Part Number: TM4C1290NCZAD
Team,
I'm working from the app note SPMA073 using example 'ektm4c129_i2c_master_udma_fifo'. The demo is based on communicating with a 24C256 external memory device. The issue I have is I'm trying to communicate with a 24C02. The main difference is that the 24C256 use a 2 byte internal addressing scheme and the 24C02 uses a single byte internal addressing scheme.
Please will you detail the steps to change the 'ektm4c129_i2c_master_udma_fifo' example from using a 2 byte address internal address (24C256) to a single byte address (24C02)?
I have tried to do this myself but so far without success.
Thanks.
