 0);
ADCSequenceStepConfigure(ADC0_BASE, 3, 0, ADC_CTL_CH2  |  ADC_CTL_D | ADC_CTL_IE | ADC_CTL_END);
ADCSequenceEnable(ADC0_BASE, 3);
void DifferentialADCRead()
ADCIntClear(ADC0_BASE,3);
ADCProcessorTrigger(ADC0_BASE,3);
while(!ADCIntStatus(ADC0_BASE, 3,false));
ADCSequenceDataGet(ADC0_BASE, 3,Diff_Read);
diff_out1 = ((Diff_Read[0]-2048)*3.3)/2048.0;
int main(void)
ui32SysClock = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480), 120000000);
DifferentialADCInit();
while(1)
DifferentialADCRead();
SysCtlDelay(4000000);
      You wrote the below code to configure PD6 and PD7 for ADC. The PD6 and PD7 corresponds to AIN5 and AIN4. If you want to use AIN2 and AIN3 then you need to change to PE1 and PE0.
  • Hii Charles
    Thanks for your response. I did the same configuartion for Channel2 and Channel3 for differential mode
    GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_1 | GPIO_PIN_0);
    and It did not work. Then I try to check on Channel4 and Channel 5(AIN4,AIN5) and it also not working.
    PD7-AIN4----connected to external voltage
    PD6-AIN5----shorted with launchpad GND
    Only AIN0 and AIN1 is working fine in differential mode.
    My requirement is  to read three adc channel in differential mode.
    Kindly suggest some sample code.
    Thanks & Regard
    Anamika
  • Hii Charles
    Sample code what I have tried is mentioned below once go through it for channel4 and channel5.And its not working
    ADCSequenceStepConfigure(ADC0_BASE, 3, 0, ADC_CTL_CH4  |  ADC_CTL_D | ADC_CTL_IE | ADC_CTL_END);
    int main(void)
    while(1)
    Thanks & regard
    Anamika
      When you are using differential mode, the ADC_CTL_CH1 denotes pair 1 which correspond to AIN2 and AIN3. If you want to use  AIN4 and AIN5, you will specify ADC_CTL_CH2 as pair 2. You specify ADC_CTL_CH4 for pair 4 which corresponds to AIN8 and AIN9.
  • Hii Charles,
    Thanks for your response. By selecting the correct channel pair selection its working,
    Appreciate your suggestion.
    Thanks & regard
    Anamika
