Part Number: MSP432E401Y
I am using the USB-MSC-HOST example for MSPE401Y and it is working perfectly when I insert a USB memory stick with an OTG adapter in the Launchpad micro USB port.
But when I connect the same USB stick through a USB hub the terminal shows : Unknowh Device Class (0x00) Connected.
I have made the same modifications as in this post to enable the USB HUB driver but it does not solve the problem.
Any idea on how to use USB MSC with USB HUB ?
Regards.
