Part Number: RM48L950
Other Parts Discussed in Thread: HALCOGEN
I am trying to use onboard temperature & light sensors of RM48 L950. I am referring to example code given in HALCoGen. So I made some changes in the example code to work on temperature & light sensors. But the output on terminal is like in the image I am attaching here. Can anyone tell me what is wrong in my pin configuartion or code?
Thanks & Regards,
Prathamesh Yawalkar
/** @file sys_main.c
* @brief Application main file
* @date 11-Dec-2018
* @version 04.07.01
* This file contains an empty main function,
* which can be used for the application.
* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "sys_common.h"
/* USER CODE BEGIN (1) */
#include "esm.h"
#include "adc.h"
#include "sci.h"
#include "gio.h"
#define TSIZE1 12
uint8 TEXT1[TSIZE1]= {'\r','\n','|','\t','C','H','.','I','D','=','0','x'};
#define TSIZE2 9
uint8 TEXT2[TSIZE2]= {'\t','V','A','L','U','E','=','0','x'};
adcData_t adc_data[10];
void sciDisplayText(sciBASE_t *sci, uint8 *text, uint32 length);
void sciDisplayData(sciBASE_t *sci, uint8 *text,uint32 length);
void wait(uint32 time);
/* USER CODE END */
/** @fn void main(void)
* @brief Application main function
* @note This function is empty by default.
* This function is called after startup.
* The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
/* USER CODE END */
int main(void)
/* USER CODE BEGIN (3) */
uint32 ch_count=0;
uint32 id =0;
uint32 value =0;
/* initialize gio */
gioInit();
gioSetDirection(gioPORTB, 1);
/* initialize sci/sci-lin : even parity , 2 stop bits */
sciInit();
/* initialize ADC */
/* Group1 -> Channel 0 and 1 */
/* HW trigger trigger source as GIOB Pin 0 */
adcInit();
/* start adc conversion */
adcStartConversion(adcREG1,adcGROUP1);
while(1) /* ... continue forever */
/* trigger using gio port b, pin 0 */
gioSetBit(gioPORTB, 0, 1);
/* ... wait and read the conversion count */
while((adcIsConversionComplete(adcREG1,adcGROUP1))==0);
ch_count = adcGetData(adcREG1, adcGROUP1,&adc_data[0]);
ch_count = ch_count;
/* conversion results : */
/* adc_data[0] -> should have conversions for Group1 channel1 */
/* adc_data[1] -> should have conversions for Group1 channel2 */
/*id = adc_data[0].id;*/
/*value = adc_data[0].value;*/
id = adc_data[9].id;
value = adc_data[9].value;
gioSetBit(gioPORTB, 0, 0);
sciDisplayText(scilinREG,&TEXT1[0],TSIZE1); /* send text 1 */
sciDisplayData(scilinREG,(uint8*)&id,8); /* send data 1 */
sciDisplayText(scilinREG,&TEXT2[0],TSIZE2); /* send text 2 */
sciDisplayData(scilinREG,(uint8*)&value,8); /* send data 2 */
id = adc_data[8].id;
value = adc_data[8].value;
sciDisplayData(scilinREG,(uint8*)&id,16); /* send data 1 */
sciDisplayData(scilinREG,(uint8*)&value,16); /* send data 2 */
wait(0xFFFFFF);
/* USER CODE END */
return 0;
/* USER CODE BEGIN (4) */
uint8 txt = 0;
uint8 txt1 = 0;
#if ((__little_endian__ == 1) || (__LITTLE_ENDIAN__ == 1))
text = text + (length -1);
#endif
while(length--)
txt = *text--;
#else
txt = *text++;
#endif
txt1 = txt;
txt &= ~(0xF0);
txt1 &= ~(0x0F);
txt1 =txt1>>4;
if(txt<=0x9)
txt +=0x30;
else if(txt > 0x9 && txt < 0xF)
txt +=0x37;
else
txt = 0x30;
if(txt1 <= 0x9)
txt1 +=0x30;
else if((txt1 > 0x9) && (txt1 <= 0xF))
txt1 +=0x37;
else
txt1 = 0x30;
while ((scilinREG->FLR & 0x4) == 4); /* wait until busy */
sciSendByte(scilinREG,txt1); /* send out text */
sciSendByte(scilinREG,txt); /* send out text */
void sciDisplayText(sciBASE_t *sci, uint8 *text,uint32 length)
while(length--)
sciSendByte(scilinREG,*text++); /* send out text */
while(time){time--;};
/* USER CODE END */
