Compiler/LAUNCHXL2-RM57L: Problem with C/C++ compiler, error #100 along all CCS project
Part Number: LAUNCHXL2-RM57L
Hi
I'm currently using CCS to program RM57L. Last day I install Dev C++ for a rapid test, but after that dev C++ was uninstalled. When I restart work over CCS, I try to build the last project but didn't work. Project build was not possible and return a large list (near of 300) of the same type of errors, "#100 a declaration here must declare a parameter". I uninstalled CCS and install it again, but the problem persists.
Errors are spread along with all kinds of scripts since .c my own created .h and .c files, c libraries, and RM57L peripherals libraries.
I test other CCS projects, and they work normally.
Problems seem to be related to the compiler.
What should I do to fix this issue?
Thanks for your time
C.R
