LAUNCHXL2-570LC43: Eathernet connection issues
Part Number: LAUNCHXL2-570LC43
Hallo TI,
Currently I am suing LaunchXL2-TMS570LC43 board to establish a eathernet connection between the evalution board and a power line communication(PLC) board (DLAN Green PHY Module to be specific).
I could run the Active webserver application and able to get the IP address of my router successfully. However when I try the same application by connecting LAUNCHXL2-570LC43 board to DLAN Green PHY Module via RJ-45 cable I cound not read the IP address of the PLC board, eventhough DHCP of the PLC module is alredy set to Automatic.
Here the messge log from my terminal window after running the application:
HERCULES MICROCONTROLLERS
Texas Instruments
Little Endian device
Initializing ethernet (DHCP)
DEBUG - Getting PHY ID....SUCCESS
DEBUG - Getting PHY Alive Status...SUCCESS
DEBUG - Getting PHY Link Status...SUCCESS
DEBUG - Setting up Link...SUCCESS
..DONE
-------- ERROR INITIALIZING HARDWARE --------
I could try to use the Static_Ip_address, however I would like to know what else could block from geting the IP automaticlly.
Tahnk you.
Best Regars,
Venkatesh
