Part Number: TM4C1294KCPDT
HI
WE are facing issue with LWIP file while compiling code. it shows error
Description Resource Path Location Type
unresolved symbol lwIPInit, first referenced in ./main.obj TRY C/C++ Problem
#include <stdbool.h>
#include <stdint.h>
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_adc.h"
#include "inc/hw_types.h"
#include "inc/hw_udma.h"
#include "inc/hw_emac.h"
#include "driverlib/debug.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/pin_map.h"
#include "driverlib/sysctl.h"
#include "driverlib/uart.h"
#include "driverlib/adc.h"
#include "driverlib/udma.h"
#include "driverlib/emac.h"
#include "driverlib/flash.h"
//#define TARGET_IS_BLIZZARD_RB1
#include "driverlib/rom.h"
//#include "eth_client.h"
//#include "utils/lwiplib.h"
#define IPADDR_USE_STATIC 0
#define IPADDR_USE_DHCP 1
#define IPADDR_USE_AUTOIP 2
//#define FLASH_BASE_ADDR ((volatile uint32_t*)0x00020000)
#define FLASH_BASE_ADDR ((uint32_t*)0x00020000)
#define ADC_SAMPLE_BUF_SIZE (128)
uint32_t udmaCtrlTable[1024] __attribute__ ((aligned(1024)));
uint32_t ADC_OUT_1[8],ADC_OUT_2[8];
uint32_t pui32Data[2];
//uint32_t ui32SysClock,ui32Config,ui32ClockDiv ;
void UARTSend(const uint8_t *pui8Buffer, uint32_t ui32Count);
void InitUART0();
void initEthernet();
int i;
void ADCSeq0Handler(void)
// Clear the Interrupt Flag.
ADCIntClear(ADC0_BASE, 0);
// uint32_t ui32Mode = uDMAChannelModeGet(UDMA_CHANNEL_ADC0);
if( uDMAChannelModeGet(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT) == 0)
uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_PRI_SELECT,UDMA_MODE_PINGPONG,(void *)(ADC0_BASE + ADC_O_SSFIFO0), ADC_OUT_1,8);
//uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_PRI_SELECT, UDMA_MODE_PINGPONG,(void *)(ADC0_BASE + ADC_O_SSFIFO0), ADC_OUT_1, 8);
uDMAChannelEnable(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT);
if( uDMAChannelModeGet(UDMA_CHANNEL_ADC0|UDMA_ALT_SELECT) == 0)
uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_ALT_SELECT, UDMA_MODE_PINGPONG,(void *)(ADC0_BASE + ADC_O_SSFIFO0),ADC_OUT_2,8);
uDMAChannelEnable(UDMA_CHANNEL_ADC0|UDMA_ALT_SELECT);
//uDMAChannelEnable(UDMA_CHANNEL_ADC0);
//uDMAChannelRequest(UDMA_CHANNEL_ADC0);
void InitUDMA(void)
uDMAEnable(); // Enables uDMA
uDMAControlBaseSet(udmaCtrlTable);
//IntEnable(INT_UDMA);
uDMAChannelAttributeDisable(UDMA_CHANNEL_ADC0, UDMA_ATTR_ALL);
// Configures the base address of the channel control table. Table resides in system memory and holds control
// information for each uDMA channel. Table must be aligned on a 1024-byte boundary. Base address must be
// configured before any of the channel functions can be used
uDMAChannelAttributeEnable(UDMA_CHANNEL_ADC0, UDMA_ATTR_USEBURST );
uDMAChannelControlSet(UDMA_CHANNEL_ADC0 | UDMA_PRI_SELECT, UDMA_SIZE_32 | UDMA_SRC_INC_NONE | UDMA_DST_INC_32 | UDMA_NEXT_USEBURST |UDMA_CHCTL_ARBSIZE_1);
uDMAChannelControlSet(UDMA_CHANNEL_ADC0 | UDMA_ALT_SELECT, UDMA_SIZE_32 | UDMA_SRC_INC_NONE | UDMA_DST_INC_32 | UDMA_NEXT_USEBURST |UDMA_CHCTL_ARBSIZE_1);
// uDMAChannelEnable(UDMA_CHANNEL_ADC0); // Enables DMA channel so it can perform transfers
//uDMAIntRegister(INT_UDMA,uDMAIntHandler);
//IntMasterEnable();
ADCIntEnableEx(ADC0_BASE, ADC_INT_DMA_SS0); // Enables ADC interrupt source due to DMA on ADC sample sequence 0
IntEnable(INT_ADC0SS0);
ADCIntRegister(ADC0_BASE,0,ADCSeq0Handler);
IntMasterEnable();
void InitConsole(void)
SysCtlPeripheralReset(SYSCTL_PERIPH_ADC0);
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
//SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC1);
SysCtlPeripheralReset(SYSCTL_PERIPH_UDMA);
SysCtlPeripheralEnable(SYSCTL_PERIPH_UDMA);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_2);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_1);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_0);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
GPIOPinTypeADC(GPIO_PORTD_BASE, GPIO_PIN_0);
GPIOPinTypeADC(GPIO_PORTD_BASE, GPIO_PIN_1);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOK);
GPIOPinTypeADC(GPIO_PORTK_BASE, GPIO_PIN_0);
GPIOPinTypeADC(GPIO_PORTK_BASE, GPIO_PIN_1);
ADCClockConfigSet(ADC0_BASE, ADC_CLOCK_SRC_PLL | ADC_CLOCK_RATE_FULL, 1);
IntDisable(INT_ADC0SS0);
ADCIntDisable(ADC0_BASE, 0);
ADCSequenceDisable(ADC0_BASE, 0);
//ADCIntClearEx(ADC0_BASE, ADC_INT_DMA_SS0);
ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_ALWAYS, 0);
ADCSequenceStepConfigure(ADC0_BASE, 0, 0, ADC_CTL_CH0);
ADCSequenceStepConfigure(ADC0_BASE, 0, 1, ADC_CTL_CH1);
ADCSequenceStepConfigure(ADC0_BASE, 0, 2, ADC_CTL_CH2);
ADCSequenceStepConfigure(ADC0_BASE, 0, 3, ADC_CTL_CH3);
ADCSequenceStepConfigure(ADC0_BASE, 0, 4, ADC_CTL_CH14);
ADCSequenceStepConfigure(ADC0_BASE, 0, 5, ADC_CTL_CH15);
ADCSequenceStepConfigure(ADC0_BASE, 0, 6, ADC_CTL_CH16);
ADCSequenceStepConfigure(ADC0_BASE, 0, 7, ADC_CTL_CH17|ADC_CTL_END);
ADCHardwareOversampleConfigure(ADC0_BASE, 64);
ADCSequenceDMAEnable(ADC0_BASE, 0);
ADCSequenceEnable(ADC0_BASE, 0);
int main(void)
uint32_t ui32SysClock;
// ui32SysClock = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |SYSCTL_OSC_MAIN|SYSCTL_USE_OSC ), 25000000);
ui32SysClock = SysCtlClockFreqSet(SYSCTL_XTAL_25MHZ|SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_320,32000000);
//uint32_t ui32Mode = uDMAChannelModeGet(UDMA_CHANNEL_ADC0);
InitConsole();
// ui32Config = ADCClockConfigGet(ADC0_BASE, &ui32ClockDiv);
InitUDMA();
InitUART0(ui32SysClock);
pui32Data[0]=FLASH_BASE_ADDR[0];
pui32Data[1]=FLASH_BASE_ADDR[1];
// FlashErase(0x20000);
initEthernet(ui32SysClock);
while(1)
for(i=0;i<5;i++)
//UARTSend((uint8_t *)"1", 1);
SysCtlDelay(ui32SysClock / 12);
pui32Data[0] = 0x00000008;
pui32Data[1] = 0x56789def;
FlashProgram(pui32Data,(uint32_t)FLASH_BASE_ADDR,sizeof(pui32Data));
//ADCProcessorTrigger(ADC0_BASE, 0);
//ADCIntClear(ADC0_BASE, 1);
//ADCSequenceDataGet(ADC0_BASE, 0, pui32ADC0Value);
//ADCSequenceDataGet(ADC1_BASE, 2, pui32ADC1Value);
// Loop while there are more characters to send.
while(ui32Count--)
// Write the next character to the UART.
UARTCharPutNonBlocking(UART0_BASE, *pui8Buffer++);
void InitUART0(uint32_t clock)
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
GPIOPinConfigure(GPIO_PA0_U0RX);
GPIOPinConfigure(GPIO_PA1_U0TX);
GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
UARTClockSourceSet(UART0_BASE,UART_CLOCK_SYSTEM);
UARTConfigSetExpClk(UART0_BASE, clock, 115200,(UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |UART_CONFIG_PAR_NONE));
void initEthernet(uint32_t sysclk)
uint8_t pui8MACArray[8];
uint32_t IpArray[4],subnet[4],Gateway[4];
GPIOPinConfigure(GPIO_PF0_EN0LED0);
GPIOPinConfigure(GPIO_PF4_EN0LED1);
GPIOPinTypeEthernetLED(GPIO_PORTF_BASE, GPIO_PIN_0 | GPIO_PIN_4);
pui8MACArray[0] = 0x01;
pui8MACArray[1] = 0x02;
pui8MACArray[2] = 0x03;
pui8MACArray[3] = 0x01;
pui8MACArray[4] = 0x02;
pui8MACArray[5] = 0x03;
IpArray[0]=192;
IpArray[1]=168;
IpArray[2]=5;
IpArray[3]=5;
subnet[0]=255;
subnet[1]=255;
subnet[2]=255;
subnet[3]=0;
Gateway[0]=192;
Gateway[1]=168;
Gateway[2]=5;
Gateway[3]=1;
lwIPInit(sysclk,pui8MACArray,(uint32_t)IpArray,(uint32_t)subnet,(uint32_t)Gateway,(uint32_t)IPADDR_USE_STATIC);
Please Help
Khodidas
