EK-TM4C1294XL: Tiva c connect to server with ndk socket
Part Number: EK-TM4C1294XL
Greatings,
I am trying to establish a raw socket connection between my windows 10 pc (which has a service waiting for incoming connections) and the tiva board (client)
Pc and Board are connected to a hub which is connected to my router.
I have the Ip of my pc as destination, the port on which the pc is accepting is the port the client is trying to connect to.
I am using RTOS on the tiva board and the whole connection is in a task function.
I configured static ip for the board which has the same mask and gateway as the pc (both devices on the same hub).
 * rtos base-system configuration for TI-RTOS 2.16 and above
 * (c) DIScoVER 2015, 2016
 *  ======== application.cfg ========
var Types = xdc.useModule('xdc.runtime.Types');
 * This module defines basic constants and types used throughout the
 * xdc.runtime package.
var mwConfig = xdc.useModule('ti.mw.Config');
 * Include TI-RTOS middleware libraries
/* ================ General configuration ================ */
var Defaults = xdc.useModule('xdc.runtime.Defaults');
/* Allow object view tools to display names of instance objects. */
Defaults.common$.namedInstance = true;
 * A flag to allow module names to be loaded on the target. Module name
 * strings are placed in the .const section for debugging purposes.
 * Pick one:
 *  - true (default)
 *      Setting this parameter to true will include name strings in the .const
 *      section so that Errors and Asserts are easier to debug.
 *  - false
 *      Setting this parameter to false will reduce footprint in the .const
 *      section. As a result, Error and Assert messages will contain an
 *      "unknown module" prefix instead of the actual module name.
Defaults.common$.namedModule = true;
var Mailbox = xdc.useModule('ti.sysbios.knl.Mailbox');
var Event = xdc.useModule('ti.sysbios.knl.Event');
var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
var Timer = xdc.useModule('ti.sysbios.hal.Timer');
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
var LogSnapshot = xdc.useModule('ti.uia.runtime.LogSnapshot');
/* ================ Error configuration ================ */
var Error = xdc.useModule('xdc.runtime.Error');
 * This function is called to handle all raised errors, but unlike
 * Error.raiseHook, this function is responsible for completely handling the
 * error with an appropriately initialized Error_Block.
 * Pick one:
 *  - Error.policyDefault (default)
 *      Calls Error.raiseHook with an initialized Error_Block structure and logs
 *      the error using the module's logger.
 *  - Error.policySpin
 *      Simple alternative that traps on a while(1) loop for minimized target
 *      footprint.
 *      Using Error.policySpin, the Error.raiseHook will NOT called.
Error.policyFxn = Error.policyDefault;
//Error.policyFxn = Error.policySpin;
 * If Error.policyFxn is set to Error.policyDefault, this function is called
 * whenever an error is raised by the Error module.
 * Pick one:
 *  - Error.print (default)
 *      Errors are formatted and output via System_printf() for easier
 *      debugging.
 *  - null
 *      Errors are not formatted or logged. This option reduces code footprint.
 *  - non-null function
 *      Errors invoke custom user function. See the Error module documentation
 *      for more details.
Error.raiseHook = Error.print;
//Error.raiseHook = null;
//Error.raiseHook = "&myErrorFxn";
 * If Error.policyFxn is set to Error.policyDefault, this option applies to the
 * maximum number of times the Error.raiseHook function can be recursively
 * invoked. This option limits the possibility of an infinite recursion that
 * could lead to a stack overflow.
 * The default value is 16.
Error.maxDepth = 2;
var Diags = xdc.useModule('xdc.runtime.Diags');
var Log = xdc.useModule('xdc.runtime.Log');
var Main = xdc.useModule('xdc.runtime.Main');
var System = xdc.useModule('xdc.runtime.System');
var xdc_runtime_Timestamp = xdc.useModule('xdc.runtime.Timestamp');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
//var FatFS = xdc.useModule('ti.sysbios.fatfs.FatFS');
/* ================ Hwi configuration ================ */
var halHwi = xdc.useModule('ti.sysbios.hal.Hwi');
var m3Hwi = xdc.useModule('ti.sysbios.family.arm.m3.Hwi');
 * Checks for Hwi (system) stack overruns while in the Idle loop.
 * Pick one:
 *  - true (default)
 *      Checks the top word for system stack overflows during the idle loop and
 *      raises an Error if one is detected.
 *  - false
 *      Disabling the runtime check improves runtime performance and yields a
 *      reduced flash footprint.
halHwi.checkStackFlag = true;
//halHwi.checkStackFlag = false;
 * The following options alter the system's behavior when a hardware exception
 * is detected.
 * Pick one:
 *  - Hwi.enableException = true
 *      This option causes the default m3Hwi.excHandlerFunc function to fully
 *      decode an exception and dump the registers to the system console.
 *      This option raises errors in the Error module and displays the
 *      exception in ROV.
 *  - Hwi.enableException = false
 *      This option reduces code footprint by not decoding or printing the
 *      exception to the system console.
 *      It however still raises errors in the Error module and displays the
 *      exception in ROV.
 *  - Hwi.excHandlerFunc = null
 *      This is the most aggressive option for code footprint savings; but it
 *      can difficult to debug exceptions. It reduces flash footprint by
 *      plugging in a default while(1) trap when exception occur. This option
 *      does not raise an error with the Error module.
m3Hwi.enableException = true;
//m3Hwi.enableException = false;
//m3Hwi.excHandlerFunc = null;
 * Enable hardware exception generation when dividing by zero.
 * Pick one:
 *  - 0 (default)
 *      Disables hardware exceptions when dividing by zero
 *  - 1
 *      Enables hardware exceptions when dividing by zero
m3Hwi.nvicCCR.DIV_0_TRP = 0;
//m3Hwi.nvicCCR.DIV_0_TRP = 1;
 * Enable hardware exception generation for invalid data alignment.
 * Pick one:
 *  - 0 (default)
 *      Disables hardware exceptions for data alignment
 *  - 1
 *      Enables hardware exceptions for data alignment
m3Hwi.nvicCCR.UNALIGN_TRP = 0;
//m3Hwi.nvicCCR.UNALIGN_TRP = 1;
/* ================ Idle configuration ================ */
var Idle = xdc.useModule('ti.sysbios.knl.Idle');
 * The Idle module is used to specify a list of functions to be called when no
 * other tasks are running in the system.
 * Functions added here will be run continuously within the idle task.
 * Function signature:
 *     Void func(Void);
//Idle.addFunc("&myIdleFunc");
/* ================ Clock configuration ================ */
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
 * Default value is family dependent. For example, Linux systems often only
 * support a minimum period of 10000 us and multiples of 10000 us.
 * TI platforms have a default of 1000 us.
Clock.tickPeriod = 1000;
/* ================ System configuration ================ */
System.extendedFormats = "%$L%$S%$F%f";
 * The Abort handler is called when the system exits abnormally.
 * Pick one:
 *  - System.abortStd (default)
 *      Call the ANSI C Standard 'abort()' to terminate the application.
 *  - System.abortSpin
 *      A lightweight abort function that loops indefinitely in a while(1) trap
 *      function.
 *  - A custom abort handler
 *      A user-defined function. See the System module documentation for
 *      details.
//System.abortFxn = System.abortStd;
 * The Exit handler is called when the system exits normally.
 * Pick one:
 *  - System.exitStd (default)
 *      Call the ANSI C Standard 'exit()' to terminate the application.
 *  - System.exitSpin
 *      A lightweight exit function that loops indefinitely in a while(1) trap
 *      function.
 *  - A custom exit function
 *      details.
// System.exitFxn = System.exitStd;
 * Minimize exit handler array in the System module. The System module includes
 * an array of functions that are registered with System_atexit() which is
 * called by System_exit(). The default value is 8.
System.maxAtexitHandlers = 2;
 * The System.SupportProxy defines a low-level implementation of System
 * functions such as System_printf(), System_flush(), etc.
 * Pick one pair:
 *  - SysMin
 *      This module maintains an internal configurable circular buffer that
 *      stores the output until System_flush() is called.
 *      The size of the circular buffer is set via SysMin.bufSize.
 *  - SysCallback
 *      SysCallback allows for user-defined implementations for System APIs.
 *      The SysCallback support proxy has a smaller code footprint and can be
 *      used to supply custom System_printf services.
 *      The default SysCallback functions point to stub functions. See the
 *      SysCallback module's documentation.
var SysMin = xdc.useModule('xdc.runtime.SysMin');
SysMin.bufSize = 1024;
System.SupportProxy = SysMin;
//var SysCallback = xdc.useModule('xdc.runtime.SysCallback');
//System.SupportProxy = SysCallback;
//SysCallback.abortFxn = "&myUserAbort";
//SysCallback.exitFxn  = "&myUserExit";
//SysCallback.flushFxn = "&myUserFlush";
//SysCallback.putchFxn = "&myUserPutch";
//SysCallback.readyFxn = "&myUserReady";
/* ================ Kernel (SYS/BIOS) configuration ================ */
var BIOS = xdc.useModule('ti.sysbios.BIOS');
 * Enable asserts in the BIOS library.
 * Pick one:
 *  - true (default)
 *      Enables asserts for debugging purposes.
 *  - false
 *      Disables asserts for a reduced code footprint and better performance.
//BIOS.assertsEnabled = false;
 * Specify default heap size for BIOS.
BIOS.heapSize = 1024*10*2;
 * A flag to determine if xdc.runtime sources are to be included in a custom
 * built BIOS library.
 * Pick one:
 *  - false (default)
 *      The pre-built xdc.runtime library is provided by the respective target
 *      used to build the application.
 *  - true
 *      xdc.runtime library sources are to be included in the custom BIOS
 *      library. This option yields the most efficient library in both code
 *      footprint and runtime performance.
BIOS.includeXdcRuntime = true;
 * The SYS/BIOS runtime is provided in the form of a library that is linked
 * with the application. Several forms of this library are provided with the
 * SYS/BIOS product.
 * Pick one:
 *   - BIOS.LibType_Custom
 *      Custom built library that is highly optimized for code footprint and
 *      runtime performance.
 *   - BIOS.LibType_Debug
 *      Custom built library that is non-optimized that can be used to
 *      single-step through APIs with a debugger.
BIOS.libType = BIOS.LibType_Custom;
 * Runtime instance creation enable flag.
 * Pick one:
 *   - true (default)
 *      Allows Mod_create() and Mod_delete() to be called at runtime which
 *      requires a default heap for dynamic memory allocation.
 *   - false
 *      Reduces code footprint by disallowing Mod_create() and Mod_delete() to
 *      be called at runtime. Object instances are constructed via
 *      Mod_construct() and destructed via Mod_destruct().
BIOS.runtimeCreatesEnabled = true;
//BIOS.runtimeCreatesEnabled = false;
 * Enable logs in the BIOS library.
 * Pick one:
 *  - true (default)
 *      Enables logs for debugging purposes.
 *  - false
 *      Disables logging for reduced code footprint and improved runtime
 *      performance.
//BIOS.logsEnabled = false;
/* ================ Memory configuration ================ */
var Memory = xdc.useModule('xdc.runtime.Memory');
 * The Memory module itself simply provides a common interface for any
 * variety of system and application specific memory management policies
 * implemented by the IHeap modules(Ex. HeapMem, HeapBuf).
/* ================ Task configuration ================ */
var Task = xdc.useModule('ti.sysbios.knl.Task');
 * Check task stacks for overflow conditions.
 * Pick one:
 *  - true (default)
 *      Enables runtime checks for task stack overflow conditions during
 *      context switching ("from" and "to")
 *  - false
 *      Disables runtime checks for task stack overflow conditions.
Task.checkStackFlag = true;
//Task.checkStackFlag = false;
 * Set the default task stack size when creating tasks.
 * The default is dependent on the device being used. Reducing the default stack
 * size yields greater memory savings.
Task.defaultStackSize = 512;
 * Enables the idle task.
 * Pick one:
 *  - true (default)
 *      Creates a task with priority of 0 which calls idle hook functions. This
 *      option must be set to true to gain power savings provided by the Power
 *      module.
 *  - false
 *      No idle task is created. This option consumes less memory as no
 *      additional default task stack is needed.
 *      To gain power savings by the Power module without having the idle task,
 *      add Idle.run as the Task.allBlockedFunc.
Task.enableIdleTask = true;
//Task.enableIdleTask = false;
//Task.allBlockedFunc = Idle.run;
 * If Task.enableIdleTask is set to true, this option sets the idle task's
 * stack size.
 * Reducing the idle stack size yields greater memory savings.
Task.idleTaskStackSize = 512;
 * Reduce the number of task priorities.
 * The default is 16.
 * Decreasing the number of task priorities yield memory savings.
Task.numPriorities = 16;
/* ================ Semaphore configuration ================ */
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
 * Enables global support for Task priority pend queuing.
 * Pick one:
 *  - true (default)
 *      This allows pending tasks to be serviced based on their task priority.
 *  - false
 *      Pending tasks are services based on first in, first out basis.
 *  When using BIOS in ROM:
 *      This option must be set to false.
Semaphore.supportsPriority = true;
//Semaphore.supportsPriority = false;
 * Allows for the implicit posting of events through the semaphore,
 * disable for additional code saving.
 * Pick one:
 *  - true
 *      This allows the Semaphore module to post semaphores and events
 *      simultaneously.
 *  - false (default)
 *      Events must be explicitly posted to unblock tasks.
//Semaphore.supportsEvents = true;
/* ================ Text configuration ================ */
var Text = xdc.useModule('xdc.runtime.Text');
 * These strings are placed in the .const section. Setting this parameter to
 * false will save space in the .const section. Error, Assert and Log messages
 * will print raw ids and args instead of a formatted message.
 * Pick one:
 *  - true (default)
 *      This option loads test string into the .const for easier debugging.
 *  - false
 *      This option reduces the .const footprint.
Text.isLoaded = true;
//Text.isLoaded = false;
/* ================ TI-RTOS drivers' configuration ================ */
var driversConfig = xdc.useModule('ti.drivers.Config');
 * Include TI-RTOS drivers
 * Pick one:
 *  - driversConfig.LibType_NonInstrumented (default)
 *      Use TI-RTOS drivers library optimized for footprint and performance
 *      without asserts or logs.
 *  - driversConfig.LibType_Instrumented
 *      Use TI-RTOS drivers library for debugging with asserts and logs enabled.
//driversConfig.libType = driversConfig.LibType_Instrumented;
/* =========== Instrumentation configuration =========== */
/* Deactivate RTOS assertions */
/* Deactivate assertions and logging for drivers */
driversConfig.libType = driversConfig.LibType_NonInstrumented;
/* Add hooks for UIA to monitor task creation and task switches */
Task.addHookSet ({ createFxn: '&tskCreateHook', });
LoggingSetup.snapshotLogging = true
/* ================ NDK configuration ================ */
var Ndk       = xdc.loadPackage('ti.ndk.config');
var Global    = xdc.useModule('ti.ndk.config.Global');
var Ip        = xdc.useModule('ti.ndk.config.Ip');
var Tcp       = xdc.useModule('ti.ndk.config.Tcp');
Tcp.transmitBufSize = 16384;
Tcp.receiveBufSize = 65536;
Tcp.receiveBufLimit = 65536;
Global.ndkTickPeriod = 100;
Global.kernTaskPriLevel = 11;
Global.serviceReportHook = null;
Global.IPv6 = false;
/* Settings for static IP configuration */
Ip.ResolveIP = false;
Ip.CallByIP = false;
Ip.autoIp = false;
Ip.address = "192.168.178.99";
Ip.mask = "255.255.255.0";
Ip.gatewayIpAddr = "192.168.178.1";
Code:
#define TCPPACKETSIZE 255
extern int inet_addr(const char *str);
int setup_Network_Task(int prio, uint32_t wait_ticks) {
    Task_Params taskParams;
    Task_Handle task;
    Error_Block eb;
    Error_init(&eb);
    Task_Params_init(&taskParams);
    taskParams.stackSize = 1024;
    taskParams.priority = prio;
    taskParams.arg0 = (UArg)wait_ticks;
    task = Task_create((Task_FuncPtr)networkFxn, &taskParams, &eb);
    if(task == NULL) {
        System_abort("Task create failed");
    return (0);
static int tryCounter = 0;
void networkFxn(UArg arg0) {
    uint32_t wait_ticks = (uint32_t) arg0;
    SOCKET clientfd;
    struct sockaddr_in sLocalAddr;
    int nbytes;
    bool flag = true;
    char *buffer;
    Error_Block eb;
    clientfd = socket(AF_INET, SOCK_STREAM, IPPROTO_IP);
    if (clientfd < 0) {
        if(DEBUG) {
            System_printf("tcpHandler: socket failed\n");
            System_flush();
        Task_exit();
        return;
    if(DEBUG) {
        System_printf("socket success\n");
        System_flush();
    memset((char *)&sLocalAddr, 0, sizeof(sLocalAddr));
    sLocalAddr.sin_family = AF_INET;
//    sLocalAddr.sin_len = sizeof(sLocalAddr);
    sLocalAddr.sin_addr.s_addr = inet_addr("192.168.178.170");
    sLocalAddr.sin_port = htons(11000);
    Task_sleep(2000);
    int connectStatus = connect(clientfd, (struct sockaddr *)&sLocalAddr, sizeof(sLocalAddr));
    if(DEBUG) {
        System_printf("Connection status: %d \n", connectStatus);
        System_flush();
    if(connectStatus < 0) {
       if(DEBUG) {
           System_printf("Connection failed %d \n", fdError());
           System_flush();
       if(tryCounter > 5) {
           Task_exit();
           return;
       tryCounter++;
       Task_sleep(1000);
       networkFxn(wait_ticks);
    if (DEBUG) {
        System_printf("Connected!\n");
        System_flush();
    fdOpenSession(TaskSelf());
    if (DEBUG) {
        System_printf("tcpWorker: start clientfd = 0x%x\n", clientfd);
        System_flush();
    /* Make sure Error_Block is initialized */
    Error_init(&eb);
    /* Get a buffer to receive incoming packets. Use the default heap. */
    buffer = Memory_alloc(NULL, TCPPACKETSIZE, 0, &eb);
    if (buffer == NULL) {
        if (DEBUG) {
            System_printf("tcpWorker: failed to alloc memory\n");
            System_flush();
        Task_exit();
    /* Loop while we receive data */
    while (flag) {
        nbytes = recv(clientfd, (char *)buffer, TCPPACKETSIZE, 0);
        if (nbytes > 0) {
            /* Echo the data back */
            nbytes = 15;
            char *sendBuffer = "I like turtles.";
            send(clientfd, (char *)sendBuffer, sizeof(sendBuffer), 0 );
        else {
            fdClose(clientfd);
            flag = false;
        Task_sleep(wait_ticks);
    if(DEBUG) {
        System_printf("tcpWorker stop clientfd = 0x%x\n", clientfd);
        System_flush();
    /* Free the buffer back to the heap */
    Memory_free(NULL, buffer, TCPPACKETSIZE);
    fdCloseSession(TaskSelf());
     *  Since deleteTerminatedTasks is set in the cfg file,
     *  the Task will be deleted when the idle task runs.
    Task_exit();
Basically the connect gets me -1 and fdError() gives me -1 too, I m not sure what -1 means because the doc describes:
" If it succeeds, the function returns 0. Otherwise, a value of -1 is returned and the function fdError() can be called to determine the error:"
http://software-dl.ti.com/simplelink/esd/simplelink_msp432e4_sdk/2.30.00.14/docs/ndk/NDK_API_Reference.html#sockets-and-stream-io-api
I m unsure what I m doing wrong, what is missing.
