Part Number: EK-TM4C1294XL
Other Parts Discussed in Thread: TM4C1294NCPDT
I tried running someone else's project code but I keep getting errors and the error said to ask here because it is an issue with the compiler
**** Build of configuration Debug for project CMMSM_FW_newCmd ****
"C:\\ti\\ccs1010\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
Building file: "../USB/usb_structs.c"
Invoking: ARM Compiler
"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/marwa/Desktop/ControleModuleForSwitchingMatrix(CMSM)/Cippà _TB_CMMSM_Report_Annex/Digital/CMMSM_ccs_workspace_V9/CMMSM_FW_newCmd" --include_path="C:/ti/TivaWare_C_Series-2.2.0.295" --include_path="C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="USB/usb_structs.d_raw" --obj_directory="USB" "../USB/usb_structs.c"
USB/subdir_rules.mk:9: recipe for target 'USB/usb_structs.obj' failed
INTERNAL ERROR: C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armcl had an internal inconsistency and aborted
while processing file ../USB/usb_structs.c
This is caused by a defect in the TI C/C++ Compiler.
TI Customer Support may be able to suggest a workaround to avoid this.
Upgrading to the newest version of the compiler may fix this problem.
Contact TI in the E2E support forums at http://e2e.ti.com under
"Development Tools", "TI C/C++ Compiler". See the link titled
"Submitting an issue".
We need to see this ENTIRE error message and a complete, reproducible
test case including ALL of the command-line options.
gmake: *** [USB/usb_structs.obj] Error 2
Building file: "../USB/usb_interface.c"
"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/marwa/Desktop/ControleModuleForSwitchingMatrix(CMSM)/Cippà _TB_CMMSM_Report_Annex/Digital/CMMSM_ccs_workspace_V9/CMMSM_FW_newCmd" --include_path="C:/ti/TivaWare_C_Series-2.2.0.295" --include_path="C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="USB/usb_interface.d_raw" --obj_directory="USB" "../USB/usb_interface.c"
USB/subdir_rules.mk:9: recipe for target 'USB/usb_interface.obj' failed
while processing file ../USB/usb_interface.c
gmake: *** [USB/usb_interface.obj] Error 2
Building file: "../Buffer/ring_buff.c"
"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/marwa/Desktop/ControleModuleForSwitchingMatrix(CMSM)/Cippà _TB_CMMSM_Report_Annex/Digital/CMMSM_ccs_workspace_V9/CMMSM_FW_newCmd" --include_path="C:/ti/TivaWare_C_Series-2.2.0.295" --include_path="C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="Buffer/ring_buff.d_raw" --obj_directory="Buffer" "../Buffer/ring_buff.c"
Buffer/subdir_rules.mk:9: recipe for target 'Buffer/ring_buff.obj' failed
while processing file ../Buffer/ring_buff.c
gmake: *** [Buffer/ring_buff.obj] Error 2
Building file: "../HAL/HAL_msm.c"
"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/marwa/Desktop/ControleModuleForSwitchingMatrix(CMSM)/Cippà _TB_CMMSM_Report_Annex/Digital/CMMSM_ccs_workspace_V9/CMMSM_FW_newCmd" --include_path="C:/ti/TivaWare_C_Series-2.2.0.295" --include_path="C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="HAL/HAL_msm.d_raw" --obj_directory="HAL" "../HAL/HAL_msm.c"
HAL/subdir_rules.mk:9: recipe for target 'HAL/HAL_msm.obj' failed
while processing file ../HAL/HAL_msm.c
gmake: *** [HAL/HAL_msm.obj] Error 2
Building file: "../tm4c1294ncpdt_startup_ccs.c"
"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/marwa/Desktop/ControleModuleForSwitchingMatrix(CMSM)/Cippà _TB_CMMSM_Report_Annex/Digital/CMMSM_ccs_workspace_V9/CMMSM_FW_newCmd" --include_path="C:/ti/TivaWare_C_Series-2.2.0.295" --include_path="C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="tm4c1294ncpdt_startup_ccs.d_raw" "../tm4c1294ncpdt_startup_ccs.c"
subdir_rules.mk:9: recipe for target 'tm4c1294ncpdt_startup_ccs.obj' failed
while processing file ../tm4c1294ncpdt_startup_ccs.c
gmake: *** [tm4c1294ncpdt_startup_ccs.obj] Error 2
Building file: "../HAL/HAL_init.c"
"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/marwa/Desktop/ControleModuleForSwitchingMatrix(CMSM)/Cippà _TB_CMMSM_Report_Annex/Digital/CMMSM_ccs_workspace_V9/CMMSM_FW_newCmd" --include_path="C:/ti/TivaWare_C_Series-2.2.0.295" --include_path="C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="HAL/HAL_init.d_raw" --obj_directory="HAL" "../HAL/HAL_init.c"
HAL/subdir_rules.mk:9: recipe for target 'HAL/HAL_init.obj' failed
while processing file ../HAL/HAL_init.c
gmake: *** [HAL/HAL_init.obj] Error 2
Building file: "../HAL/HAL_Leds.c"
"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/marwa/Desktop/ControleModuleForSwitchingMatrix(CMSM)/Cippà _TB_CMMSM_Report_Annex/Digital/CMMSM_ccs_workspace_V9/CMMSM_FW_newCmd" --include_path="C:/ti/TivaWare_C_Series-2.2.0.295" --include_path="C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="HAL/HAL_Leds.d_raw" --obj_directory="HAL" "../HAL/HAL_Leds.c"
HAL/subdir_rules.mk:9: recipe for target 'HAL/HAL_Leds.obj' failed
while processing file ../HAL/HAL_Leds.c
gmake: *** [HAL/HAL_Leds.obj] Error 2
Building file: "../main.c"
"C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/marwa/Desktop/ControleModuleForSwitchingMatrix(CMSM)/Cippà _TB_CMMSM_Report_Annex/Digital/CMMSM_ccs_workspace_V9/CMMSM_FW_newCmd" --include_path="C:/ti/TivaWare_C_Series-2.2.0.295" --include_path="C:/ti/ccs1010/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="main.d_raw" "../main.c"
subdir_rules.mk:9: recipe for target 'main.obj' failed
while processing file ../main.c
gmake: *** [main.obj] Error 2
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
