Part Number: TMS570LC4357
Other Parts Discussed in Thread: HALCOGEN,
Tools using : CCS , HALCOGEN
Issue : Example given for TMS570LC43xx in HALCOGEN for mibspi is not working
Doing all the configuration as per given in the sample example file.
/** @example example_mibspi_loopback.c
* This is an example which descibes the steps to create Mibspi Loopback check
* @b Step @b 1:
* Create a new project.
* Navigate: -> File -> New -> Project
* @image html example_createProject.jpg "Figure: Create a new Project"
* @b Step @b 2:
* Configure driver code generation:
* - Enable MIBSPI 1 to 5 driver
* - Disable others
* Navigate: -> TMS570Sxx /RMxx -> Enable Drivers
* @b Step @b 3:
* Enable Interrupts
* - Enable all MIBSPI interrupts in the MIBSPI VIM Channels tab.
* @b Step @b 4:
* Configure MIBSPI
* - Leave the Transfer group configuration as default
* @image html example_mibspi_config.jpg "Figure: Configure MIBSPI"
* @b Step @b 5:
* Generate code
* Navigate: -> File -> Generate Code
* @image html generateCode.jpg "Figure: Generate Code"
* @b Step @b 6:
* Copy the source code below into your sys_main.c (or) replace sys_main.c with this file.
* The example file example_mibspi_loopback.c can also be found in the examples folder: ../HALCoGen/examples
* @note HALCoGen generates an empty main function in sys_main.c.
/* (c) Texas Instruments 2009-2013, All rights reserved. */
* Copyright (C) 2009-2015 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* INCLUDING NEGLIGENCE OR OTHERWISE ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "HL_sys_common.h"
#include "HL_system.h"
/* USER CODE BEGIN (1) */
#include "HL_mibspi.h"
#include "HL_esm.h"
#include "HL_sys_core.h"
#define D_COUNT 8
uint32 cnt=0, error =0, tx_done =0;
uint16 tx_data1[D_COUNT] = {1,2,3,4,5,6,7,8};
uint16 tx_data2[D_COUNT] = {11,12,13,14,15,16,17,18};
uint16 tx_data3[D_COUNT] = {21,22,23,24,25,26,27,28};
uint16 tx_data4[D_COUNT] = {31,32,33,34,35,36,37,38};
uint16 tx_data5[D_COUNT] = {41,42,43,44,45,46,47,48};
uint16 rx_data1[D_COUNT] = {0};
uint16 rx_data2[D_COUNT] = {0};
uint16 rx_data3[D_COUNT] = {0};
uint16 rx_data4[D_COUNT] = {0};
uint16 rx_data5[D_COUNT] = {0};
/* USER CODE END */
/** @fn void main(void)
* @brief Application main function
* @note This function is empty by default.
* This function is called after startup.
* The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
/* USER CODE END */
void main(void)
/* USER CODE BEGIN (3) */
/* enable irq interrupt in */
_enable_IRQ_interrupt_();
/** Initialize MIBSPI */
mibspiInit();
mibspiEnableLoopback(mibspiREG1, Digital_Lbk);
mibspiEnableLoopback(mibspiREG2, Digital_Lbk);
mibspiEnableLoopback(mibspiREG3, Digital_Lbk);
mibspiEnableLoopback(mibspiREG4, Digital_Lbk);
mibspiEnableLoopback(mibspiREG5, Digital_Lbk);
mibspiEnableGroupNotification(mibspiREG1, 0, 1);
mibspiEnableGroupNotification(mibspiREG2, 0, 1);
mibspiEnableGroupNotification(mibspiREG3, 0, 1);
mibspiEnableGroupNotification(mibspiREG4, 0, 1);
mibspiEnableGroupNotification(mibspiREG5, 0, 1);
mibspiSetData(mibspiREG1, 0, &tx_data1[0]);
mibspiSetData(mibspiREG2, 0, &tx_data2[0]);
mibspiSetData(mibspiREG3, 0, &tx_data3[0]);
mibspiSetData(mibspiREG4, 0, &tx_data4[0]);
mibspiSetData(mibspiREG5, 0, &tx_data5[0]);
mibspiTransfer(mibspiREG1, 0);
mibspiTransfer(mibspiREG2, 0);
mibspiTransfer(mibspiREG3, 0);
mibspiTransfer(mibspiREG4, 0);
mibspiTransfer(mibspiREG5, 0);
while(1){};
/* USER CODE END */
/* USER CODE BEGIN (4) */
/* can interrupt notification */
void mibspiGroupNotification(mibspiBASE_t *mibspi, uint32 group)
uint16 * data;
/* node 1 - transfer request */
if(mibspi==mibspiREG1)
data = &rx_data1[0];
if(mibspi==mibspiREG2)
data = &rx_data2[0];
if(mibspi==mibspiREG3)
data = &rx_data3[0];
if(mibspi==mibspiREG4)
data = &rx_data4[0];
if(mibspi==mibspiREG5)
data = &rx_data5[0];
mibspiGetData(mibspi, group, data);
/* USER CODE END */
